    MMM-Pnews
    47 Posts 9 Posters 44.5k Views 10 Watching
    • cowboysdudeC
      cowboysdude Module Developer @DeanoAus
      @DeanoAus If you can find a newsource that works with it sure.
      • Mykle1M
        @cowboysdude
        Dude, you’re unstoppable! Nice work. :thumbsup:
          DeanoAus
          Hey quick question, can’t seem to run two copies of this module at the same time. They both get the feed source from the first one?
            DeanoAus
            If you can’t, can you run multiple sources on the one module? I tried comma seperated, but that loaded neither of them.
            • cowboysdudeC
              No it wasn’t setup to run multiple instances. The mirror was setup for finite space so the majority of the modules haven’t been built to allow that :)
              I will look into the possibility of multiple sources but it will be a bit as this is my busiest time of year at work and I am swamped at the moment.
                DeanoAus
                Not a problem - what about multiple sources?
                • cowboysdudeC
                  @DeanoAus said in MMM-Pnews:
                  If you do this in the config.js ---->
                  //newsSource:,
                  It will return news from ALL sources that’s the best I can do at the moment.
                  I answered the multiple sources question above ;)
                  “I will look into the possibility of multiple sources but it will be a bit as this is my busiest time of year at work and I am swamped at the moment.”
                  • cowboysdudeC
                    There may be a quickie fix I can do if you tell me what you’re looking for…
                    business, entertainment, gaming, general, music, politics, science-and-nature, sport or technology.
                    D 1 Reply Last reply
                      DeanoAus
                      Ah, so you did! :D I read that as you’ll look into multiple instances. It’s late. ;)
                      All good my friend. I’ve somehow killed my MM install after an update.
                      • cowboysdudeC
                        @DeanoAus OH mannnnnnn I hate that… I just redid my bathroom mirror as I killed that one too … I feel your pain.
                        It’s late for you, I just woke up LOL So let me know if there is a specific category you’re looking for or just taking out the newsource will work for you because if you do that it will return ALL news. :)
                        Future implementation will be different languages: en, de, fr
                          DeanoAus @cowboysdude
                          @cowboysdude said in MMM-Pnews:
                          Was after one tech, one Australian news. And seeing as I can’t reply before 120 seconds… sigh… i’ll combine my replies.
                          pi@Pi:~/MagicMirror $ DISPLAY=:0 npm start
                          > magicmirror@2.1.1 start /home/pi/MagicMirror
                          > sh run-start.sh
                          run-start.sh: 4: run-start.sh: electron: not found
                          npm ERR! Linux 4.9.25-v7+
                          npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
                          npm ERR! node v6.10.2
                          npm ERR! npm  v3.10.10
                          npm ERR! file sh
                          npm ERR! code ELIFECYCLE
                          npm ERR! errno ENOENT
                          npm ERR! syscall spawn
                          npm ERR! magicmirror@2.1.1 start: `sh run-start.sh`
                          npm ERR! spawn ENOENT
                          I’ve tried updating, installing, you name it.
                          npm install electron
                          npm install
                          etc. :/
                          • cowboysdudeC
                            electron: not found
                            electron is not installed… i had an issue as well so I just reinstalled the mirror… that fixed the electron issues.
                              DeanoAus
                              Ugh, I think i found it. You need to do npm install as root…
                              Wait, nope!
                              pi@Pi:~/MagicMirror $ sudo npm install
                              > electron@1.6.6 postinstall /home/pi/MagicMirror/node_modules/electron
                              > node install.js
                              /home/pi/MagicMirror/node_modules/electron/install.js:47
                                throw err
                              Error: ENOENT: no such file or directory, lstat '/home/pi/MagicMirror/node_modules/electron/dist/resources'
                                  at Error (native)
                              npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install"
                              npm ERR! electron@1.6.6 postinstall: `node install.js`
                              npm ERR! Exit status 1
                              Ugh, I give up. Going to bed. Thanks for your help, i’ll fix in the morning. :)
                              • cowboysdudeC
                                Good Night :)
                                  DeanoAus
                                  Hey mate, I think I have a bug for you. :bug:
                                  In MMM-PNews.js you hard code in the sorting method (latest) for the source.
                                  this.url = "https://newsapi.org/v1/articles?source=" + this.config.newsSource + "&sortBy=Latest&apiKey=";
                                  Latest isn’t a valid sorting method for some sources.
                                  Example is the https://newsapi.org/abc-news-au-api
                                  If you hit that with the url they provide with Latest in there for sorting, it fails and gives
                                  {"status":"error","code":"sourceUnavailableSortedBy","message":"The news source you've selected (abc-news-au) isn't available sorted by latest"}
                                  But if you change Latest to Top in the url, works fine. :)
                                  This is causing some feeds to not work.
                                    DeanoAus
                                      DeanoAus
                                      Also, mine doesn’t seem to be updating the feed. (Sorry!)
                                      Seeing this in the log?
                                      fatal: unable to access ‘https://github.com/cowboysdude/MMM-PNews/’: GnuTLS recv error (-54): Error in the pull function.
                                      • cowboysdudeC
                                        sourceUnavailable
                                        I’ve updated the url so that should fix that…
                                        The other error is a git error … “: Error in the pull function”
                                          DeanoAus
                                          Awesome, thanks! :D
                                          • lucallmonL
                                            lucallmon
                                            @cowboysdude Just installed this for the first time. Looks GREAT! However, it seems to take up a lot of space at the bottom bar; I am using a somewhat smaller screen. Is there a way I can limit the module to more of the center leaving space on both sides at the bottom for smaller modules? Also, I’d like to center the pic and text. It seems that it only aligns to the left. Any help would be greatly appreciated.
                                            • 2 / 3
