    602 Posts 67 Posters 2.3m Views 68 Watching
    • K
      kasperb
      @shbatm Thanks for clarifying. I’ve removed protocol: 'tcp' from the config.
      When executing the default command in Terminal, the video displays properly on my screen.
      The MM logs indicate that the stream is started accordingly as well (see below), but unfortunately still nothing is visible on my Mirror.
      0|mm       | Starting stream stream1 with args: [
      0|mm       |     "--avdict rtsp_transport:tcp",
      0|mm       |     "--win",
      0|mm       |     "379.5, 841.5, 731.5, 1083.5",
      0|mm       |     "--live",
      0|mm       |     "--video_queue",
      0|mm       |     "4",
      0|mm       |     "--fps",
      0|mm       |     "30",
      0|mm       |     "rtsp://admin:admin@192.168.0.130:10554/tcp/av0_1"
      0|mm       | ]
        shbatm Module Developer
        @kasperb - I have a suspicion – I think this is the same issue @Niggich was having where OMXPlayer doesn’t like non-integer window dimensions.
        Please try changing the moduleOffset: 0, setting to 0.5 and see if the video will work. If it works, you can change the offset back to 0 and try updating the module with the patch I just pushed:
        cd ~/MagicMirror/modules/MMM-RTSPStream
        git fetch --all
        git pull
        If you experience issues with the stream stopping after running for a few days, I am still finalizing work on another branch to resolve this: wip_patch which runs OMXPlayer through pm2 so it will automatically restart feed and hopefully be more stable.
        B K 2 Replies Last reply Reply Quote 0
          barnosch @shbatm
          @shbatm said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
          Great! Looking forward to it.
          • K
            kasperb @shbatm
            @shbatm I’ve tried changing the moduleOffset to 0.5, as well as some other experimental values, but unfortunately that didn’t do the trick.
            The configuration itself should work, as I had it working with a different RTSP cam previously.
              Johans
              Can’t get this up and running.
              tried to figure out the problem but as i’m newbie i’m missing the skills to locate the problem.
              what I have done so far:
              Tested my Foscam stream with VLC. This didn’t worked either. error message:
              //Uw invoer kan niet geopend worden:
              VLC kon de MRL 'rtsp://garden:garden1000%@192.168.1.241:1052/Videomain' niet openen. Controleer het logboek voor details.
              then tested VLC with default stream - and this is working fine.
              Next installed omxplayer and applied my camera stream as follows.
              //sudo omxplayer -o hdmi rtsp://garden:garden1000%@192.168.1.241:1052/videoMain
              Video codec omx-h264 width 1280 height 720 profile 66 fps 8.333333
              Audio codec pcm_mulaw channels 1 samplerate 8000 bitspersample 8
              Subtitle count: 0, state: off, index: 1, delay: 0
              V:PortSettingsChanged: 1280x720@8.33 interlace:0 deinterlace:0 anaglyph:0 par:1.00 display:0 layer:0 alpha:255 aspectMode:0
              This works perfect, getting full image on the display.
              conclusion: software is OK - just weird that my stream is not working on VLC.
              could it because password has special char ‘%’ in it?
              as omxplayer seams to work, I went back to config and added omxplayer.
              switched to the wip branch.
              started mirror - nothing happens - i get a blank screen. - below my config
              		            module: 'MMM-RTSPStream',
              			    classes: 'default everyone',
              		            position: 'middle_center',
              		                autoStart: true,
              		                rotateStreams: false,
              		                rotateStreamTimeout: 10,
              		                showSnapWhenPaused: false,
              		                moduleWidth: 354,
              		                moduleHeight: 240,
              				localPlayer: 'omxplayer',
              		                stream1: {
              		                    name: 'Webcam 1 Test Stream',
              		                    url: 'rtsp://garden:garden1000%@192.168.1.241:1052/videoMain',
              		                    snapshotUrl: '',
              		                    snapshotRefresh: 10, // Seconds
              		                    frameRate: "25",
              		                    port: 9999,
              without omxplayer and master branch active, I see the video play icon on the mirror, but nothing is displayed.
              any ideas help to get this running would be great.
