    MMM-PublicTransportBerlin - Public transport for Berlin and Brandenburg (departures)
    84 Posts 25 Posters 123.2k Views 25 Watching
      derhuerst
      just a small reminder for those who want to have direction filtering. in berlin, there’s no machine-readable information about directions in the data that VBB provides.
      as an example, take U2:
      • in the west, it may end at ruhleben, theodor-heuss-platz
      • in the east, it may end at bülowstr, spittelmarkt, pankow
      this is without more complicated construction work.
      the best way to indicate a direction you want to get departures for is the next station after yours. @Beh we can try to implement this somehow, not sure wether in the API or in your magic mirror client.
        Beh @Tekki
        Hey @Tekki
        Unfortunately, I’m not really familiar with the changes, that @olexs made in his MMM-PublicTransportDB module, so I don’t really know, if your config is correct. You could open an issue on his GitHub repository with the same question again. Here it is:
        https://github.com/olexs/MMM-PublicTransportDB
          Beh @M1dn8
          To @M1dn8 @gekberlin:
          As @derhuerst mentions, this feature can be implemented, but it is a bit of work… We can try this. If you have any programming skills, your contribution is more than welcome :)
          To @derhuerst:
          Do you think, that some other possible future services that use your API will likely use this feature? If so, I think it should be done in the API. If not, I can just throw away the entries that are not used. But as you said, determining the direction could be a bit tricky. So one would need to know the next station on the line, huh?
          • G
            gekberlin @derhuerst
            @derhuerst said in MMM-PublicTransportBerlin - Public transport for Berlin and Brandenburg (departures):
            Yeah, that would help me actually a lot. I could also use the db api, but unfortunately the real-time data are not really accurate for the bvg-trams.
            @beh Unfortunately I’m a realy beginner in the software devolopment, but I think i’m not the only one who would appreciate that future and maybe some of them can program
              derhuerst
              On the API level, further discussion on this feature should be done at https://github.com/derhuerst/vbb-hafas/issues/19 .
                Beh
                Hey guys, I have good news for you:
                Commit 8c5e69f in the GitHub repo implements the one direction feature feature via the directionStationId variable. You just enter the next station on your line for the direction you want the departures to be shown.
                Some words about that:
                After some tests, the data delivery of this feature seems not to be as reliable as the normal version. Also, please make sure you actually have the right stationId for the direction station.
                Additionally, more request results take more time for the request. So please make sure to keep your maxUnreachableDepartures and maxReachabledepartures low when using this feature.
                If you encounter any issues with that, please open an issue on GitHub.
                I also mentioned this in the readme. Thanks again to @derhuerst for implementing the feature in his service!
                /cc @M1dn8 @gekberlin @ROMSY
                • KlerikerK
                  Kleriker
                  this is a very nice module! One thing though: Is there a way to make the text stop scrolling from right to left, if it’s a realy long station name?
                    Beh @Kleriker
                    @Kleriker Yes, you can set the marqueeLongDirections option to false`.
                    It’s described in the “Configuration” section here: https://github.com/deg0nz/MMM-PublicTransportBerlin
                    KlerikerK 1 Reply Last reply Reply Quote 0
                    • KlerikerK
                      Kleriker @Beh
                      @Beh OH how did I fail to see that… Thank you!
                        PaulB
                        this is an awesome module. Thank you for that!
                        Unfortunately, HVV does not support the API Key anymore.
                        Does anyone of you guys know a different way of getting the API key?
                        Thanks in advance :)
                        • I
                          Iseknutz @rudibarani
                          @rudibarani @olexs Did you solve the problem with the delay-calculation?
                            Beh
                            Attention:
                            Due to changes in the API, the stationId must be a string now. If you experience errors, please check the updated readme and change your configuration to use a string for the ID.
                            This is also true for the directionStationId is you use this feature.
                            • N
                              nem1
                              I get the following error using this module for about 2 days:
                              “Fehler bei Daten abrufen; {ifHafasError”:true,“message”:“Gateaway Time-out”,“statusCode”:504}
                              Das könnte heißen, dass VBB-Daten gerade nicht verfügbar sind.
                              I already updated the stationID and it was working correctly after the change. But now, I get this error.
                              Can anybody help?
                              Thanks a lot.
                                Beh @nem1
                                @nem1
                                This actually means what it says. VBB Data is currently not available. The API is down for some days now… The error has been reported.
                                You can check the status at https://status.transport.rest
                                • A
                                  AgP42 Project Sponsor Module Developer
                                  It is my first installation of this module and I also have the same error message.
                                  Is the VBB data still out of order or did I wrongly configure my module ?
                                  Thank you in advance,
                                  • N
                                    nem1 @AgP42
                                    @agp42 said in MMM-PublicTransportBerlin - Public transport for Berlin and Brandenburg (departures):
                                    The API is live again. So I think you did something wrong. Can you post the part of your config?
                                    • A
                                      @nem1 said in MMM-PublicTransportBerlin - Public transport for Berlin and Brandenburg (departures):
                                      Thank you for your answer and your help, in fact I initially copy-paste the official example of config, just to try the module before doing more configuration :
                                          module: "MMM-PublicTransportBerlin",
                                              stationId: "90000010000",
                                              hidden: false,
                                              ignoredStations: [900000100003,2342,1337],
                                              ignoredLines: ["U5", "U8", "S75" "Bus 100"],
                                              excludedTransportationTypes: "bus,suburban,subway",
                                              travelTimeToStation: 10,
                                              interval: 120000,
                                              departureMinutes: 10,
                                              maxDepartures: 15,
                                              marqueeLongDirections: true,
                                              showColoredLineSymbols: true,
                                              useColorForRealtimeInfo: true,
                                              showTableHeaders: true,
                                              showTableHeadersAsSymbols: true,
                                              maxUnreachableDepartures: 3,
                                              maxReachableDepartures: 7,
                                              fadeUnreachableDepartures: true,
                                              fadeReachableDepartures: true,
                                              fadePointForReachableDepartures: 0.25,
                                              excludeDelayFromTimeLabel: true
                                      but it didn’t work at all, the MagicMirror display the error that the config file is not valid :“Please create a config file”.
                                      So to debug that I remove all the non-required parameters, and keep only :
                                      Then the Mirror is starting again but this module display this error :
                                      Any idea of the origin of the problem ?
                                      Can you maybe send me a valid config to try it ?
                                      (My Mirror was in 2.4.0 and now updated in 2.4.1, but same issue, the Module is updated at its last version)
                                      Thanks in advance,
                                      AgP42
                                        Dicous
                                        by me the same here =/ . since 2 days
                                        • A
                                          AgP42 Project Sponsor Module Developer @Dicous
                                          @dicous said in MMM-PublicTransportBerlin - Public transport for Berlin and Brandenburg (departures):
                                          I personnaly never succeded to make that module work, but I use this one instead that is really cool and powerfull :
                                          MMM-PublicTransportHafas
                                            Beh
                                            The API is live again. Let’s see how long the new method is working… I have antoher solution on my roadmap to make this more reliable (hopefully :D)
                                            @AgP42 The Problem was not your configuration, but the data source the module is getting it’s data from. When you get the shown error, the module was configured right.
                                            For future readers: Please look into the GitHub issues of the module when problems occur!
                                            You can find them here: https://github.com/deg0nz/MMM-PublicTransportBerlin/issues/
                                            Additionally, you can check the avialability of the data source here: https://status.transport.rest
                                            • 4 / 5
