adding google calander to Config
So I tried to add google calendar to thr congif file but when I start MM I get a config error. So I search similar problems and found a solution. I tried http://jshint.com/ and fix the errors but I still get the error when I start up MM. BTW it was working before I edited the calander.
Here is the config with my email edited since I have it set to private
main();var config = { port: 8080, ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], // Set [] to allow all IP addresses // or add a specific IPv4 of 192.168.1.5 : // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.5"], // or IPv4 range of 192.168.3.0 --> 192.168.3.15 use CIDR format : // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.3.0/28"], language: "en", timeFormat: 12, units: "metric", modules: [ { module: "alert", }, { module: "updatenotification", position: "top_bar" }, { module: "clock", position: "top_left" }, { module: "calendar", header: "US Holidays", position: "top_left", config: { calendars: [ { symbol: "calendar-check-o ", url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics" }, { url: "https://calendar.google.com/calendar/ical/.com/private-3c6b3e476633ad/basic.ics" }, ], } }, { module: "compliments", position: "lower_third" }, { module: "currentweather", position: "top_right", config: { location: "Milwaukee,US", locationID: "5263045", appid: "5125ae8d38c755ac70a5f75421523d3d" } }, { module: "weatherforecast", position: "top_right", header: "Weather Forecast", config: { location: "Milwaukee,US", locationID: "5263045", appid: "5125ae8d38c755ac70a5f75421523d3d" } }, { module: "newsfeed", position: "bottom_bar", config: { feeds: [ { title: "New York Times", url: "http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml" } ], showSourceTitle: true, showPublishDate: true } }, ] }; /*************** DO NOT EDIT THE LINE BELOW ***************/ if (typeof module !== "undefined") {module.exports = config;} -
@spikeboybebop said in adding google calander to Config:
You’re missing the bottom of your config file, at the very least.
i updated the original post with the end part of the config file. I did rerun it and nothing changed and I don’t get any error or warning from http://jshint.com/
The very beginning of your config should look like this:
var config = { port: 8080, ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],I don’t know where you got main(); from
