    Issue with White list IP(s) not working :(
    23 Posts 11 Posters 18.9k Views 12 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @pingywon
      @pingywon said in Issue with White list IP(s) not working :(:
      Can someone give me something I can copy and paste…im not understanding this whitelist thing.
      You may or may not need the address: line. This will Whitelist all IP’s on the network. I don’t know if that is what you want. However, it should work.
      var config = {
      	port: 8080,
      	ipWhitelist: [],
      	address: "0.0.0.0",
        pingywon
        white listing everyone would be totally fine. Thanks for this! I cant wait to try it!
        Mykle1M 1 Reply Last reply
        • Mykle1M
          @pingywon
          Keep my posted. Good luck! :^)
          P 1 Reply Last reply
            pingywon @Mykle1
            @Mykle1
            it still isnt working :( Here is my config now…
            var config = {
                    port: 8080,
                    ipWhitelist:   [],                                     // Set [] to allow all IP addresses
                                address:"0.0.0.0",                         // or add a specific IPv4 of 192.168.1.5 :
        // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.3.0/2$
            Any other ideas? I dont know why this is so hard :*(
            • Mykle1M
              You tried with and without the address line?
              I know, it can be frustrating. Other people have had a similar problem. What I suggested to you has helped some of them. I’m sorry that it didn’t. Perhaps try searching the forum for Whitelist and see what you come up with. This one if just from the other day.
              https://forum.magicmirror.builders/topic/4701/changing-ipwhitelist-prevents-mirror-from-loading-correctly
                pingywon
                I do thank you for your time, but that thread is someone with the exact same problem as me and the answer is the same one you posed here and it doesnt work.
                Why does it seem only a few people are having this issue?
                • Mykle1M
                  I really can’t say why it happens to some and not others. It’s hard to troubleshoot for someone when there are so many unknowns. There are so many different setups (various Pi’s, PC’s, Mac’s, etc) all running different OS’s (various Raspbian flavors, various Windows versions, Mac OS, various uBuntu versions). This make’s it impossible for “one fix fits all” solutions. Personally, I do the best I can to help people that ask for help. There are many Whitelist topics that have been posted. I can only suggest that you use the search function here on the forum. In the meantime, someone else may have a suggestion that might work for you.
                  Best of luck to you
                  https://forum.magicmirror.builders/search?term=Whitelist&in=titlesposts
                    pingywon
                    Anyone else have any input. Im kinda stuck here. I have looked at other threads and have not drawn any conclusions
                    • da4throuxD
                      da4throux
                      Not my area, but I was reading this: https://forum.magicmirror.builders/topic/1326/ipwhitelist-howto/8
                      and it mentions that the whitelisting on a range is for IPv6 , so maybe not working with IPv4.
                      Hope that help
                      • Mykle1M
                        Mykle1 Project Sponsor Module Developer @da4throux
                        New post:
                        https://forum.magicmirror.builders/topic/4701/changing-ipwhitelist-prevents-mirror-from-loading-correctly/8
                        D 1 Reply Last reply
                          pingywon
                          FOUND A WAY TO RESOLVE THIS!
                          Add
                          cat /etc/modprobe.d/ipv6.conf
                          # Don't load ipv6 by default
                          alias net-pf-10 off
                          # uncommented
                          alias ipv6 off
                          # added
                          options ipv6 disable_ipv6=1
                          # this is needed for not loading ipv6 driver
                          blacklist ipv6
                          to turn off all IPv6 on the Raspi.
                          Than edit all the IPv6 out of your config file.
                                  ipWhitelist: [
                                          "192.168.0.92",
                                          "192.168.0.1/24",
                                          "127.0.0.1"
                          I still have the .92 in there from testing. It is not needed.
                          did a sudo reboot just for safe measure and now it all seems to be working as intended. No real idea what the actual issue was…but it is resolved. FINALLY! :)
                          • Mykle1M
                            I just realized something. The machine I’m working on had MM 2.1.1 on it. I upgraded to MM 2.1.2 and lo and behold, the IPWhitelist is as whacked as can be. So, if I gave bad information, which I did, please excuse my oversight.
                            Peace!
                              roramirez Core Contributors
                              So, After a research about all this mess it up, the problem was a bug inside of ipfilter and MagicMirror too. When I added inside the sample config I’ve using express-ipfilter@0.2.4 In this version has a bug was fixed in 0.3.1 https://github.com/baminteractive/express-ipfilter/commit/4adc5dc33e6ef5086e36a7a56184da7cdcd056bf
                              The bug for MagicMirror was fixed some weeks ago,
                              https://github.com/MichMich/MagicMirror/commit/a7297d2685f5ed9b6b34df496065f05ee0d36568
                              You can using now the develop branch or install express-ipfilter previous of the 0.3.1
                              Mykle1M P 2 Replies Last reply
                              Reply Quote 2
                              • Mykle1M
                                Mykle1 Project Sponsor Module Developer @roramirez
                                @roramirez said in Issue with White list IP(s) not working :(:
                                Ahh, thank you! :^)
                                  psteimann @roramirez
                                  @roramirez does that mean that I only have to do an
                                  npm install express-ipfilter
                                  from the rooter with my console, if I have the actual magic mirror installed?
                                  tnx
                                  Peter
                                  • rcollieR
                                    rcollie
                                    Nice one.
                                    • Y
                                      yours.mukul
                                      How to white list all IP(s), to make magicmirror public??
                                        daikaiju @Mykle1
                                        Disabling IPv6 fixed the issue for me.
                                        • K
                                          knubbl
                                          where did u disable it?
                                          bheplerB D 2 Replies Last reply
                                          • bheplerB
                                            bhepler Module Developer @knubbl
                                            @knubbl - It will be at your router. It depends on the brand, but this sort of thing is usually in the advanced menu.
                                            … or you could follow the instructions in the post here.
