    MMM-Pnews
    47 Posts 9 Posters 44.5k Views 10 Watching
    • cowboysdudeC
      cowboysdude Module Developer @DeanoAus
      @DeanoAus OH mannnnnnn I hate that… I just redid my bathroom mirror as I killed that one too … I feel your pain.
      It’s late for you, I just woke up LOL So let me know if there is a specific category you’re looking for or just taking out the newsource will work for you because if you do that it will return ALL news. :)
      Future implementation will be different languages: en, de, fr
        DeanoAus @cowboysdude
        @cowboysdude said in MMM-Pnews:
        There may be a quickie fix I can do if you tell me what you’re looking for…
        business, entertainment, gaming, general, music, politics, science-and-nature, sport or technology.
        Was after one tech, one Australian news. And seeing as I can’t reply before 120 seconds… sigh… i’ll combine my replies.
        pi@Pi:~/MagicMirror $ DISPLAY=:0 npm start
        > magicmirror@2.1.1 start /home/pi/MagicMirror
        > sh run-start.sh
        run-start.sh: 4: run-start.sh: electron: not found
        npm ERR! Linux 4.9.25-v7+
        npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
        npm ERR! node v6.10.2
        npm ERR! npm  v3.10.10
        npm ERR! file sh
        npm ERR! code ELIFECYCLE
        npm ERR! errno ENOENT
        npm ERR! syscall spawn
        npm ERR! magicmirror@2.1.1 start: `sh run-start.sh`
        npm ERR! spawn ENOENT
        I’ve tried updating, installing, you name it.
        npm install electron
        npm install
        etc. :/
        • cowboysdudeC
          @DeanoAus said in MMM-Pnews:
          electron: not found
          electron is not installed… i had an issue as well so I just reinstalled the mirror… that fixed the electron issues.
            DeanoAus
            Ugh, I think i found it. You need to do npm install as root…
            Wait, nope!
            pi@Pi:~/MagicMirror $ sudo npm install
            > electron@1.6.6 postinstall /home/pi/MagicMirror/node_modules/electron
            > node install.js
            /home/pi/MagicMirror/node_modules/electron/install.js:47
              throw err
            Error: ENOENT: no such file or directory, lstat '/home/pi/MagicMirror/node_modules/electron/dist/resources'
                at Error (native)
            npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install"
            npm ERR! electron@1.6.6 postinstall: `node install.js`
            npm ERR! Exit status 1
            Ugh, I give up. Going to bed. Thanks for your help, i’ll fix in the morning. :)
            • cowboysdudeC
              Good Night :)
                DeanoAus
                Hey mate, I think I have a bug for you. :bug:
                In MMM-PNews.js you hard code in the sorting method (latest) for the source.
                this.url = "https://newsapi.org/v1/articles?source=" + this.config.newsSource + "&sortBy=Latest&apiKey=";
                Latest isn’t a valid sorting method for some sources.
                Example is the https://newsapi.org/abc-news-au-api
                If you hit that with the url they provide with Latest in there for sorting, it fails and gives
                {"status":"error","code":"sourceUnavailableSortedBy","message":"The news source you've selected (abc-news-au) isn't available sorted by latest"}
                But if you change Latest to Top in the url, works fine. :)
                This is causing some feeds to not work.
                  DeanoAus
                    DeanoAus
                    Also, mine doesn’t seem to be updating the feed. (Sorry!)
                    Seeing this in the log?
                    fatal: unable to access ‘https://github.com/cowboysdude/MMM-PNews/’: GnuTLS recv error (-54): Error in the pull function.
                    • cowboysdudeC
                      sourceUnavailable
                      I’ve updated the url so that should fix that…
                      The other error is a git error … “: Error in the pull function”
                        DeanoAus
                        Awesome, thanks! :D
                        • lucallmonL
                          lucallmon
                          @cowboysdude Just installed this for the first time. Looks GREAT! However, it seems to take up a lot of space at the bottom bar; I am using a somewhat smaller screen. Is there a way I can limit the module to more of the center leaving space on both sides at the bottom for smaller modules? Also, I’d like to center the pic and text. It seems that it only aligns to the left. Any help would be greatly appreciated.
                          • cowboysdudeC
                            cowboysdude Module Developer @lucallmon
                            @lucallmon I’ll take a look at it later when I get home :) We’ll see what we can do!
                              Johans
                              hi Cowboysdude,
                              I like your modules, nice work.
                              I was wondering if you could modify or make a separate module for the dutch (belgian) newsfeeds.
                              take a look at this side: http://feeds.nieuwsblad.be/nieuws/snelnieuws
                              they provide for each headline, a pircture and short description.
                              It would be nice if you could also incorparate this into the module.
                              Johan
                              • cowboysdudeC
                                cowboysdude Module Developer @Johans
                                @Johans said in MMM-Pnews:
                                hi Cowboysdude,
                                Johan
                                Johan, Thank you! I will certainly take a peek at that this evening!! :)
                                • cowboysdudeC
                                  @Johans
                                  Here you go:
                                  https://github.com/cowboysdude/MMM-DNews
                                  Mykle1M J G 3 Replies Last reply
                                  • Mykle1M
                                    Here you go:
                                    So, all I have to do is ask and you’ll make me a module?
                                    You’re awesome! :^)
                                    • cowboysdudeC
                                      @Mykle1 said in MMM-Pnews:
                                      Here you go:
                                      You’re awesome! :^)
                                      Sure, why not? LOL
                                      J 1 Reply Last reply
                                        Johans @cowboysdude
                                        @cowboysdude
                                        You are amazing.
                                        Never thought it would be realized.
                                        Had a hard day on the job today, but this makes my day.
                                        I’m going to install now.
                                        Johan
                                        • G
                                          goprojojo @cowboysdude
                                          @Johans
                                          Here you go:
                                          Isnt Johan looking for Dutch instead of Danish news? :P
                                            Johans @cowboysdude
                                            @cowboysdude
                                            just installed, but got an error -
                                            Load script: modules/MMM-Dnews//MMM-Dnews.js
                                            MMM-Dnews.js Failed to load resource: the server responded with a status of 404 (Not Found)
                                            loader.js:190 Error on loading script: modules/MMM-Dnews//MMM-Dnews.js
                                            script.onerror @ loader.js:190
                                            Would like to make a printscreen, but i can’t manage to do that on the raspberry.
                                            (indeed Dutch news, not Danish - thanks goprojojo )
                                            Edit: added screenprints
                                            cowboysdudeC 2 Replies Last reply
                                            • 2 / 3
