    Issue with White list IP(s) not working :(
    23 Posts 11 Posters 17.5k Views 12 Watching
      pingywon
      Got an issue with white listing IPs. I am sure I am doing something wrong, but I cant for the life of me figure it out.
      I wanna whitelist the whole 192.168.0.x and possibly even 192.168.1.x networks /24
      I added this to my white list
      var config = {
              port: 8080,
              ipWhitelist: ["192.168.0.1/24 , ::ffff:192.168.0.1/24", "::ffff:127.0.0.1", "::1"], // Set [] to allow all IP addresses
      The mirror boots fine (as opposed to black screening on me) but I get the
      “This device is not allowed to access your mirror.
      Please check your config.js or config.js.sample to change this.”
      error.
      Can someone give me something I can copy and paste…im not understanding this whitelist thing.
        Mykle1 Project Sponsor Module Developer @pingywon
        @pingywon said in Issue with White list IP(s) not working :(:
        You may or may not need the address: line. This will Whitelist all IP’s on the network. I don’t know if that is what you want. However, it should work.
        var config = {
        	port: 8080,
        	ipWhitelist: [],
        	address: "0.0.0.0",
          pingywon
          white listing everyone would be totally fine. Thanks for this! I cant wait to try it!
            @pingywon
            Keep my posted. Good luck! :^)
              pingywon @Mykle1
              @Mykle1
              it still isnt working :( Here is my config now…
              var config = {
                      port: 8080,
                      ipWhitelist:   [],                                     // Set [] to allow all IP addresses
                                  address:"0.0.0.0",                         // or add a specific IPv4 of 192.168.1.5 :
        // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.3.0/2$
              Any other ideas? I dont know why this is so hard :*(
                You tried with and without the address line?
                I know, it can be frustrating. Other people have had a similar problem. What I suggested to you has helped some of them. I’m sorry that it didn’t. Perhaps try searching the forum for Whitelist and see what you come up with. This one if just from the other day.
                https://forum.magicmirror.builders/topic/4701/changing-ipwhitelist-prevents-mirror-from-loading-correctly
                  pingywon
                  I do thank you for your time, but that thread is someone with the exact same problem as me and the answer is the same one you posed here and it doesnt work.
                  Why does it seem only a few people are having this issue?
                    I really can’t say why it happens to some and not others. It’s hard to troubleshoot for someone when there are so many unknowns. There are so many different setups (various Pi’s, PC’s, Mac’s, etc) all running different OS’s (various Raspbian flavors, various Windows versions, Mac OS, various uBuntu versions). This make’s it impossible for “one fix fits all” solutions. Personally, I do the best I can to help people that ask for help. There are many Whitelist topics that have been posted. I can only suggest that you use the search function here on the forum. In the meantime, someone else may have a suggestion that might work for you.
                    Best of luck to you
                    https://forum.magicmirror.builders/search?term=Whitelist&in=titlesposts
                      pingywon
                      Anyone else have any input. Im kinda stuck here. I have looked at other threads and have not drawn any conclusions
                      • da4throuxD Offline
                        da4throux
                        Not my area, but I was reading this: https://forum.magicmirror.builders/topic/1326/ipwhitelist-howto/8
                        and it mentions that the whitelisting on a range is for IPv6 , so maybe not working with IPv4.
                        Hope that help
                          Mykle1 Project Sponsor Module Developer @da4throux
                          New post:
                          https://forum.magicmirror.builders/topic/4701/changing-ipwhitelist-prevents-mirror-from-loading-correctly/8
                            pingywon
                            FOUND A WAY TO RESOLVE THIS!
                            Add
                            cat /etc/modprobe.d/ipv6.conf
                            # Don't load ipv6 by default
                            alias net-pf-10 off
                            # uncommented
                            alias ipv6 off
                            # added
                            options ipv6 disable_ipv6=1
                            # this is needed for not loading ipv6 driver
                            blacklist ipv6
                            to turn off all IPv6 on the Raspi.
                            Than edit all the IPv6 out of your config file.
                                    ipWhitelist: [
                                            "192.168.0.92",
                                            "192.168.0.1/24",
                                            "127.0.0.1"
                            I still have the .92 in there from testing. It is not needed.
                            did a sudo reboot just for safe measure and now it all seems to be working as intended. No real idea what the actual issue was…but it is resolved. FINALLY! :)
                              I just realized something. The machine I’m working on had MM 2.1.1 on it. I upgraded to MM 2.1.2 and lo and behold, the IPWhitelist is as whacked as can be. So, if I gave bad information, which I did, please excuse my oversight.
                              Peace!
                                roramirez Core Contributors
                                So, After a research about all this mess it up, the problem was a bug inside of ipfilter and MagicMirror too. When I added inside the sample config I’ve using express-ipfilter@0.2.4 In this version has a bug was fixed in 0.3.1 https://github.com/baminteractive/express-ipfilter/commit/4adc5dc33e6ef5086e36a7a56184da7cdcd056bf
                                The bug for MagicMirror was fixed some weeks ago,
                                https://github.com/MichMich/MagicMirror/commit/a7297d2685f5ed9b6b34df496065f05ee0d36568
                                You can using now the develop branch or install express-ipfilter previous of the 0.3.1
                                Mykle1M P 2 Replies Last reply Reply Quote 2
                                  Mykle1 Project Sponsor Module Developer @roramirez
                                  @roramirez said in Issue with White list IP(s) not working :(:
                                  Ahh, thank you! :^)
                                    psteimann @roramirez
                                    @roramirez does that mean that I only have to do an
                                    npm install express-ipfilter
                                    from the rooter with my console, if I have the actual magic mirror installed?
                                    tnx
                                    Peter
                                    • rcollieR Offline
                                      rcollie
                                      Nice one.
                                      • Y Offline
                                        yours.mukul
                                        How to white list all IP(s), to make magicmirror public??
                                          daikaiju @Mykle1
                                          Disabling IPv6 fixed the issue for me.
                                          • K Offline
                                            knubbl
                                            where did u disable it?
                                            B D 2 Replies Last reply Reply Quote 0
