    • cowboysdudeC Offline
      @Mykle1 Ground Hog day
      https://www.youtube.com/watch?v=eZbtAFq7dP8
      • K Offline
        kris_huang
        Chinese :)
        “GATHERING_WEATHER_STUFF”: “天气预报”,
        “CURRENTLY”: “当前”,
        “CURRENT_TEMP”: “当前温度”,
        “UV_INDEX”: “紫外线指数”,
        “WIND”: “风向”,
        “FROM”: “从”,
        “BAROMETER”: “气压”,
        “FORECAST”: “预测”,
        “MONDAY”: “星期一”,
        “TUESDAY”: “星期二”,
        “WEDNESDAY”: “星期三”,
        “THURSDAY”: “星期四”,
        “FRIDAY”: “星期五”,
        “SATURDAY”: “星期六”,
        “SUNDAY”: “星期天”,
        “OVERCAST”: “阴天”,
        “CLOUDY”: “多云”,
        “RAIN”: “雨”,
        “CLEAR”: “晴”,
        “PARTLY_CLOUDY”: “部分多云”,
        “HIGH”: “高”,
        “LOW”: “低”,
        “HUMIDITY”: “湿度”,
        “SAFE”: “安全”,
        “MODERATE”: “中等”,
        “SNOW_SHOWERS”: “阵雨”,
        “VERY_HIGH”: “非常高”,
        “EXTREME”: “极高”,
        “SUNSET”: “日落”,
        “SUNRISE”: “日出”,
        “hours”: “小时”,
        “minutes”: “分钟”,
        “Amount of Daylight”: “白昼”
          Huge Thanks to @kris_huang for providing me with the Chinese translations!
          It’s now up on Github!
          Thank you again!!
            barnosch
            can you explain what else you have changed?
            Since today the module is stuck at “Gathering weather data”.
            The mirror tells me, that there is a update, and i should upgrade.
            Since i made massive manual changes in the module on many different places to fit my needs, i don’t really want to do it all over again.
            So it would be helpful to know, what lines changed so the great module works again.
            I am not really into the git thing, so i don’t know how i can compare the changes (if possible)
            • strawberry 3.141S Offline
              strawberry 3.141 Project Sponsor Module Developer @barnosch
              @barnosch you can see a list of all changes here https://github.com/cowboysdude/MMM-NOAA/commits/master
              every item in the list will show you what has changed. green is added, red is removed
              • K Offline
                kris_huang
                I find The black screen was caused by Chinese parentheses
                  "GATHERING WEATHER STUFF": "天气预报",
                  "Currently: ": "当前:",
                  "Current Temp: ": "当前温度: ",
                  "UV Index: ": "紫外线指数: ",
                  "Wind: ": "风向: ",
                  "From: ": "从: ",
                  "Barometer: ": "气压 ",
                  "~~~ Forecast ~~~<br />": "近期天气预测",
                  "Monday": "星期一",
                  "Tuesday": "星期二",
                  "Wednesday": "星期三",
                  "Thursday": "星期四",
                  "Friday": "星期五",
                  "Saturday": "星期六",
                  "Sunday": "星期日",
                  "Overcast": "阴天",
                  "Cloudy": "多云",
                  "Rain": "雨",
                  "Clear": "晴",
                  "Partly Cloudy": "部分多云",
                  "High: ": "高: ",
                  "Low: ": "低: ",
                  "Barometer: ":"气压:",
                  "Humidity: ": "湿度: ",
                  "Humidity: <b>" : "湿度: ",
                  "Safe": "安全",
                  "Moderate": "中等",
                  "Snow showers": "阵雨",
                  "Very High": "非常高",
                  "Extreme": "极高",
                  "Sunset": "日落",
                  "Sunrise": "日出",
                  " hours ": "小时",
                  " minutes ": "分钟",
                  "Amount of Daylight": "白昼",
                  "Air Quality Index: ": "空气质量指数: ",
                  "Good Morning ":"早上好! ",
                  "Good Afternoon ": "下午好! ",
                  "Good Evening ": "晚上好! ",
                  "Good Morning!":"早上好!",
                  "Good Afternoon!": "下午好!",
                  "Good Evening!": "晚上好!"
