    After update to Mirror to 2.1.3 - no working Whitlist
    33 Posts 18 Posters 32.3k Views 18 Watching
    • Sandy2503S Offline
      Sandy2503
      Hi !
      At 2pm i have updated my mirror to Version 2.1.3.
      but now i can`t access the Mirror from my Home PC.
      /*************** AUTO GENERATED BY REMOTE CONTROL MODULE ***************/
      var config =
              port: 8081,
              electronOptions: {
              ipWhitelist: [
                      "127.0.0.1",
                      "::ffff:127.0.0.1",
                      "::1",
                      "192.168.178.20/24"
              language: "de",
                              module: "alert",
      In Mirror Version 2.1.2 it works very well.
      Is the ipWhitelist wrong ?
      I`d like to get access from my whole network after the router like 192.168.178.x --> End
      Sandy2503
      randomnoiseR 1 Reply Last reply Reply Quote 0
        d3r
        Had the same issue. added
        address:"0.0.0.0",
        to the config and it’s working again.
        https://github.com/MichMich/MagicMirror/issues/1036
        randomnoiseR 1 Reply Last reply Reply Quote 2
        • randomnoiseR Offline
          randomnoise @Sandy2503
          @Sandy2503
          Me too… my old WL settings don’t work & also using a blank whitelist (which the update description says should allow all hosts) also doesn’t work.
          Should the font also look different? I realise the Roboto font was ‘moved’ but should it still apply (or do I have to define it in CSS?)
          • G Offline
            gshimself
            Yea, same here
            • H Offline
              Hein-Jan
              Same problem here. ipWhitelist worked in 2.1.2. 2.1.3. no more.
              VNC works, Putty works. MMM-Remote-Control cannot be accessed.
              Hein-Jan
              • MichMichM Offline
                MichMich
                Hmm … that doesn’t sound good. Could one of you open an issue on https://github.com/MichMich/MagicMirror/issues?
                Make sure you fill in ALL te questions in the issue template.
                Thanks!
                  d3r
                  address:"0.0.0.0",
                  • MichMichM Offline
                    MichMich
                    Thanks d3r!
                      roramirez Core Contributors
                      That happens because the release 2.1.3 was introduced a new change to make more secure the MagicMirror, to prevent open all interfaces to world. So, now from 2.1.3 the default values for address is localhost instead of 0.0.0.0… so …be careful to set this value.
                      Sandy2503S F 2 Replies Last reply Reply Quote 0
                        Sandy2503 @roramirez
                        @roramirez - and how can i now access to my mirror from my homenetwork ?
                        What do i have to do ???
                        Sandy
                          randomnoise @d3r
                          @d3r said in After update to Mirror to 2.1.3 - no working Whitlist:
                          address:“0.0.0.0”,
                          Thanks d3r, this was indeed the solution.
                          F 1 Reply Last reply Reply Quote 1
                            roramirez Core Contributors @Sandy2503
                            @Sandy2503 said in After update to Mirror to 2.1.3 - no working Whitlist:
                            Set the IP address of your MagicMirror there.
                            • K Offline
                              knubbl
                              • F Offline
                                fox @randomnoise
                                @randomnoise said in After update to Mirror to 2.1.3 - no working Whitlist:
                                address:“0.0.0.0”,
                                And how is the syntax?
                                Something like this?
                                var config =
                                        electronOptions: {
                                        ipWhitelist: [
                                                "127.0.0.1",
                                                "0.0.0.0",
                                                "::ffff:127.0.0.1",
                                                "::1",
                                                "::ffff:192.168.188.42",
                                                "192.168.188.1/24",
                                                "::ffff:192.168.188.50"
                                that does not work for me, before the update my MM was working really fine.
                                Also MMM-iFrameReload is not working anymore :(
                                Issues With MMM-WatchDog known?
                                https://forum.magicmirror.builders/post/29827
                                Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
                                  randomnoise @fox
                                  @fox this doesn’t go within the whitelist section it has to go after the comma at the end of your whitelist section.
                                  It is its own config parameter.
                                  address:“0.0.0.0”,
                                  • F Offline
                                    fox @roramirez
                                    @randomnoise thank you for clarifying.
                                    @roramirez said in After update to Mirror to 2.1.3 - no working Whitlist:
                                    i tried your fix: https://github.com/MichMich/MagicMirror/issues/1036#issuecomment-333243474
                                    now MM crashed. With “pm2 logs mm” only weird errors appear :(
                                    Was that thing with the developer checkout really intended to remain a stable MM?
                                      Sandy2503
                                      I change my config.js in:
                                      var config =
                                              port: 8081,
                                              address:"0.0.0.0",
                                              electronOptions: {
                                              ipWhitelist: [
                                                      "127.0.0.1",
                                                      "::ffff:127.0.0.1",
                                                      "::1",
                                                      "192.168.178.20/24"
                                              language: "de",
                                      and now it works again.
                                      I have now access to MMM-Remote-Control from my HomePC again …
                                      Sandy2503
                                      • F Offline
                                        fox
                                        @Sandy2503 ok nice to know. My problem, that - as i wrote - that with the “developer checkout” from github my MagicMirror is now broken :(
                                        • H Offline
                                          Hein-Jan
                                          Adding
                                          address: “0.0.0.0”,
                                          to the config.js also did the trick for me.
                                          Thanks!
                                          • K Offline
                                            knubbl
                                            As soon i put “0.0.0.0” to my config (see bellow with empty adress"") i get a black screen on start MM
                                            var config = {
                                            port: 8080,
                                            address:“”,
                                            language: “de”,
                                            timeFormat: 24,
                                            units: “metric”,
                                            Any ideas?
                                              shotput2017 @knubbl
                                              hi!
                                              maybe wrong config.js ??
                                              here is my working code:
                                              var config =
                                              address: “0.0.0.0”,
                                              electronOptions: {
                                              ipWhitelist: [
                                              	"10.0.0.1/24",
                                              	"::ffff:10.0.0.1/120",
                                              	"127.0.0.1",
                                              	"::ffff:127.0.0.1",
                                              	"::1"
                                              and so on…
                                              greets
                                              shotput2017
