    Since the update calendar too wide
    8 Posts 6 Posters 4.0k Views 6 Watching
      JoeFranz
      Hello, since the update, the calendar is always on full width. No matter what you type at “maxTitleLength”.
      Mykle1M 1 Reply Last reply
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @JoeFranz
        @JoeFranz said in Since the update calendar too wide:
        You could try this in your custom.css file and adjust accordingly.
        .calendar {
          width: 300px;
          pjkoeleman
          An other option is working with variables in your custom CSS-file and making all of your modules the same width. Changing the width is than done only on one place in your custom CSS-file.
          Try this in your custom.css and ad all your modules to it.
          /* Vars */
          :root {
          	/* Width for all modules */
          	--mod-width	: 310px;			/* only px no % */
          /* Make all modules same width */
          .clock {
          	width	: var(--mod-width);
          .calendar {
          I do the same with colors I use in my custom CSS-file.
            JoeFranz
            Ok that works, thank you. Nevertheless, there are still problems with the calendar. “timeFormat”, “getRelative” and “urgency” do not work either.
            My PIR sensor does not work properly either.
            I think everything again to make completely new.
              djsunrise19
              same here with “maximumEntries”. Doesn’t work anymore. I see all of them, 30 or 35.
              • O
                orayoflighto Project Sponsor
                maxTitleLength
                I am having the same problem. I updated recently and maxTitleLength no longer is working.
                • O
                  onetwankyfive
                  try the flag maximumEntries: ‘10’, in your config file right after the calendar you are displaying
                  symbol: 'headphones ',
                  url: ‘https://google.com/public/basic.ics’,
                  maxTitleLength:‘30’
                  I miss the way the old calendar did max 10 no matter how many calendars you were calling in the config
                  O 1 Reply Last reply
                  • O
                    orayoflighto Project Sponsor @onetwankyfive
                    @onetwankyfive
                    Adding the config option after each calendar worked for me. Thanks for the help!
