    MMM-Pnews
    47 Posts 9 Posters 44.1k Views 10 Watching
    • cowboysdudeC
      cowboysdude Module Developer @DeanoAus
      @DeanoAus said in MMM-Pnews:
      Not a problem - what about multiple sources?
      If you do this in the config.js ---->
      //newsSource:,
      It will return news from ALL sources that’s the best I can do at the moment.
      I answered the multiple sources question above ;)
      “I will look into the possibility of multiple sources but it will be a bit as this is my busiest time of year at work and I am swamped at the moment.”
      • cowboysdudeC
        There may be a quickie fix I can do if you tell me what you’re looking for…
        business, entertainment, gaming, general, music, politics, science-and-nature, sport or technology.
          DeanoAus
          Ah, so you did! :D I read that as you’ll look into multiple instances. It’s late. ;)
          All good my friend. I’ve somehow killed my MM install after an update.
          • cowboysdudeC
            @DeanoAus OH mannnnnnn I hate that… I just redid my bathroom mirror as I killed that one too … I feel your pain.
            It’s late for you, I just woke up LOL So let me know if there is a specific category you’re looking for or just taking out the newsource will work for you because if you do that it will return ALL news. :)
            Future implementation will be different languages: en, de, fr
              DeanoAus @cowboysdude
              @cowboysdude said in MMM-Pnews:
              Was after one tech, one Australian news. And seeing as I can’t reply before 120 seconds… sigh… i’ll combine my replies.
              pi@Pi:~/MagicMirror $ DISPLAY=:0 npm start
              > magicmirror@2.1.1 start /home/pi/MagicMirror
              > sh run-start.sh
              run-start.sh: 4: run-start.sh: electron: not found
              npm ERR! Linux 4.9.25-v7+
              npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
              npm ERR! node v6.10.2
              npm ERR! npm  v3.10.10
              npm ERR! file sh
              npm ERR! code ELIFECYCLE
              npm ERR! errno ENOENT
              npm ERR! syscall spawn
              npm ERR! magicmirror@2.1.1 start: `sh run-start.sh`
              npm ERR! spawn ENOENT
              I’ve tried updating, installing, you name it.
              npm install electron
              npm install
              etc. :/
              • cowboysdudeC
                electron: not found
                electron is not installed… i had an issue as well so I just reinstalled the mirror… that fixed the electron issues.
                  DeanoAus
                  Ugh, I think i found it. You need to do npm install as root…
                  Wait, nope!
                  pi@Pi:~/MagicMirror $ sudo npm install
                  > electron@1.6.6 postinstall /home/pi/MagicMirror/node_modules/electron
                  > node install.js
                  /home/pi/MagicMirror/node_modules/electron/install.js:47
                    throw err
                  Error: ENOENT: no such file or directory, lstat '/home/pi/MagicMirror/node_modules/electron/dist/resources'
                      at Error (native)
                  npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install"
                  npm ERR! electron@1.6.6 postinstall: `node install.js`
                  npm ERR! Exit status 1
                  Ugh, I give up. Going to bed. Thanks for your help, i’ll fix in the morning. :)
                  • cowboysdudeC
                    Good Night :)
                      DeanoAus
                      Hey mate, I think I have a bug for you. :bug:
                      In MMM-PNews.js you hard code in the sorting method (latest) for the source.
                      this.url = "https://newsapi.org/v1/articles?source=" + this.config.newsSource + "&sortBy=Latest&apiKey=";
                      Latest isn’t a valid sorting method for some sources.
                      Example is the https://newsapi.org/abc-news-au-api
                      If you hit that with the url they provide with Latest in there for sorting, it fails and gives
                      {"status":"error","code":"sourceUnavailableSortedBy","message":"The news source you've selected (abc-news-au) isn't available sorted by latest"}
                      But if you change Latest to Top in the url, works fine. :)
                      This is causing some feeds to not work.
                        DeanoAus
                          DeanoAus
                          Also, mine doesn’t seem to be updating the feed. (Sorry!)
                          Seeing this in the log?
                          fatal: unable to access ‘https://github.com/cowboysdude/MMM-PNews/’: GnuTLS recv error (-54): Error in the pull function.
                          • cowboysdudeC
                            sourceUnavailable
                            I’ve updated the url so that should fix that…
                            The other error is a git error … “: Error in the pull function”
                              DeanoAus
                              Awesome, thanks! :D
                              • L
                                lucallmon
                                @cowboysdude Just installed this for the first time. Looks GREAT! However, it seems to take up a lot of space at the bottom bar; I am using a somewhat smaller screen. Is there a way I can limit the module to more of the center leaving space on both sides at the bottom for smaller modules? Also, I’d like to center the pic and text. It seems that it only aligns to the left. Any help would be greatly appreciated.
                                • cowboysdudeC
                                  cowboysdude Module Developer @lucallmon
                                  @lucallmon I’ll take a look at it later when I get home :) We’ll see what we can do!
                                    Johans
                                    hi Cowboysdude,
                                    I like your modules, nice work.
                                    I was wondering if you could modify or make a separate module for the dutch (belgian) newsfeeds.
                                    take a look at this side: http://feeds.nieuwsblad.be/nieuws/snelnieuws
                                    they provide for each headline, a pircture and short description.
                                    It would be nice if you could also incorparate this into the module.
                                    Johan
                                    • cowboysdudeC
                                      cowboysdude Module Developer @Johans
                                      @Johans said in MMM-Pnews:
                                      hi Cowboysdude,
                                      Johan
                                      Johan, Thank you! I will certainly take a peek at that this evening!! :)
                                      • cowboysdudeC
                                        @Johans
                                        Here you go:
                                        https://github.com/cowboysdude/MMM-DNews
                                        Mykle1M J G 3 Replies Last reply Reply Quote 1
                                        • Mykle1M
                                          Here you go:
                                          So, all I have to do is ask and you’ll make me a module?
                                          You’re awesome! :^)
                                          • cowboysdudeC
                                            @Mykle1 said in MMM-Pnews:
                                            Here you go:
                                            You’re awesome! :^)
                                            Sure, why not? LOL
                                            • 2 / 3
