    No Weather Showing?
    7 Posts 4 Posters 6.1k Views 3 Watching
    • G Offline
      glenntsharkey
      Hey there!
      Totally new to this! I wanted to design my own MagicMirror (thanks for the inspiration!).
      I got MagicMirror2 installed today (via the automatic installer), however the ‘Current Weather’ and ‘Weather Forecast’ is not working at all…
      With/Without the API code also, this doesn’t seem to make a difference…
      Can anyone help?
      Thanks!
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	port: 8080,
      	language: "en",
      	timeFormat: 24,
      	units: "metric",
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_left"
      			header: "US Holidays",
      						symbol: "calendar-check-o ",
      			module: "compliments",
      			position: "lower_third"
      			module: "currentweather",
      				locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
      			module: "weatherforecast",
      			header: "Weather Forecast",
      				locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
      			module: "newsfeed",
      			position: "bottom_bar",
      				feeds: [
      						title: "New York Times",
      				showSourceTitle: true,
      				showPublishDate: true
      • G Offline
        glenntsharkey
        Oh, and when I say not working at all, I mean; the weather modules are not on the screen…
        Thanks!
          Mykle1 Project Sponsor Module Developer @glenntsharkey
          @glenntsharkey said in No Weather Showing?:
          It certainly makes a difference. Without the API key neither of those modules will work. However, there does seem to be a problem with the weatherforecast module. The currentweather module is functional using a valid API key. Enter that precisely and your locationID.
          In the meantime, you can disable weatherforecast. You could also try another weather module that IS working. There are quite a few under the Weather heading here.
          https://github.com/MichMich/MagicMirror/wiki/MagicMirror²-Modules#3rd-party-modules
          • E Offline
            EventHorizon @glenntsharkey
            @glenntsharkey Hey mate, just giving you a piece of mind, you are not alone! I think in the most recent MM version there is a problem with both weather modules. But not to worry!
            I switched to this module 3 days ago:
            https://github.com/RedNax67/MMM-WunderGround
            I can confirm for you it’s working and it’s bloody fantastic. Let me know if you want any info or help or changing the config file.
            • MichMichM Offline
              MichMich
              It seems new API keys from open weather no longer are allowed to request the forecast. We are looking into a solution.
              Mykle1M E 2 Replies Last reply Reply Quote 1
                Mykle1 Project Sponsor Module Developer @MichMich
                @MichMich said in No Weather Showing?:
                That would explain it. My API key is 9 months old. With it, current weather works, forecast does not. Thanks for the update! :^)
                • E Offline
                  EventHorizon @MichMich
                  @MichMich cheers for the update Mich, you’re a legend :)
