    MMM-MyCalendar
    109 Posts 40 Posters 166.0k Views 38 Watching
      j.e.f.f Project Sponsor Module Developer @Johans
      @Johans The calendars portion of the config is an array. You can specify multiple calendars like so:
            url: "http://path.to.some/calendar.ics",
            color: "#ffb350"
            url: "http://path.to.another/calendar.ics",
            color: "#ff77d4"
      Each calendar can have its own colour setting so that you can tell what the source of the event is.
        Johans @j.e.f.f
        @j.e.f.f
        Thank you.
        All fine now.
        • kruemelK
          kruemel
          Hey @j-e-f-f , i got another issue ^^
          I updated MagicMirror to the new version and your modules also.
          It is just strange wide, no text but it streches the left moduls and wasting space
          Thats how it looks now:
          And how it should look (MyCalendar temporary disabled)
          Regards Manuel :-)
            j.e.f.f Project Sponsor Module Developer @kruemel
            @kruemel The module is configured to use the full width of the containing region (e.g.: top_left) up to a maximum of 500px. If you want it to be narrower, then you can add a rule in your custom.css file to control the width of the containers. For example, I have this in my custom.css file:
            .region.right .module-content,
            .region.left .module-content {
              min-width: 300px;
              max-width: 300px;
            This limits top_right, top_left bottom_right and bottom_left to an explicit width of 300px. MMM-MyCalendar, MMM-MyCommute and any of my other modules will conform to this width.
            • kruemelK
              kruemel
              @j-e-f-f Okay thank you very much.
              I will do it like this but i still want to understand why the “MyCalendar” streches so much with no text and your other module “MyCommute” doesnt?
              Why you configured this differently?
                @kruemel HTML is a funny thing. It can use space in all sorts of ways depending on the situation. In the case of the MMM-MyCalendar module, it is a modification of the default calendar, but generally it is much the same. Its layout is done with tables. MMM-MyCommute, on the other hand, is completely written from the ground up. It’s layout is made up of DIV and SPAN elements, fully styled and positioned with CSS. They are two different animals.
                  A Former User
                  Hello everyone, do you know how i can add my google calender to my mirror please ??
                    j.e.f.f Project Sponsor Module Developer @Guest
                    @PCPAYN3 It works the same way you would do it for the default calendar module.
                    Config details here:
                    https://github.com/jclarke0000/MMM-MyCalendar
                    which are more or less identical to configuring the default calendar:
                    https://github.com/MichMich/MagicMirror/tree/develop/modules/default/calendar
                    The only tricky part is getting the ics link for your google calendar. See here for instructions:
                    https://www.smsclientreminders.com/how_to_share_your_calendar_with_other_applications#google
                    I hope this helps!
                    • Jeff
                    • kruemelK
                      kruemel
                      @j-e-f-f thank you :-)
                        A Former User @j.e.f.f
                        @j.e.f.f Thank you I will look into this.
                          @j.e.f.f I have tried to set this up and all I’m getting on the screen is the time & date at the top and then calendar loading ??
                            @PCPAYN3 are you trying to set up up your google calendar? Do you have the .ics link for it?
                              @j.e.f.f hi yes i am, and have the ics link.
                                @PCPAYN3 can your post your config? Hide your ics link, but post the rest.
                                    @PCPAYN3 Two things:
                                    1. Your config is trying to configure the default calendar module, not MMM-MyCalendar. The config for MMM-MyCalendar looks something like this:
                                          module: "MMM-MyCalendar",
                                          classes: "default everyone",
                                          header: "Upcoming",
                                          disabled: false,
                                            colored: true,
                                            maximumNumberOfDays: 30,
                                            maximumEntries: 5,
                                            fade: false,
                                            maxTitleLength: 500,
                                            useRelativeDates: false,
                                            dayOfWeekFormat: "dddd",
                                            timeFormat: "h:mm A",
                                            dateFormat: "MMMM D",
                                            joiningWord: "at",
                                            urgency: 1,
                                                url: "https://calendar.google.com/path/to/your/basic.ics",
                                                color: "#ffb350"
                                                url: "https://calendar.google.com/path/to/another/basic.ics",
                                                color: "#ff77d4"
                                    1. You should delete your post above. It contains your private ICS link – this is what I meant for you to hide when I mentioned it above – as well as you app id for the weather module. That’s all information you should keep secret, and edit out before you post your config in the forum.
                                      @j.e.f.f Hi jeff I have replaced the code as you said in the config file and still nothing :/ its showing the clock but nothing else on the page. Not even the loading anymore. Any ideas? & I think ive deleted my other post, it shows as greyed out now.
                                        @PCPAYN3 Can you confirm you installed the module by following these steps:
                                        1. Navigate to the MagicMirror/modules directory
                                        2. Execute git clone https://github.com/jclarke0000/MMM-MyCalendar.git
                                        3. Add the relevant configuration to config.js
                                        4. Restart Magic Mirror
                                        And yes, your post shows as deleted.
                                        ? 3 Replies Last reply Reply Quote 0
                                          @j.e.f.f Thanks @j-e-f-f no I didn’t do that, I have done it now. And trying it out. Sorry im new to this, and really appreciate your help.
                                            @j.e.f.f After reboot it is now showing the second calendar i entered for UK holidays but not the top one which was my google calendar :( any ideas?
                                            • 2 / 6
