    How can I see the HTML that being generated?
    11 Posts 4 Posters 7.9k Views 2 Watching
    • Z
      Zooooooom
      I am trying to modify an existing module. In order to understand it, I would like to see the underlying HTML. Is there a simple way of doing that besides reading the code?
      • cowboysdudeC
        Not sure what you’re after here… what module? Can’t answer a question without all the info here…
        • Z
          Zooooooom
          I am trying to mess with CalendarExt, but I didn’t think that matters.
          Doesn’t every module basically output HTML? I am thinking of something like hitting F12 to go into debug mode in a browser and then being able to view the DOM.
          Mykle1M 1 Reply Last reply
          • Mykle1M
            Mykle1 Project Sponsor Module Developer @Zooooooom
            @Zooooooom said in How can I see the HTML that being generated?:
            start the mirror using npm start dev
            Z 1 Reply Last reply
            • brobergB
              broberg Project Sponsor
              Yeah, it’s easier to understand how the modules displays if you check the output in a browser, so check the debug in your browser and cross-reference the DIV’s, names and ID’s to see what’s what.
              • Z
                Zooooooom @Mykle1
                @Mykle1, that did it, thanks!
                @broberg, is there a way to use a browser on my PC to view it? Looking at debug view is very slow over VNC.
                • Mykle1M
                  http://192.168.1.20:8080/ - substitute your Pi’s ip address. You’ll likely have to Whitelist your PC’s ip address for this
                  Or, even better, run MM on your PC and do all your developing there. No lag
                  • Z
                    Zooooooom @Mykle1
                    @Mykle1 Thanks, I will try to get the web server working. Right now, it’s not responding. I tried adding “::ffff:192.168.1.1/120” and my exact ip address. I am just getting “unable to connect”
                    • Mykle1M
                      @Zooooooom
                      Well, if you don’t mind whitelisting all the devices on your network, this will work:
                      Try this at the very beginning of your config.js file, so it looks like this:
                      var config = {
                      	port: 8080,
                              address: "0.0.0.0",
                      	ipWhitelist: [], // Set [] to allow all IP addresses.
                      Reply Quote 2
                      • Z
                        Zooooooom @Mykle1
                        @Mykle1 Thanks! I was missing the address from config.
                        Reply Quote 2
                        • Mykle1M
                          You’re welcome mate
