    After update to Mirror to 2.1.3 - no working Whitlist
    33 Posts 18 Posters 33.3k Views 18 Watching
    • randomnoiseR
      randomnoise @d3r
      @d3r said in After update to Mirror to 2.1.3 - no working Whitlist:
      address:“0.0.0.0”,
      Thanks d3r, this was indeed the solution.
      F 1 Reply Last reply
        roramirez Core Contributors @Sandy2503
        @Sandy2503 said in After update to Mirror to 2.1.3 - no working Whitlist:
        What do i have to do ???
        Set the IP address of your MagicMirror there.
        • K
          knubbl
          • F
            fox @randomnoise
            @randomnoise said in After update to Mirror to 2.1.3 - no working Whitlist:
            address:“0.0.0.0”,
            And how is the syntax?
            Something like this?
            var config =
                    electronOptions: {
                    ipWhitelist: [
                            "127.0.0.1",
                            "0.0.0.0",
                            "::ffff:127.0.0.1",
                            "::1",
                            "::ffff:192.168.188.42",
                            "192.168.188.1/24",
                            "::ffff:192.168.188.50"
            that does not work for me, before the update my MM was working really fine.
            Also MMM-iFrameReload is not working anymore :(
            Issues With MMM-WatchDog known?
            https://forum.magicmirror.builders/post/29827
            Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
            randomnoiseR 1 Reply Last reply
            • randomnoiseR
              randomnoise @fox
              @fox this doesn’t go within the whitelist section it has to go after the comma at the end of your whitelist section.
              It is its own config parameter.
              address:“0.0.0.0”,
              • F
                fox @roramirez
                @randomnoise thank you for clarifying.
                @roramirez said in After update to Mirror to 2.1.3 - no working Whitlist:
                That happens because the release 2.1.3 was introduced a new change to make more secure the MagicMirror, to prevent open all interfaces to world. So, now from 2.1.3 the default values for address is localhost instead of 0.0.0.0… so …be careful to set this value.
                i tried your fix: https://github.com/MichMich/MagicMirror/issues/1036#issuecomment-333243474
                now MM crashed. With “pm2 logs mm” only weird errors appear :(
                Was that thing with the developer checkout really intended to remain a stable MM?
                • Sandy2503S
                  Sandy2503
                  I change my config.js in:
                  /*************** AUTO GENERATED BY REMOTE CONTROL MODULE ***************/
                  var config =
                          port: 8081,
                          address:"0.0.0.0",
                          electronOptions: {
                          ipWhitelist: [
                                  "127.0.0.1",
                                  "::ffff:127.0.0.1",
                                  "::1",
                                  "192.168.178.20/24"
                          language: "de",
                  and now it works again.
                  I have now access to MMM-Remote-Control from my HomePC again …
                  Sandy2503
                  Reply Quote 2
                  • F
                    fox
                    @Sandy2503 ok nice to know. My problem, that - as i wrote - that with the “developer checkout” from github my MagicMirror is now broken :(
                    • H
                      Hein-Jan
                      Adding
                      address: “0.0.0.0”,
                      to the config.js also did the trick for me.
                      Thanks!
                      • K
                        knubbl
                        As soon i put “0.0.0.0” to my config (see bellow with empty adress"") i get a black screen on start MM
                        var config = {
                        port: 8080,
                        address:“”,
                        language: “de”,
                        timeFormat: 24,
                        units: “metric”,
                        Any ideas?
                          shotput2017 @knubbl
                          hi!
                          maybe wrong config.js ??
                          here is my working code:
                          var config =
                          address: “0.0.0.0”,
                          electronOptions: {
                          ipWhitelist: [
                          	"10.0.0.1/24",
                          	"::ffff:10.0.0.1/120",
                          	"127.0.0.1",
                          	"::ffff:127.0.0.1",
                          	"::1"
                          and so on…
                          greets
                          shotput2017
                            cben0ist
                            is this an acceptable configuration ?
                            address:"0.0.0.0",
                            or is it better specifying the actual server ip here ?
                            • NiggichN
                              Niggich
                              I put my config like this:
                              	port: 1103,
                              	address: '0.0.0.0',
                              	electronOptions: {
                              	ipWhitelist: [
                              		"127.0.0.1",
                              		"::ffff:127.0.0.1",
                              		"::1",
                              		"::ffff:192.168.113.60",
                              		"::ffff:192.168.113.22",
                              		"::ffff:192.168.113.97",
                              		"::ffff:192.168.113.29",
                              		"::ffff:192.168.113.103",
                              		"::ffff:192.168.113.66"
                              The Remote-Control says “This device is not allowed to acces your mirror”. The IP-Adresses are correct.
                              J 1 Reply Last reply
                              • F
                                FreddeHamm
                                i have the same problem
                                i already set “adress” to :“0.0.0.0” and edited the ipwhitelist to
                                ipWhitelist: [“::fff:0.0.0.0/1”, “::fff:0.8.0.0/1”, “::fff:128.0.0.0/2”, “::fff:192.0.0.0/3”, “::fff:224.0.0.0/4”, “127.0.0.1”, “::ffff:127.0.0.1”, “::1”]
                                but still i get no access.
                                Btw. its a raspberry pi zero with serveronly
                                  Jopyth Moderator @Niggich
                                  @Niggich For my setup (raspberry pi 2) something changed after the update, but when I changed my IP addresses to the IPv4 notation (remove ::ffff: from your addresses) it worked again. Which format do the blocked addresses have in your logs (see below)?
                                  @FreddeHamm Are you sure those CIDR numbers are correct?
                                  When in doubt, check the output or logs (pm2 logs MagicMirror or pm2 logs mm if you used the old auto starting guide), there should be a line telling you which IP address was received. Also there are a calculators which transform your IP range to the CIDR notation.
                                  • N
                                    Nick
                                    Same here, tried addres 0.0.0.0 and various things in the Whitelist.
                                    A ping gives “destination unreachable”… SSH also doesn’t work.
                                    Can someone please suggest ways to troubleshoot?
                                    Mykle1M 1 Reply Last reply
                                    • Mykle1M
                                      Mykle1 Project Sponsor Module Developer @Nick
                                      @Nick said in After update to Mirror to 2.1.3 - no working Whitlist:
                                      Have you tried OUTSIDE your Whitelist, as such:
                                      var config = {
                                      	port: 8080,
                                              address: "0.0.0.0",
                                      	ipWhitelist: [], // Set [] to allow all IP addresses.
                                      • N
                                        Nick
                                        Thx @Mykle1, indeed I have. See the beginning of my (working) config file below.
                                        What is suspicious to me is that not even a Ping works to that IP, even though I’ve checked it by printing it on the screen of the MM and in the router.
                                        Also, before my Whitelist was a long list of IPs, now I’ve tried the [] option but to no avail…
                                        var config =
                                                address: "0.0.0.0",
                                                electronOptions: {
                                                ipWhitelist: [
        module: "alert",
        module: "updatenotification",
        position: "top_bar",
        module: "MMM-Remote-Control",
        position: "middle_center",
                                        • Mykle1M
                                          Pinging the mirror’s IP fails? Pinging other devices on your network is successful?
                                          • N
                                            Nick
                                            Yes, including my personal wiki on another Raspberry Pi, all with 2-5ms
                                            Mykle1M J 2 Replies Last reply
