    MMM-Pnews
    47 Posts 9 Posters 44.5k Views 10 Watching
    • Mykle1M
      @cowboysdude said in MMM-Pnews:
      Here you go:
      So, all I have to do is ask and you’ll make me a module?
      You’re awesome! :^)
      • cowboysdudeC
        @Mykle1 said in MMM-Pnews:
        Here you go:
        You’re awesome! :^)
        Sure, why not? LOL
        J 1 Reply Last reply
          Johans @cowboysdude
          @cowboysdude
          You are amazing.
          Never thought it would be realized.
          Had a hard day on the job today, but this makes my day.
          I’m going to install now.
          Johan
          • G
            goprojojo @cowboysdude
            @Johans
            Here you go:
            https://github.com/cowboysdude/MMM-DNews
            Isnt Johan looking for Dutch instead of Danish news? :P
              Johans @cowboysdude
              @cowboysdude
              just installed, but got an error -
              Load script: modules/MMM-Dnews//MMM-Dnews.js
              MMM-Dnews.js Failed to load resource: the server responded with a status of 404 (Not Found)
              loader.js:190 Error on loading script: modules/MMM-Dnews//MMM-Dnews.js
              script.onerror @ loader.js:190
              Would like to make a printscreen, but i can’t manage to do that on the raspberry.
              (indeed Dutch news, not Danish - thanks goprojojo )
              Edit: added screenprints
              cowboysdudeC 2 Replies Last reply
              • cowboysdudeC
                Sorry about that… right now I just don’t have time. I am SUPER busy… I will look at it when I can.
                • cowboysdudeC
                  cowboysdude Module Developer @Johans
                  @Johans said in MMM-Pnews:
                  MMM-Dnews.js
                  The config was wrong…
                  Should be:
                         module: 'MMM-DNews',
                        position: 'bottom_bar',
                          rotateInterval: 20 * 1000
                  • cowboysdudeC
                    cowboysdude Module Developer @goprojojo
                    @goprojojo Yes I believe you are right!! OPPS…I’m fixing that right now!
                    @Johans
                    There NOW if your config.js is ‘nl’ then the translation file should work now :)
                    The other issue was my fault because on github I put ‘MMM-Dnews’… should be ‘MMM-DNews’… all fixed!
                    do a git pull to update :) Should work now.
                    PS you may have to adjust translation file… I used google translate .
                    • cowboysdudeC
                      @cowboysdude
                      As for the weather error…it does that every now and then and it’s the weather api …it fixes itself so no worry there :)
                        Johans @cowboysdude
                        @cowboysdude
                        works like a charm now.
                        Thank you very much for this and all the great work you are doing.
                        much appriciated !!
                        Johans
                        • cowboysdudeC
                          @Johans You’re welcome and I’m glad it works for you :)
                          • 3 / 3
