    After update to Mirror to 2.1.3 - no working Whitlist
    33 Posts 18 Posters 33.3k Views 18 Watching
    • MichMichM
      MichMich
      Thanks d3r!
        roramirez Core Contributors
        That happens because the release 2.1.3 was introduced a new change to make more secure the MagicMirror, to prevent open all interfaces to world. So, now from 2.1.3 the default values for address is localhost instead of 0.0.0.0… so …be careful to set this value.
        Sandy2503S F 2 Replies Last reply
        • Sandy2503S
          Sandy2503 @roramirez
          @roramirez - and how can i now access to my mirror from my homenetwork ?
          What do i have to do ???
          Sandy
          R 1 Reply Last reply
          • randomnoiseR
            randomnoise @d3r
            @d3r said in After update to Mirror to 2.1.3 - no working Whitlist:
            address:“0.0.0.0”,
            Thanks d3r, this was indeed the solution.
            F 1 Reply Last reply
              roramirez Core Contributors @Sandy2503
              @Sandy2503 said in After update to Mirror to 2.1.3 - no working Whitlist:
              Set the IP address of your MagicMirror there.
              • K
                knubbl
                • F
                  fox @randomnoise
                  @randomnoise said in After update to Mirror to 2.1.3 - no working Whitlist:
                  address:“0.0.0.0”,
                  And how is the syntax?
                  Something like this?
                  var config =
                          electronOptions: {
                          ipWhitelist: [
                                  "127.0.0.1",
                                  "0.0.0.0",
                                  "::ffff:127.0.0.1",
                                  "::1",
                                  "::ffff:192.168.188.42",
                                  "192.168.188.1/24",
                                  "::ffff:192.168.188.50"
                  that does not work for me, before the update my MM was working really fine.
                  Also MMM-iFrameReload is not working anymore :(
                  Issues With MMM-WatchDog known?
                  https://forum.magicmirror.builders/post/29827
                  Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
                  randomnoiseR 1 Reply Last reply
                  • randomnoiseR
                    randomnoise @fox
                    @fox this doesn’t go within the whitelist section it has to go after the comma at the end of your whitelist section.
                    It is its own config parameter.
                    address:“0.0.0.0”,
                    • F
                      fox @roramirez
                      @randomnoise thank you for clarifying.
                      @roramirez said in After update to Mirror to 2.1.3 - no working Whitlist:
                      i tried your fix: https://github.com/MichMich/MagicMirror/issues/1036#issuecomment-333243474
                      now MM crashed. With “pm2 logs mm” only weird errors appear :(
                      Was that thing with the developer checkout really intended to remain a stable MM?
                      • Sandy2503S
                        Sandy2503
                        I change my config.js in:
                        /*************** AUTO GENERATED BY REMOTE CONTROL MODULE ***************/
                        var config =
                                port: 8081,
                                address:"0.0.0.0",
                                electronOptions: {
                                ipWhitelist: [
                                        "127.0.0.1",
                                        "::ffff:127.0.0.1",
                                        "::1",
                                        "192.168.178.20/24"
                                language: "de",
                        and now it works again.
                        I have now access to MMM-Remote-Control from my HomePC again …
                        Sandy2503
                        Reply Quote 2
                        • F
                          fox
                          @Sandy2503 ok nice to know. My problem, that - as i wrote - that with the “developer checkout” from github my MagicMirror is now broken :(
                          • H
                            Hein-Jan
                            Adding
                            address: “0.0.0.0”,
                            to the config.js also did the trick for me.
                            Thanks!
                            • K
                              knubbl
                              As soon i put “0.0.0.0” to my config (see bellow with empty adress"") i get a black screen on start MM
                              var config = {
                              port: 8080,
                              address:“”,
                              language: “de”,
                              timeFormat: 24,
                              units: “metric”,
                              Any ideas?
                                shotput2017 @knubbl
                                hi!
                                maybe wrong config.js ??
                                here is my working code:
                                var config =
                                address: “0.0.0.0”,
                                electronOptions: {
                                ipWhitelist: [
                                	"10.0.0.1/24",
                                	"::ffff:10.0.0.1/120",
                                	"127.0.0.1",
                                	"::ffff:127.0.0.1",
                                	"::1"
                                and so on…
                                greets
                                shotput2017
                                  cben0ist
                                  is this an acceptable configuration ?
                                  address:"0.0.0.0",
                                  or is it better specifying the actual server ip here ?
                                  • NiggichN
                                    Niggich
                                    I put my config like this:
                                    	port: 1103,
                                    	address: '0.0.0.0',
                                    	electronOptions: {
                                    	ipWhitelist: [
                                    		"127.0.0.1",
                                    		"::ffff:127.0.0.1",
                                    		"::1",
                                    		"::ffff:192.168.113.60",
                                    		"::ffff:192.168.113.22",
                                    		"::ffff:192.168.113.97",
                                    		"::ffff:192.168.113.29",
                                    		"::ffff:192.168.113.103",
                                    		"::ffff:192.168.113.66"
                                    The Remote-Control says “This device is not allowed to acces your mirror”. The IP-Adresses are correct.
                                    J 1 Reply Last reply
                                    • F
                                      FreddeHamm
                                      i have the same problem
                                      i already set “adress” to :“0.0.0.0” and edited the ipwhitelist to
                                      ipWhitelist: [“::fff:0.0.0.0/1”, “::fff:0.8.0.0/1”, “::fff:128.0.0.0/2”, “::fff:192.0.0.0/3”, “::fff:224.0.0.0/4”, “127.0.0.1”, “::ffff:127.0.0.1”, “::1”]
                                      but still i get no access.
                                      Btw. its a raspberry pi zero with serveronly
                                        Jopyth Moderator @Niggich
                                        @Niggich For my setup (raspberry pi 2) something changed after the update, but when I changed my IP addresses to the IPv4 notation (remove ::ffff: from your addresses) it worked again. Which format do the blocked addresses have in your logs (see below)?
                                        @FreddeHamm Are you sure those CIDR numbers are correct?
                                        When in doubt, check the output or logs (pm2 logs MagicMirror or pm2 logs mm if you used the old auto starting guide), there should be a line telling you which IP address was received. Also there are a calculators which transform your IP range to the CIDR notation.
                                        • N
                                          Nick
                                          Same here, tried addres 0.0.0.0 and various things in the Whitelist.
                                          A ping gives “destination unreachable”… SSH also doesn’t work.
                                          Can someone please suggest ways to troubleshoot?
                                          Mykle1M 1 Reply Last reply
                                          • Mykle1M
                                            Mykle1 Project Sponsor Module Developer @Nick
                                            @Nick said in After update to Mirror to 2.1.3 - no working Whitlist:
                                            Have you tried OUTSIDE your Whitelist, as such:
                                            var config = {
                                            	port: 8080,
                                                    address: "0.0.0.0",
                                            	ipWhitelist: [], // Set [] to allow all IP addresses.
