    Issue with White list IP(s) not working :(
    23 Posts 11 Posters 18.9k Views 12 Watching
    • da4throuxD
      da4throux
      Not my area, but I was reading this: https://forum.magicmirror.builders/topic/1326/ipwhitelist-howto/8
      and it mentions that the whitelisting on a range is for IPv6 , so maybe not working with IPv4.
      Hope that help
      Mykle1M 1 Reply Last reply
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @da4throux
        New post:
        https://forum.magicmirror.builders/topic/4701/changing-ipwhitelist-prevents-mirror-from-loading-correctly/8
        D 1 Reply Last reply
          pingywon
          FOUND A WAY TO RESOLVE THIS!
          Add
          cat /etc/modprobe.d/ipv6.conf
          # Don't load ipv6 by default
          alias net-pf-10 off
          # uncommented
          alias ipv6 off
          # added
          options ipv6 disable_ipv6=1
          # this is needed for not loading ipv6 driver
          blacklist ipv6
          to turn off all IPv6 on the Raspi.
          Than edit all the IPv6 out of your config file.
                  ipWhitelist: [
                          "192.168.0.92",
                          "192.168.0.1/24",
                          "127.0.0.1"
          I still have the .92 in there from testing. It is not needed.
          did a sudo reboot just for safe measure and now it all seems to be working as intended. No real idea what the actual issue was…but it is resolved. FINALLY! :)
          • Mykle1M
            Mykle1 Project Sponsor Module Developer @pingywon
            I just realized something. The machine I’m working on had MM 2.1.1 on it. I upgraded to MM 2.1.2 and lo and behold, the IPWhitelist is as whacked as can be. So, if I gave bad information, which I did, please excuse my oversight.
            Peace!
              roramirez Core Contributors
              So, After a research about all this mess it up, the problem was a bug inside of ipfilter and MagicMirror too. When I added inside the sample config I’ve using express-ipfilter@0.2.4 In this version has a bug was fixed in 0.3.1 https://github.com/baminteractive/express-ipfilter/commit/4adc5dc33e6ef5086e36a7a56184da7cdcd056bf
              The bug for MagicMirror was fixed some weeks ago,
              https://github.com/MichMich/MagicMirror/commit/a7297d2685f5ed9b6b34df496065f05ee0d36568
              You can using now the develop branch or install express-ipfilter previous of the 0.3.1
              Mykle1M P 2 Replies Last reply
              Reply Quote 2
              • Mykle1M
                Mykle1 Project Sponsor Module Developer @roramirez
                @roramirez said in Issue with White list IP(s) not working :(:
                Ahh, thank you! :^)
                  psteimann @roramirez
                  @roramirez does that mean that I only have to do an
                  npm install express-ipfilter
                  from the rooter with my console, if I have the actual magic mirror installed?
                  tnx
                  Peter
                  • rcollieR
                    rcollie
                    Nice one.
                    • Y
                      yours.mukul
                      How to white list all IP(s), to make magicmirror public??
                        daikaiju @Mykle1
                        Disabling IPv6 fixed the issue for me.
                        • K
                          knubbl
                          where did u disable it?
                          bheplerB D 2 Replies Last reply
                          • bheplerB
                            bhepler Module Developer @knubbl
                            @knubbl - It will be at your router. It depends on the brand, but this sort of thing is usually in the advanced menu.
                            … or you could follow the instructions in the post here.
                              daikaiju @knubbl
                              @knubbl https://www.leowkahman.com/2016/03/19/disable-ipv6-raspberry-raspbian/
                                chef
                                Are you giving your raspberry pi an ip address of “0.0.0.0”?
                                Why?
                                The address line should be the IP address of your pi.
                                Having it listen on any interface hasn’t really worked well.
                                Then the whitelist is an array of ip address. If you leave it empy (ex. []) then all the devices on your network will be able to access your mirror.
                                This is what mine looks like:
                                var config = {
                                	address: "192.168.2.48",
                                	port: 8080,
                                	ipWhitelist: [],
                                This especially makes a difference when using the “Restfull-ish” API. It is necessary to give the address line an ip address :)
