    MMM-MyCalendar
    109 Posts 40 Posters 163.6k Views 38 Watching
    • kruemelK Offline
      kruemel
      @j-e-f-f thank you :-)
        A Former User @j.e.f.f
        @j.e.f.f Thank you I will look into this.
          @j.e.f.f I have tried to set this up and all I’m getting on the screen is the time & date at the top and then calendar loading ??
            j.e.f.f Project Sponsor Module Developer @Guest
            @PCPAYN3 are you trying to set up up your google calendar? Do you have the .ics link for it?
              @j.e.f.f hi yes i am, and have the ics link.
                @PCPAYN3 can your post your config? Hide your ics link, but post the rest.
                    @PCPAYN3 Two things:
                    1. Your config is trying to configure the default calendar module, not MMM-MyCalendar. The config for MMM-MyCalendar looks something like this:
                          module: "MMM-MyCalendar",
                          classes: "default everyone",
                          header: "Upcoming",
                          disabled: false,
                            colored: true,
                            maximumNumberOfDays: 30,
                            maximumEntries: 5,
                            fade: false,
                            maxTitleLength: 500,
                            useRelativeDates: false,
                            dayOfWeekFormat: "dddd",
                            timeFormat: "h:mm A",
                            dateFormat: "MMMM D",
                            joiningWord: "at",
                            urgency: 1,
                                url: "https://calendar.google.com/path/to/your/basic.ics",
                                color: "#ffb350"
                                url: "https://calendar.google.com/path/to/another/basic.ics",
                                color: "#ff77d4"
                    1. You should delete your post above. It contains your private ICS link – this is what I meant for you to hide when I mentioned it above – as well as you app id for the weather module. That’s all information you should keep secret, and edit out before you post your config in the forum.
                      @j.e.f.f Hi jeff I have replaced the code as you said in the config file and still nothing :/ its showing the clock but nothing else on the page. Not even the loading anymore. Any ideas? & I think ive deleted my other post, it shows as greyed out now.
                        @PCPAYN3 Can you confirm you installed the module by following these steps:
                        1. Navigate to the MagicMirror/modules directory
                        2. Execute git clone https://github.com/jclarke0000/MMM-MyCalendar.git
                        3. Add the relevant configuration to config.js
                        4. Restart Magic Mirror
                        And yes, your post shows as deleted.
                        ? 3 Replies Last reply Reply Quote 0
                          @j.e.f.f Thanks @j-e-f-f no I didn’t do that, I have done it now. And trying it out. Sorry im new to this, and really appreciate your help.
                            @j.e.f.f After reboot it is now showing the second calendar i entered for UK holidays but not the top one which was my google calendar :( any ideas?
                              @j.e.f.f Sorry to keep bothering you, i have everything on the screen now apart from the google calender. Can i embed in as an iframe on the html page? As i am familiar with html.
                                @PCPAYN3 google calendar should work – I’m using two separate google calendars with mine.
                                You can confirm that you got your ics link by following these instructions?
                                (full instructions here: https://www.smsclientreminders.com/how_to_share_your_calendar_with_other_applications#google)
                                  @j.e.f.f Hi jeff yes thats what ive done and got that link and still not showing. Do i edit the module to show this link? Or in the config file? As i tried to also edit the .js file in the MMM-Calendar module but it said permission denied when saving.
                                    A Former User
                                    As I know, private calendar sharing works only in Google Calendar. If you want to use calendar in other application, you should use public calendar. (I might be wrong.)
                                      I worked with @PCPAYN3 over chat to figure out this issue. For anyone else this might help, the problem was as follows:
                                      The following error came up in the log:
                                      Error: dates lower than Thu Jan 01 1970 00:00:00 GMT-0500 (EST) are not supported
                                      A bit of Googling pointed me to this thread:
                                      https://forum.magicmirror.builders/topic/2208/calendar-shows-no-entries-after-mm-update/29?page=3
                                      Apparently the problem is that there is an entry in the calendar that has a date prior to Jan 1, 1970. The solution was to edit the following file:
                                      /home/pi/MagicMirror/node_modules/rrule-alt/lib/rrule.js
                                      and change the ORDINAL_BASE property on line 56 to an earlier date.
                                      example, I changed:
                                      ORDINAL_BASE: new Date(1970, 0, 1),
                                      to
                                      ORDINAL_BASE: new Date(1900, 0, 1),
                                      and then the calendar worked.
                                      Z B 2 Replies Last reply Reply Quote 3
                                      • Z Offline
                                        zzaidi148 @j.e.f.f
                                        @j.e.f.f Hi Jeff! I love your module and its been easily booting up nicely. However, I tried adding two of my google calendars on it, and as I booted the module it up, it loaded and said no upcoming events. While today I dont have any events, tomorrow I do. I set the max number of days in the future to a huge number but stilll nothing. Any ideas?
                                        J C 2 Replies Last reply Reply Quote 1
                                          j.e.f.f Project Sponsor Module Developer @zzaidi148
                                          @zzaidi148 Can you confirm that you got your Gmail ICS link by following the instructions here?
                                          If so, send me a private message and I’ll troubleshoot your config.
                                            bmarofsky @j.e.f.f
                                            @j.e.f.f Thank You! Spent 3 days trying to figure this out after my SD card corrupted and I had to rebuild my MM.
                                            (making sure I remember where I store my backup .img)
                                            • 3 / 6
