    MMM-MyCalendar
    109 Posts 40 Posters 167.3k Views 38 Watching
      A Former User @j.e.f.f
      J 1 Reply Last reply
        j.e.f.f Project Sponsor Module Developer @Guest
        @PCPAYN3 Two things:
        1. Your config is trying to configure the default calendar module, not MMM-MyCalendar. The config for MMM-MyCalendar looks something like this:
              module: "MMM-MyCalendar",
              classes: "default everyone",
              header: "Upcoming",
              disabled: false,
                colored: true,
                maximumNumberOfDays: 30,
                maximumEntries: 5,
                fade: false,
                maxTitleLength: 500,
                useRelativeDates: false,
                dayOfWeekFormat: "dddd",
                timeFormat: "h:mm A",
                dateFormat: "MMMM D",
                joiningWord: "at",
                urgency: 1,
                    url: "https://calendar.google.com/path/to/your/basic.ics",
                    color: "#ffb350"
                    url: "https://calendar.google.com/path/to/another/basic.ics",
                    color: "#ff77d4"
        1. You should delete your post above. It contains your private ICS link – this is what I meant for you to hide when I mentioned it above – as well as you app id for the weather module. That’s all information you should keep secret, and edit out before you post your config in the forum.
        ? 1 Reply Last reply
          @j.e.f.f Hi jeff I have replaced the code as you said in the config file and still nothing :/ its showing the clock but nothing else on the page. Not even the loading anymore. Any ideas? & I think ive deleted my other post, it shows as greyed out now.
            @PCPAYN3 Can you confirm you installed the module by following these steps:
            1. Navigate to the MagicMirror/modules directory
            2. Execute git clone https://github.com/jclarke0000/MMM-MyCalendar.git
            3. Add the relevant configuration to config.js
            4. Restart Magic Mirror
            And yes, your post shows as deleted.
            ? 3 Replies Last reply
              @j.e.f.f Thanks @j-e-f-f no I didn’t do that, I have done it now. And trying it out. Sorry im new to this, and really appreciate your help.
                @j.e.f.f After reboot it is now showing the second calendar i entered for UK holidays but not the top one which was my google calendar :( any ideas?
                  @j.e.f.f Sorry to keep bothering you, i have everything on the screen now apart from the google calender. Can i embed in as an iframe on the html page? As i am familiar with html.
                    @PCPAYN3 google calendar should work – I’m using two separate google calendars with mine.
                    You can confirm that you got your ics link by following these instructions?
                    (full instructions here: https://www.smsclientreminders.com/how_to_share_your_calendar_with_other_applications#google)
                      @j.e.f.f Hi jeff yes thats what ive done and got that link and still not showing. Do i edit the module to show this link? Or in the config file? As i tried to also edit the .js file in the MMM-Calendar module but it said permission denied when saving.
                        A Former User
                        As I know, private calendar sharing works only in Google Calendar. If you want to use calendar in other application, you should use public calendar. (I might be wrong.)
                          I worked with @PCPAYN3 over chat to figure out this issue. For anyone else this might help, the problem was as follows:
                          The following error came up in the log:
                          Error: dates lower than Thu Jan 01 1970 00:00:00 GMT-0500 (EST) are not supported
                          A bit of Googling pointed me to this thread:
                          https://forum.magicmirror.builders/topic/2208/calendar-shows-no-entries-after-mm-update/29?page=3
                          Apparently the problem is that there is an entry in the calendar that has a date prior to Jan 1, 1970. The solution was to edit the following file:
                          /home/pi/MagicMirror/node_modules/rrule-alt/lib/rrule.js
                          and change the ORDINAL_BASE property on line 56 to an earlier date.
                          example, I changed:
                          ORDINAL_BASE: new Date(1970, 0, 1),
                          to
                          ORDINAL_BASE: new Date(1900, 0, 1),
                          and then the calendar worked.
                          Z B 2 Replies Last reply
                          Reply Quote 3
                          • Z
                            zzaidi148 @j.e.f.f
                            @j.e.f.f Hi Jeff! I love your module and its been easily booting up nicely. However, I tried adding two of my google calendars on it, and as I booted the module it up, it loaded and said no upcoming events. While today I dont have any events, tomorrow I do. I set the max number of days in the future to a huge number but stilll nothing. Any ideas?
                            J C 2 Replies Last reply
                              j.e.f.f Project Sponsor Module Developer @zzaidi148
                              @zzaidi148 Can you confirm that you got your Gmail ICS link by following the instructions here?
                              If so, send me a private message and I’ll troubleshoot your config.
                                bmarofsky @j.e.f.f
                                @j.e.f.f Thank You! Spent 3 days trying to figure this out after my SD card corrupted and I had to rebuild my MM.
                                (making sure I remember where I store my backup .img)
                                  Buggy
                                  Hi all. Has someone seen this? Today ist the 4th. The second term is wrong “heute” (today) and the third term is correct “morgen” (tomorrow)
                                    A Former User @Buggy
                                    @Buggy
                                    I don’t know why creater leave this issue until now, but there is a hot-fix about that.
                                    https://github.com/jclarke0000/MMM-MyCalendar/issues/3
                                    B J 2 Replies Last reply
                                      Buggy @Guest
                                      @Sean Thank you. I will apply this hot-fix.
                                        @Sean I’m currently moving to the UK, so I haven’t had time to fix this. If the hot fix worked for you, then great! I probably won’t get around to addressing this until sometime in the new year.
                                        N 1 Reply Last reply
                                        • N
                                          nitram @j.e.f.f
                                          @j.e.f.f Hi all, firstly thanks for this module - it’s fab. I’m having the exact same issue as above with today/tomorrow not working properly. I tried applying the hotfix, but it didn’t seem to work for me (though that was quite a way beyond my skill level so I could have done that wrong!). Has anyone else got this sorted?
                                            rrrene
                                            first of all thanks for the great looking module.
                                            Unfortunately I don‘t get it up on my side…
                                            It doesnt‘t show anything no matter if I load your example ics or my iCloud calendar Url (is this supposed to work?)
                                            Below you can see my module config, maybe someone can help me out :)
                                            			maximumEntries: 6,
                                            					url: "http://calendarlabs.com/templates/ical/US-Holidays.ics"
                                            Thanks in advance.
                                            Best regards,
                                            René
                                            H 1 Reply Last reply
                                            • 3 / 6
