    Issue with White list IP(s) not working :(
    23 Posts 11 Posters 15.9k Views 12 Watching
      pingywon
      white listing everyone would be totally fine. Thanks for this! I cant wait to try it!
        Mykle1 Project Sponsor Module Developer @pingywon
        @pingywon
        Keep my posted. Good luck! :^)
          pingywon @Mykle1
          @Mykle1
          it still isnt working :( Here is my config now…
          var config = {
                  port: 8080,
                  ipWhitelist:   [],                                     // Set [] to allow all IP addresses
                              address:"0.0.0.0",                         // or add a specific IPv4 of 192.168.1.5 :
        // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.3.0/2$
          Any other ideas? I dont know why this is so hard :*(
            @pingywon said in Issue with White list IP(s) not working :(:
            You tried with and without the address line?
            I know, it can be frustrating. Other people have had a similar problem. What I suggested to you has helped some of them. I’m sorry that it didn’t. Perhaps try searching the forum for Whitelist and see what you come up with. This one if just from the other day.
            https://forum.magicmirror.builders/topic/4701/changing-ipwhitelist-prevents-mirror-from-loading-correctly
              pingywon
              I do thank you for your time, but that thread is someone with the exact same problem as me and the answer is the same one you posed here and it doesnt work.
              Why does it seem only a few people are having this issue?
                I really can’t say why it happens to some and not others. It’s hard to troubleshoot for someone when there are so many unknowns. There are so many different setups (various Pi’s, PC’s, Mac’s, etc) all running different OS’s (various Raspbian flavors, various Windows versions, Mac OS, various uBuntu versions). This make’s it impossible for “one fix fits all” solutions. Personally, I do the best I can to help people that ask for help. There are many Whitelist topics that have been posted. I can only suggest that you use the search function here on the forum. In the meantime, someone else may have a suggestion that might work for you.
                Best of luck to you
                https://forum.magicmirror.builders/search?term=Whitelist&in=titlesposts
                  pingywon
                  Anyone else have any input. Im kinda stuck here. I have looked at other threads and have not drawn any conclusions
                  • da4throuxD Offline
                    da4throux
                    Not my area, but I was reading this: https://forum.magicmirror.builders/topic/1326/ipwhitelist-howto/8
                    and it mentions that the whitelisting on a range is for IPv6 , so maybe not working with IPv4.
                    Hope that help
                      Mykle1 Project Sponsor Module Developer @da4throux
                      New post:
                      https://forum.magicmirror.builders/topic/4701/changing-ipwhitelist-prevents-mirror-from-loading-correctly/8
                        pingywon
                        FOUND A WAY TO RESOLVE THIS!
                        Add
                        cat /etc/modprobe.d/ipv6.conf
                        # Don't load ipv6 by default
                        alias net-pf-10 off
                        # uncommented
                        alias ipv6 off
                        # added
                        options ipv6 disable_ipv6=1
                        # this is needed for not loading ipv6 driver
                        blacklist ipv6
                        to turn off all IPv6 on the Raspi.
                        Than edit all the IPv6 out of your config file.
                                ipWhitelist: [
                                        "192.168.0.92",
                                        "192.168.0.1/24",
                                        "127.0.0.1"
                        I still have the .92 in there from testing. It is not needed.
                        did a sudo reboot just for safe measure and now it all seems to be working as intended. No real idea what the actual issue was…but it is resolved. FINALLY! :)
