    Electron CPU usage
    247 Posts 46 Posters 660.6k Views 42 Watching
    • T
      TiemenMoesker
      @strawberry-3-141
      @Mykle1
      Sad to report; Didn’t seem to solve the problem. YET, It almost seemed like the fade out animation was a tiny bit smoother, can’t say it for sure tho.
      • strawberry 3.141S
        strawberry 3.141 Project Sponsor Module Developer @TiemenMoesker
        @TiemenMoesker bugger, also when you increase gpu memory to a higher level than 64mb default
        Also it could still be unsupported in electron or it has to be taken to another element…
        • T
          TiemenMoesker @strawberry 3.141
          @strawberry-3.141
          I’ve tried 64,128 and 256. No improvement :(
          strawberry 3.141S Mykle1M 2 Replies Last reply Reply Quote 0
          • strawberry 3.141S
            @TiemenMoesker maybe also @Jeff could have a look after his holidays as he is quiet familiar with css and he could check if the stuff I mentioned is valid
            • Mykle1M
              Mykle1 Project Sponsor Module Developer @TiemenMoesker
              @TiemenMoesker said in Electron CPU usage:
              @strawberry-3.141
              I don’t even remember changing this to 96, but it’s been like that since January, and no issues.
              • T
                @strawberry-3.141 Alright, although I am not sure this has anything to do with css. First, because 99% of the people who have MM2 don’t have this problem, yet the same css. Second, I just found out that it’s not just the Newsfeed and the Compliments. I have installed the MMM-Earth module and the same thing happends. Time freezes, animation starts (not smooth at all, it only shows me one fade frame), CPU usage spikes to 99% and my PI is hotter than a BBQ.
                I think it has something to do with the hardware.
                My hardware =BCM2835
                Revision= a02082
                • T
                  TiemenMoesker @Mykle1
                  @Mykle1
                  Just set is to 96, still the same.
                  • Mykle1M
                    My suspicion as well, as previously stated. And just to cover all bases, the only interface I have enabled is VNC. I don’t know if that matters in the least.
                    • T
                      TiemenMoesker
                      I researched the BCM2835 today if there where any known problems with it. Turns out there are, I just didn’t understand any of them. English is not my first language and I am a kinda new to the whole Raspberry Pi stuff and all the programming around it.
                      • strawberry 3.141S
                        @TiemenMoesker I’m sure thats not the reason for it, but it was worth trying it as a possible fix
                        • Mykle1M
                          You have a link for that?
                          • T
                            @Mykle1
                            Let me try, appreciate the help dude. Best forum i’ve ever been on. Problem is not solved yet, but I am happy there are some more brains in de game to help us out.
                            • Mykle1M
                              That makes perfect sense. If your Pi struggles with the simple compliments transition then it would certainly have trouble with MMM-EARTH. I’m even more sympathetic now because that’s my module! :-(
                              • T
                                @Mykle1
                                https://www.raspberrypi.org/forums/viewtopic.php?f=28&t=164454
                                https://github.com/Pi4J/pi4j/issues/319
                                This is what I found just typing in Rapberry BCM2835.
                                Not sure if this has anything to do with this problem tho.
                                • Mykle1M
                                  I read through both links. I don’t see anything that applies to this problem directly.
                                    djsunrise19 @Mykle1
                                    @Mykle1 said in Electron CPU usage:
                                    BCM2835
                                    For my two raspi3:
                                    Both of them are the BCM2835 Hardware-Versions. First BCM2835 has the problem, the other BCM2835 hasn’t. Wow… :-D
                                    T Mykle1M 2 Replies Last reply Reply Quote 0
                                    • T
                                      TiemenMoesker @djsunrise19
                                      @djsunrise19
                                      So the CPU usage doens’t spike with animations?
                                        djsunrise19 @TiemenMoesker
                                        @djsunrise19
                                        Not so high like my first one (100% permanently), about 50-60%. Here is a picture from my ATB, that arrives today. Naked installations, standard config / css / modules. 75% peak. Bad.
                                        T Mykle1M 3 Replies Last reply Reply Quote 0
                                        • T
                                          @djsunrise19
                                          Sorry to hear that man. I can get mine replaced for free, but I think I get a Pi with the same hardware
                                          • Mykle1M
                                            Mykle1 Project Sponsor Module Developer @djsunrise19
                                            @djsunrise19 said in Electron CPU usage:
                                            Well, there goes my theory, if the installations are exactly alike.
                                            • 12
                                            • 13
                                            • 5 / 13
