    PIR Motion sensor
    16 Posts 6 Posters 14.7k Views 7 Watching
    • KimzerK
      Kimzer
      Interested in the very same thing! But i am trying to make my HUE light strip turn/on off as the screen already does.
      I found this Hue motion
      R 1 Reply Last reply
        richardh151 @Kimzer
        @Kimzer thanks but as a novice the suggested scripts blew my mind and seems much more complicated to what I’m currently using. I’m sure there is a way to modify it to switch on the led strip at the same time as the monitor jumps to life from the PIR motion sensor. I have a RPi3 and have it connected but struggle with the script which I’m sure is easy for someone else.
        O 1 Reply Last reply
        • KimzerK
          Kimzer
          @Kimzer said in LED Backlight for mirror - PIR to control them:
          Found this hue motion but i couldnt get it to run.
          Anyone that has some input?
          So i managed to do this. Its probably quite a dirty fix. And only setup to work with phillips hue bulbs/strips. But if u want to know shoot me a pm and ill show it. (Y)
          • O
            orayoflighto Project Sponsor @richardh151
            @richardh151
            Have you seen this?
            https://forum.magicmirror.builders/post/26789
            R 3 Replies Last reply
            • cowboysdudeC
              cowboysdude Module Developer @richardh151
              @richardh151 Here’s a VERY simple one…
              https://github.com/cowboysdude/Pir-Sensor
                richardh151 @orayoflighto
                @orayoflighto what you show is exactly what I need, however struggling with MMM pir Sensor module as my MM shows a conf.js error. So can’t get beyond that. I also have the RGB WS2812B led strips which I discovered r more problematic to control. I feel as though I tried many things but still frustrated with non functioning lights.
                    @orayoflighto I’m struggling with MMM PIR Sensor and constantly get a black screen, this is my coming input, can you advise if I’m doing anything obviously wrong, thanks
                    module: ‘MMM-PIR-Sensor’,
                    sensorGpio: 4, // This is the GPIO port number, not the header pin number
                    relayGpio: false, // This is the GPIO port number, not the header pin number
                    powerSaving: true,
                    relayOnState: 1,
                    relayOffState: 0,
                    turnOffAfterSeconds: 30,
                    debug: false
                    • O
                      Usually a black screen means that you have an error in your configuration file. Make a backup and remove as many lines as you can. Make sure you have the right GPIO pin. That can be confusing because it is different than the actual PIN number. Make sure you are also looking at a GPIO readout for a Pi 3 as the GPIOs are a little different depending on what version of the Pi you have.
                        @orayoflighto the error message is cannot find module onoff. Unsure now how to correct this, the GPIO pin seems correct
                        • strawberry 3.141S
                          strawberry 3.141 Project Sponsor Module Developer @richardh151
                          @richardh151 open a terminal go into your modules directory mmm-pir-sensor and run npm install
                          Reply Quote 2
                            richardh151 @strawberry 3.141
                            @strawberry-3.141 the simplest advice is always the best, it now works perfectly, thank you
