    MMM-SimpleTides - (Replaced by MMM-SORT)
    Scheduled Pinned Locked Moved Education
    6 Posts 2 Posters 3.0k Views 2 Watching
      Description:
      • A simple tide module that rotates through 7 days of tides.
      • Based on your latitude and longitude.
      • Extremely small footprint won’t crowd your mirror.
      Examples:
      Annotated .css file included for position, sizing, and coloring. Default is white.
      • One colored with header, one plain white with no header.
      • Display only the info that you want to see, line by line.
      Download:
      [card:mykle1/MMM-SimpleTides]
      Version 1.0.0
        Thanks to @yawns for the green light! :^)
          Ok, so I went a bit mental. ;^)
          I couldn’t decide if I wanted the tides rotating or static and my pitiful programming skills don’t include making a module that does both. So, I made MMM-StaticTIdes. It’s basically a rewrite of MMM-SimpleTides with some formatting changes and less info to keep screen real estate to a minimum. However, a quick glance gives you the next 8 tides, whereas MMM-SimpleTides gives a full week of tides and other information in rotation.
          • yawnsY Offline
            yawns Moderator @Mykle1
            @Mykle1 said in MMM-SimpleTides:
            Simplest way would be this:
            Add a config attribute
            	disabled: false,
            	module: "MMM-SimpleTides",
            		outputLayout: "simple"
            and in getDom: function() { after preparing/modifying your data you add a simple if/else clause.
            if (this.config.outputLayout == "simple") {
            // print the data as in SimpleTides
            } else {
            // print the data as in StaticTides
            Mykle1M 2 Replies Last reply Reply Quote 1
              Mykle1 Project Sponsor Module Developer @yawns
              @yawns said in MMM-SimpleTides:
              Oh snap! Of course! Thanks yawns!
              I will give that a shot today. :^)
                I gave it the old college try, and I almost got there on my own. Two simple mistakes fixed and a Carousel() addition all made by @cowboysdude got me up and running. Thanks bro!
                MMM-SORT
