    MMM-Pnews
    47 Posts 9 Posters 44.5k Views 10 Watching
    • cowboysdudeC
      cowboysdude Module Developer @open_book
      @open_book Thank you!! Good catch!! :) Updated
        DeanoAus
        Can this be used with custom RSS feeds, rather than the repository?
        • cowboysdudeC
          cowboysdude Module Developer @DeanoAus
          @DeanoAus If you can find a newsource that works with it sure.
          • Mykle1M
            @cowboysdude
            Dude, you’re unstoppable! Nice work. :thumbsup:
              DeanoAus
              Hey quick question, can’t seem to run two copies of this module at the same time. They both get the feed source from the first one?
                DeanoAus
                If you can’t, can you run multiple sources on the one module? I tried comma seperated, but that loaded neither of them.
                • cowboysdudeC
                  No it wasn’t setup to run multiple instances. The mirror was setup for finite space so the majority of the modules haven’t been built to allow that :)
                  I will look into the possibility of multiple sources but it will be a bit as this is my busiest time of year at work and I am swamped at the moment.
                    DeanoAus
                    Not a problem - what about multiple sources?
                    • cowboysdudeC
                      @DeanoAus said in MMM-Pnews:
                      If you do this in the config.js ---->
                      //newsSource:,
                      It will return news from ALL sources that’s the best I can do at the moment.
                      I answered the multiple sources question above ;)
                      “I will look into the possibility of multiple sources but it will be a bit as this is my busiest time of year at work and I am swamped at the moment.”
                      • cowboysdudeC
                        There may be a quickie fix I can do if you tell me what you’re looking for…
                        business, entertainment, gaming, general, music, politics, science-and-nature, sport or technology.
                        D 1 Reply Last reply
                          DeanoAus
                          Ah, so you did! :D I read that as you’ll look into multiple instances. It’s late. ;)
                          All good my friend. I’ve somehow killed my MM install after an update.
                          • cowboysdudeC
                            @DeanoAus OH mannnnnnn I hate that… I just redid my bathroom mirror as I killed that one too … I feel your pain.
                            It’s late for you, I just woke up LOL So let me know if there is a specific category you’re looking for or just taking out the newsource will work for you because if you do that it will return ALL news. :)
                            Future implementation will be different languages: en, de, fr
                              DeanoAus @cowboysdude
                              @cowboysdude said in MMM-Pnews:
                              Was after one tech, one Australian news. And seeing as I can’t reply before 120 seconds… sigh… i’ll combine my replies.
                              pi@Pi:~/MagicMirror $ DISPLAY=:0 npm start
                              > magicmirror@2.1.1 start /home/pi/MagicMirror
                              > sh run-start.sh
                              run-start.sh: 4: run-start.sh: electron: not found
                              npm ERR! Linux 4.9.25-v7+
                              npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
                              npm ERR! node v6.10.2
                              npm ERR! npm  v3.10.10
                              npm ERR! file sh
                              npm ERR! code ELIFECYCLE
                              npm ERR! errno ENOENT
                              npm ERR! syscall spawn
                              npm ERR! magicmirror@2.1.1 start: `sh run-start.sh`
                              npm ERR! spawn ENOENT
                              I’ve tried updating, installing, you name it.
                              npm install electron
                              npm install
                              etc. :/
                              • cowboysdudeC
                                electron: not found
                                electron is not installed… i had an issue as well so I just reinstalled the mirror… that fixed the electron issues.
                                  DeanoAus
                                  Ugh, I think i found it. You need to do npm install as root…
                                  Wait, nope!
                                  pi@Pi:~/MagicMirror $ sudo npm install
                                  > electron@1.6.6 postinstall /home/pi/MagicMirror/node_modules/electron
                                  > node install.js
                                  /home/pi/MagicMirror/node_modules/electron/install.js:47
                                    throw err
                                  Error: ENOENT: no such file or directory, lstat '/home/pi/MagicMirror/node_modules/electron/dist/resources'
                                      at Error (native)
                                  npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install"
                                  npm ERR! electron@1.6.6 postinstall: `node install.js`
                                  npm ERR! Exit status 1
                                  Ugh, I give up. Going to bed. Thanks for your help, i’ll fix in the morning. :)
                                  • cowboysdudeC
                                    Good Night :)
                                      DeanoAus
                                      Hey mate, I think I have a bug for you. :bug:
                                      In MMM-PNews.js you hard code in the sorting method (latest) for the source.
                                      this.url = "https://newsapi.org/v1/articles?source=" + this.config.newsSource + "&sortBy=Latest&apiKey=";
                                      Latest isn’t a valid sorting method for some sources.
                                      Example is the https://newsapi.org/abc-news-au-api
                                      If you hit that with the url they provide with Latest in there for sorting, it fails and gives
                                      {"status":"error","code":"sourceUnavailableSortedBy","message":"The news source you've selected (abc-news-au) isn't available sorted by latest"}
                                      But if you change Latest to Top in the url, works fine. :)
                                      This is causing some feeds to not work.
                                        DeanoAus
                                          DeanoAus
                                          Also, mine doesn’t seem to be updating the feed. (Sorry!)
                                          Seeing this in the log?
                                          fatal: unable to access ‘https://github.com/cowboysdude/MMM-PNews/’: GnuTLS recv error (-54): Error in the pull function.
                                          • cowboysdudeC
                                            sourceUnavailable
                                            I’ve updated the url so that should fix that…
                                            The other error is a git error … “: Error in the pull function”
