    Electron CPU usage
    247 Posts 46 Posters 668.9k Views 42 Watching
    • W
      wtidwell @TiemenMoesker
      @TiemenMoesker it feels good to get some validation that I may not actually be crazy and there is a problem. Hahaha
      T 1 Reply Last reply
      • T
        TiemenMoesker @wtidwell
        @wtidwell True :)
        • T
          TiemenMoesker
          @djsunrise19 I noticed that you have had this problem for wel over a year now. Damn. I don’t understand how it doesnt work properly… Used Noobs to install Rasbain, used auto install from MagicMirror homepage, nothing else, yet it doesn’t work.
          D 1 Reply Last reply
            djsunrise19 @TiemenMoesker
            @TiemenMoesker said in Electron CPU usage:
            Yes, but today, after
            git pull && npm install
            it becomes totally unusable. My “seconds” refreshed every 15 seconds, 320% CPU usage… I don’t know.
            • T
              TiemenMoesker @djsunrise19
              @djsunrise19
              :( …has anyone here tried another PI. I am considering to buy another one.
              D W 2 Replies Last reply
                @djsunrise19
                I have two of them. The second Raspi 3 (I bought them at the same time) works better. But, as everybody can see, while an animation is working, there are 45-55% peaks (one animation in newsfeed). I don’t think, that this should be.
                • W
                  @TiemenMoesker I tried two pies with exactly the same result. My spikes are way higher than 55%, on the order of max processing.
                    A Former User
                    I have a very stupid question.
                    In my new ATB, transition animation caused CPU usage around max 70%.(by nmon. htop shows less than that… around 30~50%). Without transition, near 10~20%.
                    But… I had not felt the performance issue before this thread. Will it be a real problem? I’m not an expert, but I think, temporally CPU usage could be high than we’ve thought. Should I really worry about this?
                      djsunrise19 @wtidwell
                      @wtidwell said in Electron CPU usage:
                      Hm, okay. But that seems to be a little bit weird. Imagine there are f.e. 8 modules. 3 of them make a fade at the same time (compliments, feed and calendar / netatmo, …). Then max processing is over 100%. Thats the problem in my first screenshot. 320% max cpu. This can not be right.
                        djsunrise19 @Guest
                        @Sean said in Electron CPU usage:
                        My ATB is coming today. I’ll made a new installation with all my modules and settings from my actual raspi. I’m very excited and I’ll give a report.
                        All in all it seems crazy to me, that those transitions are so cpu heavy. And in some cases (look at those nmon screenshots here) the cpu load is way to high and the mirror becomes unusable. So in that case, we should worry about that.
                        • Mykle1M
                          Mykle1 Project Sponsor Module Developer @Snille
                          @Snille said in Electron CPU usage:
                          The was originally @Snille idea!
                          Run in Pi3 terminal (or in SSH): cat /proc/cpuinfo
                          Compare hardware and revision… :)
                          Hardware : BCM2835
                          Revision : a02082
                          Pi 3 Model B 1GB a02082 (Sony, UK)
                          Pi 3 Model B 1GB a22082 (Embest, China)
                          Does anyone with Hardware :BCM2709 have this problem?
                          Does anyone with Hardware :BCM2835 NOT have this problem?
                          T D 2 Replies Last reply
                          • T
                            TiemenMoesker @Mykle1
                            @Mykle1
                            Maybe we are on to somthing here.
                            My hardware =BCM2835
                            Revision= a02082
                            And I DO have this problem.
                            Mykle1M L 2 Replies Last reply
                            • strawberry 3.141S
                              if i remember correct there is also a possibility to increase performance of transformations, but I’m not sure. Have to research on this
                              EDIT: I can’t do any testing for a while, if someone wants to get a hand on it I think this should make an effect as it will optimize the rendering from cpu usage to gpu. It’s still a new stuff though and I’m not sure if it is supported in electron yet.
                              .MODULENAME {
                                will-change: opacity;
                              replace modulename with the actual module name
                              • Mykle1M
                                Mykle1 Project Sponsor Module Developer @TiemenMoesker
                                Revision= a02082
                                My hardware = BCM2709
                                I do NOT have this problem
                                I’ve long suspected that this was/is a hardware issue. Why? I’ve done nothing special or different to my Pi 3 (except for adding a fan), yet it runs flawlessly, smoothly, and without the cpu overload experienced by a few select users. Assuming they have done nothing out of the ordinary (most have done fresh installs of the OS and default install of MM) yet their Pi 3’s exhibit inordinate amounts of cpu load at rest and extreme cpu load with just a simple function like the compliments changing.
                                @strawberry-3-141 There’s no need for me to try your suggestion but perhaps someone experiencing this problem will test it and report back their findings.
                                • T
                                  TiemenMoesker @strawberry 3.141
                                  @strawberry-3.141
                                  Ill hook up my PI in a sec and test it. I am supposed to put that line of code in the main.css file right? (Just to be sure)
                                  Mykle1M 1 Reply Last reply
                                  • Mykle1M
                                    @TiemenMoesker
                                    custom.css probably
                                    • T
                                      TiemenMoesker
                                      @strawberry-3-141
                                      @Mykle1
                                      Sad to report; Didn’t seem to solve the problem. YET, It almost seemed like the fade out animation was a tiny bit smoother, can’t say it for sure tho.
                                      • strawberry 3.141S
                                        strawberry 3.141 Project Sponsor Module Developer @TiemenMoesker
                                        @TiemenMoesker bugger, also when you increase gpu memory to a higher level than 64mb default
                                        Also it could still be unsupported in electron or it has to be taken to another element…
                                        • T
                                          @strawberry-3.141
                                          I’ve tried 64,128 and 256. No improvement :(
                                          strawberry 3.141S Mykle1M 2 Replies Last reply
                                          • strawberry 3.141S
                                            @TiemenMoesker maybe also @Jeff could have a look after his holidays as he is quiet familiar with css and he could check if the stuff I mentioned is valid
                                            • 12
                                            • 13
                                            • 4 / 13
