    MMM-MyCalendar
    109 Posts 40 Posters 166.0k Views 38 Watching
      [card:jclarke0000/MMM-MyCalendar]
      UPDATE: v2.0 released – requires MagicMirror v 2.2.0
      See below for details.
      This is based on the default calendar module, and is functionally exactly the same. The difference is in presentation layout:
      A note on v2.0:
      I’ve updated this module to use the new Nunjucks templating system. It also adds a new optional 2-column layout, useful if you’ve assigned MMM-MyCalendar to a wide region in your layout. See screenshot below. If you want to use this version you will need MagicMirror v2.2.0. Otherwise, you can download v1.0 here, which will work with earlier MM versions but will not have the 2-column layout option:
      https://github.com/jclarke0000/MMM-MyCalendar/releases/tag/v1.0
      rudibaraniR ? C 3 Replies Last reply Reply Quote 1
      • rudibaraniR
        rudibarani Project Sponsor @j.e.f.f
        @j.e.f.f Hi j.e.f.f.,
        it seems, as you made all the cool modules - so I keep coming back to you with questions. Hope that is OK.
        I plan to use your module to show if today is a national holiday.
        I have three questions for you:
        • If today is no holiday, you module shows “keine Termine” (=no entries). Is it possible to completely hide it, if no entry is present? (I limited the module to show only today’s entry from a public national holiday calendar).
        • You designed a nice way to integrate the number of the day into the calendar icon. I found this to be very useful for upcoming events - but would love to use custom symbols like in the original calendar for entries that are today (e.g. cake for birthdays) to visually separate things easily. The “symbol” variable does not seem to change it. Is it disabled? Or could it be used to overwrite your symbol?
        *Every entry is shown with a symbol, the description and a text, when it will be. In this example “Dienstag” (=tuesday). Is it possible to hide this last element and show only the symbol and the description? As my holiday-checker only shows today’s entries, this could be omitted and look cleaner.
        Thanks for your help!
          A Former User
          @j-e-f-f Nice job!
          I have a few question.
          1. How can I set the color of icons? My config is here. I don’t know why it doesn’t work.
              colored: true,  // required, right?
                           color: '#99FF99', // I don't know why this color doesn't work
                           url: "something.ics"
          1. How can you attach extra icon? In your screenshot, “Kinetic Social Pay” event has some image icon. I want to know how to do.
          strawberry 3.141S J 2 Replies Last reply Reply Quote 1
          • strawberry 3.141S
            strawberry 3.141 Project Sponsor Module Developer @Guest
            @Sean you didn’t nest the config properly
              j.e.f.f Project Sponsor Module Developer @rudibarani
              @rudibarani I just use a holiday calendar to add national holidays into the list. Like the ones you can find here:
              https://www.calendarlabs.com/ical-calendar-holidays.php
              If you download the ics file, you can insert the name into the url like this:
              http://www.calendarlabs.com/templates/ical/Canada-Holidays.ics
              renders like this:
              As for bringing back the alternative icon, it would break the design. The number in the calendar is the only place where the day of the month is indicated. If there were were a custom icon, I would have to put the full date into the description line, which I was trying to keep as minimal as possible. My thought is that my family would look at this for 30 seconds max on the way out the door. So I’m trying to keep the mental processing down.
              Maybe the original calendar beter suits your needs?
                j.e.f.f Project Sponsor Module Developer @Guest
                @Sean That extra icon beside “Kinetic Social Pay” is an emoji in the calendar entry itself. It has nothing to do with this module. In any case, you’re seeing a screenshot from my laptop. It doesn’t render on the mirror running Raspberry Pi. I just see a box.
                Does anyone know how to incorporate emojis on the Pi?
                bdeelmanB 1 Reply Last reply Reply Quote 0
                • kruemelK
                  kruemel
                  Hey Jeff
                  Iam not sure if this happend with the change, but i just updated your other module…
                  Since you added the possibility to change the format of your MyCommute travelTime (travelTimeFormat: “h[h] m[m]”,) i have the following issue with your calendar module.
                  Iam from switzerland and we are using the 24h mode.
                  If i set 12h in the config, the apointment is correct 7:00pm
                  If i change to 24h in the config (which here is the common setting) it shows 7:00 (am) instead of 19:00
                  I know the module is just modified from you (with the integrated basic “calendar” module which comes with the MagicMirror itself i also have the same issue).
                  So i think this could be an effect of the recent change of the “moment-duration-format” you describe? Or is this not possible?