              Also installed MMM-IP webcam but also no image from the webcam.
              J K 2 Replies Last reply Reply Quote 0
                Johans @Johans
                Switched back to master branch
                started in dev mode.
                error info see picture
                • K
                  kasperb @kasperb
                  @shbatm I did a fresh install of the module, and am pleased to inform you that it’s working fine now. Thanks for your help!
                  • K
                    kasperb @Johans
                    @Johans I had a similar issue, and was able to resolve it by re-installing the module.
                    I just realized that I also added the cam’s ip to the IP whitelist and moved this module to the top of the config; not sure if that did anything, but mine is working now, so it might be worth a shot.
                      shbatm Module Developer @Johans
                      @Johans Which other modules are you using? It looks like you may be using something like MMM-ProfileSwitcher, there may be a conflict between these modules or it may be because of the % symbol in the password.
                      Also, when you switched to the wip branch, did you remember to re-run npm install in that folder? There are some additional dependencies for the wip branch.
                        Johans @shbatm
                        @shbatm
                        re-installed module, changed IPcams password and removed the ‘%’
                        Result: No live stream.
                        swiched module to wip branch for usage with omxplayer:
                        Result OK, I can see the live stream from the IPCAM - so that is working.
                        so thanks for the feedback.
                          Johans @kasperb
                          @kasperb
                          Re-installed - loaded wip branch and now it’s working - thx
                            Version 1.2.1 (Updated 15 Oct 2017) Now Available on ‘master’ branch
                            • Now uses hardware-accelerated OMXPlayer as default player for local video
                            • Resolved latency issues
                            • Uses PM2 to control stream playback – automatically restarts streams when they close
                            • Fullscreen, custom window and offset options now available.
                            • Important - please update your configurations after updating this module. as some settings have changed. This new version includes a new configuration tool for building your configuration section.
                            Fresh Install:
                            See the installation instructions on the README.
                            To switch back from the ‘wip’ branch:
                            (Only necessary if you want to, the ‘wip’ and ‘master’ are the same currently, but I will update the ‘wip’ with new features and bug-fixes first for testing. If you want to beta test, stay on ‘wip’)
                            cd ~/MagicMirror/modules/MMM-RSTPStream
                            git checkout master
                            git pull
                            npm install
                            http-server -p 9999
                            # From a web browser, navigate to http://mirror-ip:9999/config.html
                            # Once your config is made, press Ctrl+C to exit the config builder
                            # Restart your mirror and test!
                            J NiggichN 2 Replies Last reply Reply Quote 1
                              Johans @shbatm
                              @shbatm
                              Nice work man.
                              One small question: white box is not in line with the video window.
                              I added this line in the config
                              //      autoStart: true,
                              	rotateStreams: false,   //changed true to false
                                      rotateStreamTimeout: 10,    // seconds
                              	moduleWidth: 354,
                              	moduleHeight: 240,
                              moduleOffset: { top: 20, left: -20 },
                                      remotePlayer: 'none',
                                      showSnapWhenPaused: true,
                                      remoteSnaps: true,
                              but this doesn’t change anything, position of video window isn’t moved.
                              how can I change the position?
                                @Johans I just tried this on my mirror and was able to get the video feed to move without a problem. Did you try restarting the mirror & video feed after you made the change? You can also try making larger changes to make sure it’s actually moving : moduleOffset: { left -200, top: 200} or try just moduleOffset: 50 to make sure it works.
                                An alternative is to watch the console log for the parameters used:
                                    "--avdict",
                                    "rtsp_transport:tcp",
                                    "--win",
                                    "731, 439, 1259, 799",  # --- this is the position it tries to draw the video
                                And then add the following inside the stream1: { section to specify the exact position you want the video to show using the numbers from the log and your desired offset:
                                absPosition: { top: XX, right: XX, bottom: XX, left: XX },
                                  barnosch
                                  i updated the module from work, but did not start the server thing to get the server config page.