                ```</b>
                  barnosch
                  cool. thanks for the explanation.
                  So what can i do, if i do not want to update, because it would overwrite my changes, but get rid of the “please update the MMM-NOAA module” message on the mirror?
                  is there a git command to ignore local changes?
                  strawberry 3.141S cowboysdudeC 2 Replies Last reply Reply Quote 0
                    @barnosch i think you can ignore the update message by moving the .git directory somewhere else, so the updatechecker doesn’t recognize this module as a git repository
                      cowboysdude Module Developer @barnosch
                      @barnosch said in MMM-NOAA - Another Weather Module:
                      The change was made because the url was wrong… For some reason that’s one of the issues for the problems :) It’s fixed.
                      Follow @strawberry-3-141 advice :)
                        @kris_huang said in MMM-NOAA - Another Weather Module:
                        “GATHERING WEATHER STUFF”: “天气预报”,
                        "Currently: ": “当前:”,
                        "Wind: ": "风向: ",
                        "From: ": "从: ",
                        “~~~ Forecast ~~~
                        ”: “近期天气预测”,
                        “Monday”: “星期一”,
                        “Tuesday”: “星期二”,
                        “Wednesday”: “星期三”,
                        “Thursday”: “星期四”,
                        “Friday”: “星期五”,
                        “Saturday”: “星期六”,
                        “Sunday”: “星期日”,
                        “Overcast”: “阴天”,
                        “Cloudy”: “多云”,
                        “Rain”: “雨”,
                        “Clear”: “晴”,
                        “Partly Cloudy”: “部分多云”,
                        "High: ": "高: ",
                        "Low: ": "低: ",
                        "Barometer: ":“气压:”,
                        “Humidity: ” : "湿度: ",
                        “Safe”: “安全”,
                        “Moderate”: “中等”,
                        “Snow showers”: “阵雨”,
                        “Very High”: “非常高”,
                        “Extreme”: “极高”,
                        “Sunset”: “日落”,
                        “Sunrise”: “日出”,
                        " hours ": “小时”,
                        " minutes ": “分钟”,
                        “Amount of Daylight”: “白昼”,
                        “Good Morning!”:“早上好!”,
                        “Good Afternoon!”: “下午好!”,
                        “Good Evening!”: “晚上好!”
                        Thank you for the corrections :)
                          Mykle1 Project Sponsor Module Developer @kris_huang
                          @kris_huang
                          That looks absolutely BAD ASS with the Chinese characters!
                            @cowboysdude
                            It was a great module.
                            Now . . . . . it’s friggin awesome!
                              barnosch
                              alert and update module disabled -> problem solved ;)
                                @barnosch That’s the first thing I do when I install it LOL Hate to say it… but it’s cool that you can!
                                But am curious to what changes you made… you never know they make another version ;) I"m always looking for ideas… Even styling ideas…because the one thing I’m not is a css wizard LOL
                                  @cowboysdude
                                  As this is a NOAA weather module, I thought you might be interested in this, from NOAA. Pretty amazing!
                                  https://weather.com/storms/hurricane/video/flying-into-the-eye-of-hurricane-irma
                                    barnosch
                                    my fork looks like this.
                                    Almost anything is hardcoded or directly changed in the code since i am to lazy and just made it for my needs ;)
                                      @barnosch I like it!! Looks great!!
                                        UPDATE V.2
                                        Changed the format to show 3 days of weather instead of rotating. Quicker, easier and loads twice as fast!
                                        Added 2 new config options:
                                        1. Show or hide wind
                                        2. Show or hide Date
                                        See the README on Github
                                        Thank you to @barnosch for the help and ideas!!
                                        Download:
                                        [card:cowboysdude/MMM-NOAA]
                                          barnosch
                                          big like !
                                            plybz18
                                            great, just got myself upgraded and looking awesome.
                                            How do i increase font size of temperature to look big?
                                            • 34
                                            • 35
                                            • 2 / 35
