adding google calander to Config
4 Posts 2 Posters 2.1k Views 2 Watching
    spikeboybebop
    So I tried to add google calendar to thr congif file but when I start MM I get a config error. So I search similar problems and found a solution. I tried http://jshint.com/ and fix the errors but I still get the error when I start up MM. BTW it was working before I edited the calander.
    Here is the config with my email edited since I have it set to private
    main();var config = {
    	port: 8080,
    	language: "en",
    	timeFormat: 12,
    	units: "metric",
    			module: "alert",
    			module: "updatenotification",
    			position: "top_bar"
    			module: "clock",
    			position: "top_left"
    			header: "US Holidays",
    						symbol: "calendar-check-o ",
                                                    url: "https://calendar.google.com/calendar/ical/.com/private-3c6b3e476633ad/basic.ics"
    			module: "compliments",
    			position: "lower_third"
    			module: "currentweather",
    				locationID: "5263045",
    				appid: "5125ae8d38c755ac70a5f75421523d3d"
    			module: "weatherforecast",
    			header: "Weather Forecast",
    			module: "newsfeed",
    			position: "bottom_bar",
    				feeds: [
    						title: "New York Times",
    				showSourceTitle: true,
    				showPublishDate: true
    M 1 Reply Last reply Sep 2, 2017, 12:58 AM Reply Quote 0
      Mykle1 Project Sponsor Module Developer @spikeboybebop
      @spikeboybebop said in adding google calander to Config:
      You’re missing the bottom of your config file, at the very least.
        spikeboybebop
        i updated the original post with the end part of the config file. I did rerun it and nothing changed and I don’t get any error or warning from http://jshint.com/
        M 1 Reply Last reply Sep 2, 2017, 1:49 AM Reply Quote 0
          @spikeboybebop
          The very beginning of your config should look like this:
          var config = {
          	port: 8080,
          I don’t know where you got main(); from