                                  Later at home i could not start the server anymore to reach the config page.
                                  Is that mandatory?
                                  The stream runs good, without any changes in the config. Hopefully it does not crash so often anymore.
                                  I saw that it launches now another pm2 session just for the stream. thats nice.
                                  So i can restart both sessions (stream and mirror) with a script and do not need to reboot the whole pi anymore, when i change something.
                                    Johans @shbatm
                                    @shbatm
                                    Made some larger changes and saw the video moves. Now it’s perfect within the box.
                                    I’ve noticed that when video is out of the box window, the omxplayer is not stopped or killed. Video still remains visible even MM has stopped.
                                    At moment the video was perfect within the box, it also kills perfect the video stream.
                                    Just wanted to let you know this.
                                    thanks for the support.
                                    J.
                                    • NiggichN
                                      Niggich @shbatm
                                      @shbatm At first, thx for your great work. I finally tried to update the module but after npm installI get an Error message like this.
                                      > MMM-RTSPStream@1.2.1 postinstall /home/pi/MagicMirror/modules/MMM-RTSPStream
                                      > ./install_sd_patch.sh && sudo npm i -g http-server
                                      Applying Graceful Shutdown patch to MagicMirror.
                                      error: Anwendung des Patches fehlgeschlagen: js/electron.js:96
                                      error: js/electron.js: Patch konnte nicht angewendet werden
                                      npm ERR! Linux 4.9.48-v7+
                                      npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install"
                                      npm ERR! node v4.3.2
                                      npm ERR! npm  v2.14.12
                                      npm ERR! code ELIFECYCLE
                                      npm ERR! MMM-RTSPStream@1.2.1 postinstall: `./install_sd_patch.sh && sudo npm i -g http-server`
                                      npm ERR! Exit status 1
                                      npm ERR!
                                      npm ERR! Failed at the MMM-RTSPStream@1.2.1 postinstall script './install_sd_patch.sh && sudo npm i -g http-server'.
                                      npm ERR! This is most likely a problem with the MMM-RTSPStream package,
                                      npm ERR! not with npm itself.
                                      npm ERR!     ./install_sd_patch.sh && sudo npm i -g http-server
                                      npm ERR! You can get their info via:
                                      npm ERR!     npm owner ls MMM-RTSPStream
                                      npm ERR!     /home/pi/MagicMirror/modules/MMM-RTSPStream/npm-debug.log
                                      I tried to update and a Fresh install but at both ways I get the same Error.
                                        shbatm Module Developer @Niggich
                                        @Niggich It appears it is installing correctly and the post-install is not working, please try to run the following commands and see which one fails:
                                        # Change directory
                                        # Install the "Graceful Shutdown" patch on MM core (Issue #1056)
                                        # Install the Node.js http-server module
                                        NiggichN 1 Reply Last reply Reply Quote 0
                                          @Johans said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                                          This sounds like there is still a glitch in the starting of the stream. I will investigate on my end too. Are you using any other modules that hide or show this one? Scheduler, Carousel, or ProfileSwitcher?
                                            shbatm Module Developer @barnosch
                                            @barnosch said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                                            The config page is not mandatory, it just helps create a valid config file and helps you eliminate settings you don’t need to mess with. If you had a working version before on the wip branch, nothing significant has changed. If you used ffmpeg or the main branch before, you must update the port setting to ffmpegPort.
                                            You should also still be able to get to the config page after install:
                                            # Make sure http-server is installed:
                                            # Start the server:
                                            http-server -p 9999
                                            # Navigate in browser to:
                                            http://magic-mirror-ip:9999/config.html
                                            • 30
                                            • 31
                                            • 4 / 31
