    How can I see the HTML that being generated?
    11 Posts 4 Posters 7.0k Views 2 Watching
    • brobergB Offline
      broberg Project Sponsor
      Yeah, it’s easier to understand how the modules displays if you check the output in a browser, so check the debug in your browser and cross-reference the DIV’s, names and ID’s to see what’s what.
      • Z Offline
        Zooooooom @Mykle1
        @Mykle1, that did it, thanks!
        @broberg, is there a way to use a browser on my PC to view it? Looking at debug view is very slow over VNC.
          Mykle1 Project Sponsor Module Developer @Zooooooom
          @Zooooooom said in How can I see the HTML that being generated?:
          http://192.168.1.20:8080/ - substitute your Pi’s ip address. You’ll likely have to Whitelist your PC’s ip address for this
          Or, even better, run MM on your PC and do all your developing there. No lag
          Z 1 Reply Last reply Reply Quote 1
          • Z Offline
            Zooooooom @Mykle1
            @Mykle1 Thanks, I will try to get the web server working. Right now, it’s not responding. I tried adding “::ffff:192.168.1.1/120” and my exact ip address. I am just getting “unable to connect”
              @Zooooooom
              Well, if you don’t mind whitelisting all the devices on your network, this will work:
              Try this at the very beginning of your config.js file, so it looks like this:
              var config = {
              	port: 8080,
                      address: "0.0.0.0",
              	ipWhitelist: [], // Set [] to allow all IP addresses.
              Z 1 Reply Last reply Reply Quote 2
              • Z Offline
                Zooooooom @Mykle1
                @Mykle1 Thanks! I was missing the address from config.
                  You’re welcome mate
