    After update to Mirror to 2.1.3 - no working Whitlist
    33 Posts 18 Posters 33.2k Views 18 Watching
    • F
      fox @randomnoise
      @randomnoise said in After update to Mirror to 2.1.3 - no working Whitlist:
      @d3r said in After update to Mirror to 2.1.3 - no working Whitlist:
      address:“0.0.0.0”,
      Thanks d3r, this was indeed the solution.
      And how is the syntax?
      Something like this?
      var config =
              electronOptions: {
              ipWhitelist: [
                      "127.0.0.1",
                      "0.0.0.0",
                      "::ffff:127.0.0.1",
                      "::1",
                      "::ffff:192.168.188.42",
                      "192.168.188.1/24",
                      "::ffff:192.168.188.50"
      that does not work for me, before the update my MM was working really fine.
      Also MMM-iFrameReload is not working anymore :(
      Issues With MMM-WatchDog known?
      https://forum.magicmirror.builders/post/29827
      Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
      randomnoiseR 1 Reply Last reply
      • randomnoiseR
        randomnoise @fox
        @fox this doesn’t go within the whitelist section it has to go after the comma at the end of your whitelist section.
        It is its own config parameter.
        address:“0.0.0.0”,
        • F
          fox @roramirez
          @randomnoise thank you for clarifying.
          @roramirez said in After update to Mirror to 2.1.3 - no working Whitlist:
          That happens because the release 2.1.3 was introduced a new change to make more secure the MagicMirror, to prevent open all interfaces to world. So, now from 2.1.3 the default values for address is localhost instead of 0.0.0.0… so …be careful to set this value.
          i tried your fix: https://github.com/MichMich/MagicMirror/issues/1036#issuecomment-333243474
          now MM crashed. With “pm2 logs mm” only weird errors appear :(
          Was that thing with the developer checkout really intended to remain a stable MM?
          • Sandy2503S
            Sandy2503
            I change my config.js in:
            /*************** AUTO GENERATED BY REMOTE CONTROL MODULE ***************/
            var config =
                    port: 8081,
                    address:"0.0.0.0",
                    electronOptions: {
                    ipWhitelist: [
                            "127.0.0.1",
                            "::ffff:127.0.0.1",
                            "::1",
                            "192.168.178.20/24"
                    language: "de",
            and now it works again.
            I have now access to MMM-Remote-Control from my HomePC again …
            Sandy2503
            Reply Quote 2
            • F
              fox
              @Sandy2503 ok nice to know. My problem, that - as i wrote - that with the “developer checkout” from github my MagicMirror is now broken :(
              • H
                Hein-Jan
                Adding
                address: “0.0.0.0”,
                to the config.js also did the trick for me.
                Thanks!
                • K
                  knubbl
                  As soon i put “0.0.0.0” to my config (see bellow with empty adress"") i get a black screen on start MM
                  var config = {
                  port: 8080,
                  address:“”,
                  language: “de”,
                  timeFormat: 24,
                  units: “metric”,
                  Any ideas?
                    shotput2017 @knubbl
                    hi!
                    maybe wrong config.js ??
                    here is my working code:
                    var config =
                    address: “0.0.0.0”,
                    electronOptions: {
                    ipWhitelist: [
                    	"10.0.0.1/24",
                    	"::ffff:10.0.0.1/120",
                    	"127.0.0.1",
                    	"::ffff:127.0.0.1",
                    	"::1"
                    and so on…
                    greets
                    shotput2017
                      cben0ist
                      is this an acceptable configuration ?
                      address:"0.0.0.0",
                      or is it better specifying the actual server ip here ?
                      • NiggichN
                        Niggich
                        I put my config like this:
                        	port: 1103,
                        	address: '0.0.0.0',
                        	electronOptions: {
                        	ipWhitelist: [
                        		"127.0.0.1",
                        		"::ffff:127.0.0.1",
                        		"::1",
                        		"::ffff:192.168.113.60",
                        		"::ffff:192.168.113.22",
                        		"::ffff:192.168.113.97",
                        		"::ffff:192.168.113.29",
                        		"::ffff:192.168.113.103",
                        		"::ffff:192.168.113.66"
                        The Remote-Control says “This device is not allowed to acces your mirror”. The IP-Adresses are correct.
