    After update to Mirror to 2.1.3 - no working Whitlist
    33 Posts 18 Posters 32.3k Views 18 Watching
      roramirez Core Contributors
      That happens because the release 2.1.3 was introduced a new change to make more secure the MagicMirror, to prevent open all interfaces to world. So, now from 2.1.3 the default values for address is localhost instead of 0.0.0.0… so …be careful to set this value.
      Sandy2503S F 2 Replies Last reply Reply Quote 0
      • Sandy2503S Offline
        Sandy2503 @roramirez
        @roramirez - and how can i now access to my mirror from my homenetwork ?
        What do i have to do ???
        Sandy
        • randomnoiseR Offline
          randomnoise @d3r
          @d3r said in After update to Mirror to 2.1.3 - no working Whitlist:
          address:“0.0.0.0”,
          Thanks d3r, this was indeed the solution.
          F 1 Reply Last reply Reply Quote 1
            roramirez Core Contributors @Sandy2503
            @Sandy2503 said in After update to Mirror to 2.1.3 - no working Whitlist:
            Set the IP address of your MagicMirror there.
            • K Offline
              knubbl
              • F Offline
                fox @randomnoise
                @randomnoise said in After update to Mirror to 2.1.3 - no working Whitlist:
                address:“0.0.0.0”,
                And how is the syntax?
                Something like this?
                var config =
                        electronOptions: {
                        ipWhitelist: [
                                "127.0.0.1",
                                "0.0.0.0",
                                "::ffff:127.0.0.1",
                                "::1",
                                "::ffff:192.168.188.42",
                                "192.168.188.1/24",
                                "::ffff:192.168.188.50"
                that does not work for me, before the update my MM was working really fine.
                Also MMM-iFrameReload is not working anymore :(
                Issues With MMM-WatchDog known?
                https://forum.magicmirror.builders/post/29827
                Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
                randomnoiseR 1 Reply Last reply Reply Quote 0
                  randomnoise @fox
                  @fox this doesn’t go within the whitelist section it has to go after the comma at the end of your whitelist section.
                  It is its own config parameter.
                  address:“0.0.0.0”,
                  • F Offline
                    fox @roramirez
                    @randomnoise thank you for clarifying.
                    @roramirez said in After update to Mirror to 2.1.3 - no working Whitlist:
                    i tried your fix: https://github.com/MichMich/MagicMirror/issues/1036#issuecomment-333243474
                    now MM crashed. With “pm2 logs mm” only weird errors appear :(
                    Was that thing with the developer checkout really intended to remain a stable MM?
                      Sandy2503
                      I change my config.js in:
                      /*************** AUTO GENERATED BY REMOTE CONTROL MODULE ***************/
                      var config =
                              port: 8081,
                              address:"0.0.0.0",
                              electronOptions: {
                              ipWhitelist: [
                                      "127.0.0.1",
                                      "::ffff:127.0.0.1",
                                      "::1",
                                      "192.168.178.20/24"
                              language: "de",
                      and now it works again.
                      I have now access to MMM-Remote-Control from my HomePC again …
                      Sandy2503
                      • F Offline
                        fox
                        @Sandy2503 ok nice to know. My problem, that - as i wrote - that with the “developer checkout” from github my MagicMirror is now broken :(
                        • H Offline
                          Hein-Jan
                          Adding
                          address: “0.0.0.0”,
                          to the config.js also did the trick for me.
                          Thanks!
                          • K Offline
                            knubbl
                            As soon i put “0.0.0.0” to my config (see bellow with empty adress"") i get a black screen on start MM
                            var config = {
                            port: 8080,
                            address:“”,
                            language: “de”,
                            timeFormat: 24,
                            units: “metric”,
                            Any ideas?
                              shotput2017 @knubbl
                              hi!
                              maybe wrong config.js ??
                              here is my working code:
                              var config =
                              address: “0.0.0.0”,
                              electronOptions: {
                              ipWhitelist: [
                              	"10.0.0.1/24",
                              	"::ffff:10.0.0.1/120",
                              	"127.0.0.1",
                              	"::ffff:127.0.0.1",
                              	"::1"
                              and so on…
                              greets
                              shotput2017
                                cben0ist
                                is this an acceptable configuration ?
                                address:"0.0.0.0",
                                or is it better specifying the actual server ip here ?
                                • NiggichN Offline
                                  Niggich
                                  I put my config like this:
                                  	port: 1103,
                                  	address: '0.0.0.0',
                                  	electronOptions: {
                                  	ipWhitelist: [
                                  		"127.0.0.1",
                                  		"::ffff:127.0.0.1",
                                  		"::1",
                                  		"::ffff:192.168.113.60",
                                  		"::ffff:192.168.113.22",
                                  		"::ffff:192.168.113.97",
                                  		"::ffff:192.168.113.29",
                                  		"::ffff:192.168.113.103",
                                  		"::ffff:192.168.113.66"
                                  The Remote-Control says “This device is not allowed to acces your mirror”. The IP-Adresses are correct.
                                  • F Offline
                                    FreddeHamm
                                    i have the same problem
                                    i already set “adress” to :“0.0.0.0” and edited the ipwhitelist to
                                    ipWhitelist: [“::fff:0.0.0.0/1”, “::fff:0.8.0.0/1”, “::fff:128.0.0.0/2”, “::fff:192.0.0.0/3”, “::fff:224.0.0.0/4”, “127.0.0.1”, “::ffff:127.0.0.1”, “::1”]
                                    but still i get no access.
                                    Btw. its a raspberry pi zero with serveronly
                                      Jopyth Moderator @Niggich
                                      @Niggich For my setup (raspberry pi 2) something changed after the update, but when I changed my IP addresses to the IPv4 notation (remove ::ffff: from your addresses) it worked again. Which format do the blocked addresses have in your logs (see below)?
                                      @FreddeHamm Are you sure those CIDR numbers are correct?
                                      When in doubt, check the output or logs (pm2 logs MagicMirror or pm2 logs mm if you used the old auto starting guide), there should be a line telling you which IP address was received. Also there are a calculators which transform your IP range to the CIDR notation.
                                      • N Offline
                                        Nick
                                        Same here, tried addres 0.0.0.0 and various things in the Whitelist.
                                        A ping gives “destination unreachable”… SSH also doesn’t work.
                                        Can someone please suggest ways to troubleshoot?
                                          Mykle1 Project Sponsor Module Developer @Nick
                                          @Nick said in After update to Mirror to 2.1.3 - no working Whitlist:
                                          Have you tried OUTSIDE your Whitelist, as such:
                                          var config = {
                                          	port: 8080,
                                                  address: "0.0.0.0",
                                          	ipWhitelist: [], // Set [] to allow all IP addresses.
                                          • N Offline
                                            Nick
                                            Thx @Mykle1, indeed I have. See the beginning of my (working) config file below.
                                            What is suspicious to me is that not even a Ping works to that IP, even though I’ve checked it by printing it on the screen of the MM and in the router.
                                            Also, before my Whitelist was a long list of IPs, now I’ve tried the [] option but to no avail…
                                            var config =
                                                    address: "0.0.0.0",
                                                    electronOptions: {
                                                    ipWhitelist: [
        module: "alert",
        module: "updatenotification",
        position: "top_bar",
        module: "MMM-Remote-Control",
        position: "middle_center",
