    Electron CPU usage
    247 Posts 46 Posters 661.9k Views 42 Watching
    • strawberry 3.141S
      strawberry 3.141 Project Sponsor Module Developer @TiemenMoesker
      @TiemenMoesker maybe also @Jeff could have a look after his holidays as he is quiet familiar with css and he could check if the stuff I mentioned is valid
      T 1 Reply Last reply
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @TiemenMoesker
        @TiemenMoesker said in Electron CPU usage:
        @strawberry-3.141
        I’ve tried 64,128 and 256. No improvement :(
        I don’t even remember changing this to 96, but it’s been like that since January, and no issues.
        • T
          TiemenMoesker @strawberry 3.141
          @strawberry-3.141 Alright, although I am not sure this has anything to do with css. First, because 99% of the people who have MM2 don’t have this problem, yet the same css. Second, I just found out that it’s not just the Newsfeed and the Compliments. I have installed the MMM-Earth module and the same thing happends. Time freezes, animation starts (not smooth at all, it only shows me one fade frame), CPU usage spikes to 99% and my PI is hotter than a BBQ.
          I think it has something to do with the hardware.
          My hardware =BCM2835
          Revision= a02082
          Mykle1M 2 Replies Last reply
          • T
            TiemenMoesker @Mykle1
            @Mykle1
            Just set is to 96, still the same.
            • Mykle1M
              My suspicion as well, as previously stated. And just to cover all bases, the only interface I have enabled is VNC. I don’t know if that matters in the least.
              • T
                TiemenMoesker
                I researched the BCM2835 today if there where any known problems with it. Turns out there are, I just didn’t understand any of them. English is not my first language and I am a kinda new to the whole Raspberry Pi stuff and all the programming around it.
                Mykle1M 1 Reply Last reply
                • strawberry 3.141S
                  @TiemenMoesker I’m sure thats not the reason for it, but it was worth trying it as a possible fix
                  • Mykle1M
                    You have a link for that?
                    • T
                      @Mykle1
                      Let me try, appreciate the help dude. Best forum i’ve ever been on. Problem is not solved yet, but I am happy there are some more brains in de game to help us out.
                      • Mykle1M
                        That makes perfect sense. If your Pi struggles with the simple compliments transition then it would certainly have trouble with MMM-EARTH. I’m even more sympathetic now because that’s my module! :-(
                        • T
                          @Mykle1
                          https://www.raspberrypi.org/forums/viewtopic.php?f=28&t=164454
                          https://github.com/Pi4J/pi4j/issues/319
                          This is what I found just typing in Rapberry BCM2835.
                          Not sure if this has anything to do with this problem tho.
                          • Mykle1M
                            I read through both links. I don’t see anything that applies to this problem directly.
                              djsunrise19 @Mykle1
                              @Mykle1 said in Electron CPU usage:
                              BCM2835
                              For my two raspi3:
                              Both of them are the BCM2835 Hardware-Versions. First BCM2835 has the problem, the other BCM2835 hasn’t. Wow… :-D
                              T Mykle1M 2 Replies Last reply
                              • T
                                TiemenMoesker @djsunrise19
                                @djsunrise19
                                So the CPU usage doens’t spike with animations?
                                D 1 Reply Last reply
                                  djsunrise19 @TiemenMoesker
                                  @djsunrise19
                                  Not so high like my first one (100% permanently), about 50-60%. Here is a picture from my ATB, that arrives today. Naked installations, standard config / css / modules. 75% peak. Bad.
                                  T Mykle1M 3 Replies Last reply
                                  • T
                                    @djsunrise19
                                    Sorry to hear that man. I can get mine replaced for free, but I think I get a Pi with the same hardware
                                    • Mykle1M
                                      Mykle1 Project Sponsor Module Developer @djsunrise19
                                      @djsunrise19 said in Electron CPU usage:
                                      Well, there goes my theory, if the installations are exactly alike.
                                      • Mykle1M
                                        Oh hell no. This issue gets more mysterious by the day!
                                        • Mykle1M
                                          about 50-60%
                                          That is even high, in my opinion, based on my results
                                            bhepler Module Developer
                                            For what it’s worth:
                                            Hardware: BCM2835
                                            Revision: a02082
                                            And I do not have the problem.
                                            • 12
                                            • 13
                                            • 5 / 13