                        J 1 Reply Last reply
                        • F
                          FreddeHamm
                          i have the same problem
                          i already set “adress” to :“0.0.0.0” and edited the ipwhitelist to
                          ipWhitelist: [“::fff:0.0.0.0/1”, “::fff:0.8.0.0/1”, “::fff:128.0.0.0/2”, “::fff:192.0.0.0/3”, “::fff:224.0.0.0/4”, “127.0.0.1”, “::ffff:127.0.0.1”, “::1”]
                          but still i get no access.
                          Btw. its a raspberry pi zero with serveronly
                            Jopyth Moderator @Niggich
                            @Niggich For my setup (raspberry pi 2) something changed after the update, but when I changed my IP addresses to the IPv4 notation (remove ::ffff: from your addresses) it worked again. Which format do the blocked addresses have in your logs (see below)?
                            @FreddeHamm Are you sure those CIDR numbers are correct?
                            When in doubt, check the output or logs (pm2 logs MagicMirror or pm2 logs mm if you used the old auto starting guide), there should be a line telling you which IP address was received. Also there are a calculators which transform your IP range to the CIDR notation.
                            • N
                              Nick
                              Same here, tried addres 0.0.0.0 and various things in the Whitelist.
                              A ping gives “destination unreachable”… SSH also doesn’t work.
                              Can someone please suggest ways to troubleshoot?
                              Mykle1M 1 Reply Last reply
                              • Mykle1M
                                Mykle1 Project Sponsor Module Developer @Nick
                                @Nick said in After update to Mirror to 2.1.3 - no working Whitlist:
                                Have you tried OUTSIDE your Whitelist, as such:
                                var config = {
                                	port: 8080,
                                        address: "0.0.0.0",
                                	ipWhitelist: [], // Set [] to allow all IP addresses.
                                • N
                                  Nick
                                  Thx @Mykle1, indeed I have. See the beginning of my (working) config file below.
                                  What is suspicious to me is that not even a Ping works to that IP, even though I’ve checked it by printing it on the screen of the MM and in the router.
                                  Also, before my Whitelist was a long list of IPs, now I’ve tried the [] option but to no avail…
                                  var config =
                                          address: "0.0.0.0",
                                          electronOptions: {
                                          ipWhitelist: [
                                                          module: "alert",
                                                          module: "updatenotification",
                                                          position: "top_bar",
                                                          module: "MMM-Remote-Control",
                                                          position: "middle_center",
                                  • Mykle1M
                                    Pinging the mirror’s IP fails? Pinging other devices on your network is successful?
                                    • N
                                      Nick
                                      Yes, including my personal wiki on another Raspberry Pi, all with 2-5ms
                                      Mykle1M J 2 Replies Last reply
                                      • Mykle1M
                                        None of this may help, but you can use it as a checklist.
                                        • ifconfig on Pi reports the IP address you are trying to ping (wlan0) assuming wifi
                                        • Connecting Pi via ethernet, ifconfig and trying to ping then
                                        • Pinging another device from the Pi itself
                                        • The MM software updates. Clock, calendar, weather, etc?
                                        Logically, if the only thing you can’t do is ping or connect to the Pi, then something is wrong on the software side, whether a corruption, an edit or a failed installation of the software or dependencies during the upgrade process. The answer in that case, with the most success, is a manual installation, IMHO. You can continue to troubleshoot, which could take a long time, or you can know in less than an hour. You will not lose anything in doing this.
                                        https://forum.magicmirror.builders/topic/5274/how-to-manually-install-mm-on-your-pi-for-absolute-beginners
                                        Reply Quote 2
                                          Jopyth Moderator @Nick
                                          @Nick As @Mykle1 said: something is wrong if you can neither ping nor ssh. You definitely need to check your general wifi/ethernet setup. This is not something that can be solved through the config file.
                                          • FlatPepsiF
                                            FlatPepsi