                  (that works by the way, perfectly)
                  Thank you and you made a great job with this modules, love those! :-)
                    j.e.f.f Project Sponsor Module Developer @kruemel
                    @kruemel Ah! I see. The problem here is my version of the module is not properly respecting the global time format setting, so you’re getting a weird combination of 12 hour and 24 hour time in the output. I’ll see how soon I can get a fix in place for this.
                      @kruemel OK So I made a rather significant change in order to support this. Instead of trying to use the global time format parameter, you now explicitly specify how you would like days, dates and times displayed in your config. This gives you absolute control over everything.
                      To get the update, navigate to the MMM-MyCalendar directory and execute git pull.
                      IMPORTANT!!
                      One of the configuration parameters no longer means what it used to. If you used timeFormat to specify if you would like to see relative or absolute dates for upcoming events, that parameter is now named useRelativeDates, and you can specify true or false (Defaults to false).
                      timeFormat is now used to specify how you would like to see time displayed. For example, if you wanted 24 hour time with leading zeros, you would specify HH:mm (e.g.: 07:00, 23:30, etc).
                      dateFormat, which was previously used to specify a full string for date and time display is now used JUST to configure how you would like dates to be displayed. (e.g.: MMMM D for January 2, DD-MMM for 02-Jan, etc).
                      dayOfWeekFormat is new and is used to specify how you would like to see weekday names displayed (e.g.: dddd for Monday, ddd for Mon, etc.).
                      joiningWord is the word you would like to see displayed between Day/Date and Time. It defaults to at (e.g.: January 2 at 2:00 PM), so if you do not want a joining word, specify an empty string (i.e.: joiningWord : ""). In the above example you would configure joiningWord : "um".
                      The module will build the full event date string using bits and pieces of how your configure the items above.
                      • kruemelK
                        kruemel
                        You’r great :-)
                        Thank you very much, it works like a charm. Also happy about the joiningWord.
                        That makes fun to use with short response from developers ;-)
                        Wish you a nice week and thanks again for your fast adjustment!
                          @kruemel Glad you like the update!
                            pjkoeleman
                            Re: MMM-MyCalendar
                            @j-e-f-f Thanks a lot for the latest update. Now I have a request for an addittion.
                            In the line with the appointment date and time my line in Dutch now reads
                            “Morgen om 19:00” > “Tomorrow at 19:00”
                            Can we ad a suffix word like “joiningWord”? In this way I can configure my appointment day and time line as
                            “Morgen om 19:00 uur” > “Tomorrow at 19:00 hour”
                            When you don’t want the suffix make it possible to use an empty string like joiningWord (suffixWord : “”)
                            On Github I sent you my proposed file changes.
                            Thanks in advance.
                              j.e.f.f Project Sponsor Module Developer @pjkoeleman
                              @pjkoeleman you can add that into your timeFormat config, like so:
                              timeFormat : "HH:mm [uur]"
                              Anything in the square brackets will display exactly as you type it.
                              P 1 Reply Last reply Reply Quote 2
                                pjkoeleman @j.e.f.f
                                @j.e.f.f
                                That will do as well, thanks for your repley.
                                • KimzerK
                                  Kimzer
                                  I love this module. Very nicely made. But i would like to be able to show a calender with every single day + something special to show the holidays(i only use it for holidays now)
                                  Can i create an ical with all the days in it and maybe have a certain color for holidays?
                                  J ? 2 Replies Last reply Reply Quote 0
                                    j.e.f.f Project Sponsor Module Developer @Kimzer
                                    @Kimzer Do you mean you want to display the whole year? If so that is not what this is designed to do. The thinking behind this is that you really don’t spend a lot of time looking at the mirror, so it only displays information that is immediately useful and that can be consumed in about 30 seconds.
                                    That said, I think I saw a calendar module that displays a month at a time that might be more in line with what you are looking for. Sorry I don’t remember its name but if you do a search I’m sure you’ll find it.
                                    • strawberry 3.141S
                                      strawberry 3.141 Project Sponsor Module Developer @j.e.f.f
                                      @j.e.f.f should be calendar_monthly by @KirAsh4
                                        A Former User @Kimzer
                                        @Kimzer Consider MMM-CalendarExt. It has daily view.(or something more than)
                                          Johans
                                          Nice module, great work.
                                          Now I see the US calendar but I would like to see a Belgian calendar with school hollidays and also where I can add local appointments.
                                          How can I do this - any instructions or help would be great
                                            j.e.f.f Project Sponsor Module Developer @Johans
                                            @Johans Try this site:
                                            https://calendar.teamup.com/kb/holiday-calendar-feeds-preview-teamup/
                                            There is one for Belgium there, as well as a whole bunch of countries.
                                            To add your own appointments, just follow the same instructions as the default calendar for adding your own calendar account.
                                            • 1 / 6
