    adding google calander to Config
    4 Posts 2 Posters 2.6k Views 2 Watching
      spikeboybebop
      So I tried to add google calendar to thr congif file but when I start MM I get a config error. So I search similar problems and found a solution. I tried http://jshint.com/ and fix the errors but I still get the error when I start up MM. BTW it was working before I edited the calander.
      Here is the config with my email edited since I have it set to private
      main();var config = {
      	port: 8080,
      	language: "en",
      	timeFormat: 12,
      	units: "metric",
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_left"
      			header: "US Holidays",
      						symbol: "calendar-check-o ",
                                                      url: "https://calendar.google.com/calendar/ical/.com/private-3c6b3e476633ad/basic.ics"
      			module: "compliments",
      			position: "lower_third"
      			module: "currentweather",
      				locationID: "5263045",
      				appid: "5125ae8d38c755ac70a5f75421523d3d"
      			module: "weatherforecast",
      			header: "Weather Forecast",
      			module: "newsfeed",
      			position: "bottom_bar",
      				feeds: [
      						title: "New York Times",
      				showSourceTitle: true,
      				showPublishDate: true
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @spikeboybebop
        @spikeboybebop said in adding google calander to Config:
        You’re missing the bottom of your config file, at the very least.
          spikeboybebop
          i updated the original post with the end part of the config file. I did rerun it and nothing changed and I don’t get any error or warning from http://jshint.com/
          • Mykle1M
            @spikeboybebop
            The very beginning of your config should look like this:
            var config = {
            	port: 8080,
            I don’t know where you got main(); from
