    MMM-Pnews
    47 Posts 9 Posters 42.7k Views 10 Watching
      DeanoAus
      Awesome, thanks! :D
      • L Offline
        lucallmon
        @cowboysdude Just installed this for the first time. Looks GREAT! However, it seems to take up a lot of space at the bottom bar; I am using a somewhat smaller screen. Is there a way I can limit the module to more of the center leaving space on both sides at the bottom for smaller modules? Also, I’d like to center the pic and text. It seems that it only aligns to the left. Any help would be greatly appreciated.
        • cowboysdudeC Offline
          cowboysdude Module Developer @lucallmon
          @lucallmon I’ll take a look at it later when I get home :) We’ll see what we can do!
            Johans
            hi Cowboysdude,
            I like your modules, nice work.
            I was wondering if you could modify or make a separate module for the dutch (belgian) newsfeeds.
            take a look at this side: http://feeds.nieuwsblad.be/nieuws/snelnieuws
            they provide for each headline, a pircture and short description.
            It would be nice if you could also incorparate this into the module.
            Johan
              cowboysdude Module Developer @Johans
              @Johans said in MMM-Pnews:
              hi Cowboysdude,
              Johan
              Johan, Thank you! I will certainly take a peek at that this evening!! :)
                @Johans
                Here you go:
                https://github.com/cowboysdude/MMM-DNews
                Mykle1M J G 3 Replies Last reply Reply Quote 1
                  @cowboysdude said in MMM-Pnews:
                  Here you go:
                  So, all I have to do is ask and you’ll make me a module?
                  You’re awesome! :^)
                    @Mykle1 said in MMM-Pnews:
                    Here you go:
                    You’re awesome! :^)
                    Sure, why not? LOL
                      Johans @cowboysdude
                      @cowboysdude
                      You are amazing.
                      Never thought it would be realized.
                      Had a hard day on the job today, but this makes my day.
                      I’m going to install now.
                      Johan
                      • G Offline
                        goprojojo @cowboysdude
                        @Johans
                        Here you go:
                        Isnt Johan looking for Dutch instead of Danish news? :P
                          Johans @cowboysdude
                          @cowboysdude
                          just installed, but got an error -
                          Load script: modules/MMM-Dnews//MMM-Dnews.js
                          MMM-Dnews.js Failed to load resource: the server responded with a status of 404 (Not Found)
                          loader.js:190 Error on loading script: modules/MMM-Dnews//MMM-Dnews.js
                          script.onerror @ loader.js:190
                          Would like to make a printscreen, but i can’t manage to do that on the raspberry.
                          (indeed Dutch news, not Danish - thanks goprojojo )
                          Edit: added screenprints
                          cowboysdudeC 2 Replies Last reply Reply Quote 0
                            Sorry about that… right now I just don’t have time. I am SUPER busy… I will look at it when I can.
                              MMM-Dnews.js
                              The config was wrong…
                              Should be:
                                     module: 'MMM-DNews',
                                    position: 'bottom_bar',
                                      rotateInterval: 20 * 1000
                                cowboysdude Module Developer @goprojojo
                                @goprojojo Yes I believe you are right!! OPPS…I’m fixing that right now!
                                @Johans
                                There NOW if your config.js is ‘nl’ then the translation file should work now :)
                                The other issue was my fault because on github I put ‘MMM-Dnews’… should be ‘MMM-DNews’… all fixed!
                                do a git pull to update :) Should work now.
                                PS you may have to adjust translation file… I used google translate .
                                  @cowboysdude
                                  As for the weather error…it does that every now and then and it’s the weather api …it fixes itself so no worry there :)
                                    Johans @cowboysdude
                                    @cowboysdude
                                    works like a charm now.
                                    Thank you very much for this and all the great work you are doing.
                                    much appriciated !!
                                    Johans
                                      @Johans You’re welcome and I’m glad it works for you :)
                                      • 2 / 3
