    MMM-Pnews
    47 Posts 9 Posters 44.5k Views 10 Watching
    • lucallmonL
      lucallmon
      @cowboysdude Just installed this for the first time. Looks GREAT! However, it seems to take up a lot of space at the bottom bar; I am using a somewhat smaller screen. Is there a way I can limit the module to more of the center leaving space on both sides at the bottom for smaller modules? Also, I’d like to center the pic and text. It seems that it only aligns to the left. Any help would be greatly appreciated.
      • cowboysdudeC
        cowboysdude Module Developer @lucallmon
        @lucallmon I’ll take a look at it later when I get home :) We’ll see what we can do!
          Johans
          hi Cowboysdude,
          I like your modules, nice work.
          I was wondering if you could modify or make a separate module for the dutch (belgian) newsfeeds.
          take a look at this side: http://feeds.nieuwsblad.be/nieuws/snelnieuws
          they provide for each headline, a pircture and short description.
          It would be nice if you could also incorparate this into the module.
          Johan
          • cowboysdudeC
            cowboysdude Module Developer @Johans
            @Johans said in MMM-Pnews:
            hi Cowboysdude,
            Johan
            Johan, Thank you! I will certainly take a peek at that this evening!! :)
            • cowboysdudeC
              @Johans
              Here you go:
              https://github.com/cowboysdude/MMM-DNews
              Mykle1M J G 3 Replies Last reply
              • Mykle1M
                @cowboysdude said in MMM-Pnews:
                Here you go:
                So, all I have to do is ask and you’ll make me a module?
                You’re awesome! :^)
                • cowboysdudeC
                  @Mykle1 said in MMM-Pnews:
                  Here you go:
                  You’re awesome! :^)
                  Sure, why not? LOL
                  J 1 Reply Last reply
                    Johans @cowboysdude
                    @cowboysdude
                    You are amazing.
                    Never thought it would be realized.
                    Had a hard day on the job today, but this makes my day.
                    I’m going to install now.
                    Johan
                    • G
                      goprojojo @cowboysdude
                      @Johans
                      Here you go:
                      Isnt Johan looking for Dutch instead of Danish news? :P
                        Johans @cowboysdude
                        @cowboysdude
                        just installed, but got an error -
                        Load script: modules/MMM-Dnews//MMM-Dnews.js
                        MMM-Dnews.js Failed to load resource: the server responded with a status of 404 (Not Found)
                        loader.js:190 Error on loading script: modules/MMM-Dnews//MMM-Dnews.js
                        script.onerror @ loader.js:190
                        Would like to make a printscreen, but i can’t manage to do that on the raspberry.
                        (indeed Dutch news, not Danish - thanks goprojojo )
                        Edit: added screenprints
                        cowboysdudeC 2 Replies Last reply
                        • cowboysdudeC
                          Sorry about that… right now I just don’t have time. I am SUPER busy… I will look at it when I can.
                          • cowboysdudeC
                            MMM-Dnews.js
                            The config was wrong…
                            Should be:
                                   module: 'MMM-DNews',
                                  position: 'bottom_bar',
                                    rotateInterval: 20 * 1000
                            • cowboysdudeC
                              cowboysdude Module Developer @goprojojo
                              @goprojojo Yes I believe you are right!! OPPS…I’m fixing that right now!
                              @Johans
                              There NOW if your config.js is ‘nl’ then the translation file should work now :)
                              The other issue was my fault because on github I put ‘MMM-Dnews’… should be ‘MMM-DNews’… all fixed!
                              do a git pull to update :) Should work now.
                              PS you may have to adjust translation file… I used google translate .
                              • cowboysdudeC
                                @cowboysdude
                                As for the weather error…it does that every now and then and it’s the weather api …it fixes itself so no worry there :)
                                  Johans @cowboysdude
                                  @cowboysdude
                                  works like a charm now.
                                  Thank you very much for this and all the great work you are doing.
                                  much appriciated !!
                                  Johans
                                  • cowboysdudeC
                                    @Johans You’re welcome and I’m glad it works for you :)
                                    • 3 / 3
