    MMM-MyCalendar
    109 Posts 40 Posters 167.3k Views 38 Watching
      j.e.f.f Project Sponsor Module Developer @Guest
      @PCPAYN3 can your post your config? Hide your ics link, but post the rest.
      ? 1 Reply Last reply
        A Former User @j.e.f.f
        J 1 Reply Last reply
          @PCPAYN3 Two things:
          1. Your config is trying to configure the default calendar module, not MMM-MyCalendar. The config for MMM-MyCalendar looks something like this:
                module: "MMM-MyCalendar",
                classes: "default everyone",
                header: "Upcoming",
                disabled: false,
                  colored: true,
                  maximumNumberOfDays: 30,
                  maximumEntries: 5,
                  fade: false,
                  maxTitleLength: 500,
                  useRelativeDates: false,
                  dayOfWeekFormat: "dddd",
                  timeFormat: "h:mm A",
                  dateFormat: "MMMM D",
                  joiningWord: "at",
                  urgency: 1,
                      url: "https://calendar.google.com/path/to/your/basic.ics",
                      color: "#ffb350"
                      url: "https://calendar.google.com/path/to/another/basic.ics",
                      color: "#ff77d4"
          1. You should delete your post above. It contains your private ICS link – this is what I meant for you to hide when I mentioned it above – as well as you app id for the weather module. That’s all information you should keep secret, and edit out before you post your config in the forum.
            @j.e.f.f Hi jeff I have replaced the code as you said in the config file and still nothing :/ its showing the clock but nothing else on the page. Not even the loading anymore. Any ideas? & I think ive deleted my other post, it shows as greyed out now.
              @PCPAYN3 Can you confirm you installed the module by following these steps:
              1. Navigate to the MagicMirror/modules directory
              2. Execute git clone https://github.com/jclarke0000/MMM-MyCalendar.git
              3. Add the relevant configuration to config.js
              4. Restart Magic Mirror
              And yes, your post shows as deleted.
              ? 3 Replies Last reply
                @j.e.f.f Thanks @j-e-f-f no I didn’t do that, I have done it now. And trying it out. Sorry im new to this, and really appreciate your help.
                  @j.e.f.f After reboot it is now showing the second calendar i entered for UK holidays but not the top one which was my google calendar :( any ideas?
                    @j.e.f.f Sorry to keep bothering you, i have everything on the screen now apart from the google calender. Can i embed in as an iframe on the html page? As i am familiar with html.
                      @PCPAYN3 google calendar should work – I’m using two separate google calendars with mine.
                      You can confirm that you got your ics link by following these instructions?
                      (full instructions here: https://www.smsclientreminders.com/how_to_share_your_calendar_with_other_applications#google)
                        @j.e.f.f Hi jeff yes thats what ive done and got that link and still not showing. Do i edit the module to show this link? Or in the config file? As i tried to also edit the .js file in the MMM-Calendar module but it said permission denied when saving.
                          A Former User
                          As I know, private calendar sharing works only in Google Calendar. If you want to use calendar in other application, you should use public calendar. (I might be wrong.)
                            I worked with @PCPAYN3 over chat to figure out this issue. For anyone else this might help, the problem was as follows:
                            The following error came up in the log:
                            Error: dates lower than Thu Jan 01 1970 00:00:00 GMT-0500 (EST) are not supported
                            A bit of Googling pointed me to this thread:
                            https://forum.magicmirror.builders/topic/2208/calendar-shows-no-entries-after-mm-update/29?page=3
                            Apparently the problem is that there is an entry in the calendar that has a date prior to Jan 1, 1970. The solution was to edit the following file:
                            /home/pi/MagicMirror/node_modules/rrule-alt/lib/rrule.js
                            and change the ORDINAL_BASE property on line 56 to an earlier date.
                            example, I changed:
                            ORDINAL_BASE: new Date(1970, 0, 1),
                            to
                            ORDINAL_BASE: new Date(1900, 0, 1),
                            and then the calendar worked.
                            Z B 2 Replies Last reply
                            Reply Quote 3
                            • Z
                              zzaidi148 @j.e.f.f
                              @j.e.f.f Hi Jeff! I love your module and its been easily booting up nicely. However, I tried adding two of my google calendars on it, and as I booted the module it up, it loaded and said no upcoming events. While today I dont have any events, tomorrow I do. I set the max number of days in the future to a huge number but stilll nothing. Any ideas?
                              J C 2 Replies Last reply
                                j.e.f.f Project Sponsor Module Developer @zzaidi148
                                @zzaidi148 Can you confirm that you got your Gmail ICS link by following the instructions here?
                                If so, send me a private message and I’ll troubleshoot your config.
                                  bmarofsky @j.e.f.f
                                  @j.e.f.f Thank You! Spent 3 days trying to figure this out after my SD card corrupted and I had to rebuild my MM.
                                  (making sure I remember where I store my backup .img)
                                    Buggy
                                    Hi all. Has someone seen this? Today ist the 4th. The second term is wrong “heute” (today) and the third term is correct “morgen” (tomorrow)
                                      A Former User @Buggy
                                      @Buggy
                                      I don’t know why creater leave this issue until now, but there is a hot-fix about that.
                                      https://github.com/jclarke0000/MMM-MyCalendar/issues/3
                                      B J 2 Replies Last reply
                                        Buggy @Guest
                                        @Sean Thank you. I will apply this hot-fix.
                                          @Sean I’m currently moving to the UK, so I haven’t had time to fix this. If the hot fix worked for you, then great! I probably won’t get around to addressing this until sometime in the new year.
                                          N 1 Reply Last reply
                                          • N
                                            nitram @j.e.f.f
                                            @j.e.f.f Hi all, firstly thanks for this module - it’s fab. I’m having the exact same issue as above with today/tomorrow not working properly. I tried applying the hotfix, but it didn’t seem to work for me (though that was quite a way beyond my skill level so I could have done that wrong!). Has anyone else got this sorted?
                                            • 3 / 6
