    MMM-Pnews
    47 Posts 9 Posters 42.2k Views 10 Watching
      Johans
      hi Cowboysdude,
      I like your modules, nice work.
      I was wondering if you could modify or make a separate module for the dutch (belgian) newsfeeds.
      take a look at this side: http://feeds.nieuwsblad.be/nieuws/snelnieuws
      they provide for each headline, a pircture and short description.
      It would be nice if you could also incorparate this into the module.
      Johan
      • cowboysdudeC Offline
        cowboysdude Module Developer @Johans
        @Johans said in MMM-Pnews:
        hi Cowboysdude,
        Johan
        Johan, Thank you! I will certainly take a peek at that this evening!! :)
          @Johans
          Here you go:
          https://github.com/cowboysdude/MMM-DNews
          Mykle1M J G 3 Replies Last reply Reply Quote 1
            @cowboysdude said in MMM-Pnews:
            Here you go:
            So, all I have to do is ask and you’ll make me a module?
            You’re awesome! :^)
              @Mykle1 said in MMM-Pnews:
              Here you go:
              You’re awesome! :^)
              Sure, why not? LOL
                Johans @cowboysdude
                @cowboysdude
                You are amazing.
                Never thought it would be realized.
                Had a hard day on the job today, but this makes my day.
                I’m going to install now.
                Johan
                • G Offline
                  goprojojo @cowboysdude
                  @Johans
                  Here you go:
                  Isnt Johan looking for Dutch instead of Danish news? :P
                    Johans @cowboysdude
                    @cowboysdude
                    just installed, but got an error -
                    Load script: modules/MMM-Dnews//MMM-Dnews.js
                    MMM-Dnews.js Failed to load resource: the server responded with a status of 404 (Not Found)
                    loader.js:190 Error on loading script: modules/MMM-Dnews//MMM-Dnews.js
                    script.onerror @ loader.js:190
                    Would like to make a printscreen, but i can’t manage to do that on the raspberry.
                    (indeed Dutch news, not Danish - thanks goprojojo )
                    Edit: added screenprints
                    cowboysdudeC 2 Replies Last reply Reply Quote 0
                      Sorry about that… right now I just don’t have time. I am SUPER busy… I will look at it when I can.
                        MMM-Dnews.js
                        The config was wrong…
                        Should be:
                               module: 'MMM-DNews',
                              position: 'bottom_bar',
                                rotateInterval: 20 * 1000
                          cowboysdude Module Developer @goprojojo
                          @goprojojo Yes I believe you are right!! OPPS…I’m fixing that right now!
                          @Johans
                          There NOW if your config.js is ‘nl’ then the translation file should work now :)
                          The other issue was my fault because on github I put ‘MMM-Dnews’… should be ‘MMM-DNews’… all fixed!
                          do a git pull to update :) Should work now.
                          PS you may have to adjust translation file… I used google translate .
                            @cowboysdude
                            As for the weather error…it does that every now and then and it’s the weather api …it fixes itself so no worry there :)
                              Johans @cowboysdude
                              @cowboysdude
                              works like a charm now.
                              Thank you very much for this and all the great work you are doing.
                              much appriciated !!
                              Johans
                                @Johans You’re welcome and I’m glad it works for you :)
                                • 3 / 3
