    After update to Mirror to 2.1.3 - no working Whitlist
    33 Posts 18 Posters 33.3k Views 18 Watching
    • H
      Hein-Jan
      Same problem here. ipWhitelist worked in 2.1.2. 2.1.3. no more.
      VNC works, Putty works. MMM-Remote-Control cannot be accessed.
      Hein-Jan
      • MichMichM
        MichMich
        Hmm … that doesn’t sound good. Could one of you open an issue on https://github.com/MichMich/MagicMirror/issues?
        Make sure you fill in ALL te questions in the issue template.
        Thanks!
          d3r
          Had the same issue. added
          address:"0.0.0.0",
          to the config and it’s working again.
          https://github.com/MichMich/MagicMirror/issues/1036
          randomnoiseR 1 Reply Last reply
          Reply Quote 2
          • MichMichM
            MichMich
            Thanks d3r!
              roramirez Core Contributors
              That happens because the release 2.1.3 was introduced a new change to make more secure the MagicMirror, to prevent open all interfaces to world. So, now from 2.1.3 the default values for address is localhost instead of 0.0.0.0… so …be careful to set this value.
              Sandy2503S F 2 Replies Last reply
              • Sandy2503S
                Sandy2503 @roramirez
                @roramirez - and how can i now access to my mirror from my homenetwork ?
                What do i have to do ???
                Sandy
                • randomnoiseR
                  randomnoise @d3r
                  @d3r said in After update to Mirror to 2.1.3 - no working Whitlist:
                  address:“0.0.0.0”,
                  Thanks d3r, this was indeed the solution.
                  F 1 Reply Last reply
                    roramirez Core Contributors @Sandy2503
                    @Sandy2503 said in After update to Mirror to 2.1.3 - no working Whitlist:
                    Set the IP address of your MagicMirror there.
                    • K
                      knubbl
                      • F
                        fox @randomnoise
                        @randomnoise said in After update to Mirror to 2.1.3 - no working Whitlist:
                        address:“0.0.0.0”,
                        And how is the syntax?
                        Something like this?
                        var config =
                                electronOptions: {
                                ipWhitelist: [
                                        "127.0.0.1",
                                        "0.0.0.0",
                                        "::ffff:127.0.0.1",
                                        "::1",
                                        "::ffff:192.168.188.42",
                                        "192.168.188.1/24",
                                        "::ffff:192.168.188.50"
                        that does not work for me, before the update my MM was working really fine.
                        Also MMM-iFrameReload is not working anymore :(
                        Issues With MMM-WatchDog known?
                        https://forum.magicmirror.builders/post/29827
                        Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
                        • randomnoiseR
                          randomnoise @fox
                          @fox this doesn’t go within the whitelist section it has to go after the comma at the end of your whitelist section.
                          It is its own config parameter.
                          address:“0.0.0.0”,
                          • F
                            fox @roramirez
                            @randomnoise thank you for clarifying.
                            @roramirez said in After update to Mirror to 2.1.3 - no working Whitlist:
                            i tried your fix: https://github.com/MichMich/MagicMirror/issues/1036#issuecomment-333243474
                            now MM crashed. With “pm2 logs mm” only weird errors appear :(
                            Was that thing with the developer checkout really intended to remain a stable MM?
                            • Sandy2503S
                              Sandy2503
                              I change my config.js in:
                              /*************** AUTO GENERATED BY REMOTE CONTROL MODULE ***************/
                              var config =
                                      port: 8081,
                                      address:"0.0.0.0",
                                      electronOptions: {
                                      ipWhitelist: [
                                              "127.0.0.1",
                                              "::ffff:127.0.0.1",
                                              "::1",
                                              "192.168.178.20/24"
                                      language: "de",
                              and now it works again.
                              I have now access to MMM-Remote-Control from my HomePC again …
                              Sandy2503
                              Reply Quote 2
                              • F
                                fox
                                @Sandy2503 ok nice to know. My problem, that - as i wrote - that with the “developer checkout” from github my MagicMirror is now broken :(
                                • H
                                  Hein-Jan
                                  Adding
                                  address: “0.0.0.0”,
                                  to the config.js also did the trick for me.
                                  Thanks!
                                  • K
                                    knubbl
                                    As soon i put “0.0.0.0” to my config (see bellow with empty adress"") i get a black screen on start MM
                                    var config = {
                                    port: 8080,
                                    address:“”,
                                    language: “de”,
                                    timeFormat: 24,
                                    units: “metric”,
                                    Any ideas?
                                      shotput2017 @knubbl
                                      hi!
                                      maybe wrong config.js ??
                                      here is my working code:
                                      var config =
                                      address: “0.0.0.0”,
                                      electronOptions: {
                                      ipWhitelist: [
                                      	"10.0.0.1/24",
                                      	"::ffff:10.0.0.1/120",
                                      	"127.0.0.1",
                                      	"::ffff:127.0.0.1",
                                      	"::1"
                                      and so on…
                                      greets
                                      shotput2017
                                        cben0ist
                                        is this an acceptable configuration ?
                                        address:"0.0.0.0",
                                        or is it better specifying the actual server ip here ?
                                        • NiggichN
                                          Niggich
                                          I put my config like this:
                                          	port: 1103,
                                          	address: '0.0.0.0',
                                          	electronOptions: {
                                          	ipWhitelist: [
                                          		"127.0.0.1",
                                          		"::ffff:127.0.0.1",
                                          		"::1",
                                          		"::ffff:192.168.113.60",
                                          		"::ffff:192.168.113.22",
                                          		"::ffff:192.168.113.97",
                                          		"::ffff:192.168.113.29",
                                          		"::ffff:192.168.113.103",
                                          		"::ffff:192.168.113.66"
                                          The Remote-Control says “This device is not allowed to acces your mirror”. The IP-Adresses are correct.
                                          J 1 Reply Last reply
                                          • F
                                            FreddeHamm
                                            i have the same problem
                                            i already set “adress” to :“0.0.0.0” and edited the ipwhitelist to
                                            ipWhitelist: [“::fff:0.0.0.0/1”, “::fff:0.8.0.0/1”, “::fff:128.0.0.0/2”, “::fff:192.0.0.0/3”, “::fff:224.0.0.0/4”, “127.0.0.1”, “::ffff:127.0.0.1”, “::1”]
                                            but still i get no access.
                                            Btw. its a raspberry pi zero with serveronly
