    MMM-MyCalendar
    109 Posts 40 Posters 163.6k Views 38 Watching
      I worked with @PCPAYN3 over chat to figure out this issue. For anyone else this might help, the problem was as follows:
      The following error came up in the log:
      Error: dates lower than Thu Jan 01 1970 00:00:00 GMT-0500 (EST) are not supported
      A bit of Googling pointed me to this thread:
      https://forum.magicmirror.builders/topic/2208/calendar-shows-no-entries-after-mm-update/29?page=3
      Apparently the problem is that there is an entry in the calendar that has a date prior to Jan 1, 1970. The solution was to edit the following file:
      /home/pi/MagicMirror/node_modules/rrule-alt/lib/rrule.js
      and change the ORDINAL_BASE property on line 56 to an earlier date.
      example, I changed:
      ORDINAL_BASE: new Date(1970, 0, 1),
      to
      ORDINAL_BASE: new Date(1900, 0, 1),
      and then the calendar worked.
      Z B 2 Replies Last reply Reply Quote 3
      • Z Offline
        zzaidi148 @j.e.f.f
        @j.e.f.f Hi Jeff! I love your module and its been easily booting up nicely. However, I tried adding two of my google calendars on it, and as I booted the module it up, it loaded and said no upcoming events. While today I dont have any events, tomorrow I do. I set the max number of days in the future to a huge number but stilll nothing. Any ideas?
        J C 2 Replies Last reply Reply Quote 1
          j.e.f.f Project Sponsor Module Developer @zzaidi148
          @zzaidi148 Can you confirm that you got your Gmail ICS link by following the instructions here?
          https://www.smsclientreminders.com/how_to_share_your_calendar_with_other_applications#google
          If so, send me a private message and I’ll troubleshoot your config.
            bmarofsky @j.e.f.f
            @j.e.f.f Thank You! Spent 3 days trying to figure this out after my SD card corrupted and I had to rebuild my MM.
            (making sure I remember where I store my backup .img)
              Buggy
              Hi all. Has someone seen this? Today ist the 4th. The second term is wrong “heute” (today) and the third term is correct “morgen” (tomorrow)
                A Former User @Buggy
                @Buggy
                I don’t know why creater leave this issue until now, but there is a hot-fix about that.
                https://github.com/jclarke0000/MMM-MyCalendar/issues/3
                B J 2 Replies Last reply Reply Quote 1
                  Buggy @Guest
                  @Sean Thank you. I will apply this hot-fix.
                    j.e.f.f Project Sponsor Module Developer @Guest
                    @Sean I’m currently moving to the UK, so I haven’t had time to fix this. If the hot fix worked for you, then great! I probably won’t get around to addressing this until sometime in the new year.
                    • N Offline
                      nitram @j.e.f.f
                      @j.e.f.f Hi all, firstly thanks for this module - it’s fab. I’m having the exact same issue as above with today/tomorrow not working properly. I tried applying the hotfix, but it didn’t seem to work for me (though that was quite a way beyond my skill level so I could have done that wrong!). Has anyone else got this sorted?
                        rrrene
                        first of all thanks for the great looking module.
                        Unfortunately I don‘t get it up on my side…
                        It doesnt‘t show anything no matter if I load your example ics or my iCloud calendar Url (is this supposed to work?)
                        Below you can see my module config, maybe someone can help me out :)
                        		module: "MMM-MyCalendar",
                        			maximumEntries: 6,
                        					url: "http://calendarlabs.com/templates/ical/US-Holidays.ics"
                        Thanks in advance.
                        Best regards,
                        René
                        • H Offline
                          Hotstepper @rrrene
                          • H Offline
                            Hotstepper
                            @rrrene said in MMM-MyCalendar:
                            I have had the same issue and have searched the error for a while…
                            My fault was, that the entry in the “MMM-Carousel”-Module in the slides-Section was missing.
                            So the Module wasn’t showing.
                            		module: 'MMM-Carousel',
                                            		slides: [
                                                				['MMM-MyCalendar',.....],
                            Best regards
                            Lutz
                            • F Offline
                              fabbr
                              alt text
                              I can’t find out why the left panel is stretched so much. when I turn this module off it goes back to normal. Any ideas?
                              Here’s my code:
                              		position: "top_left",	// This can be any of the regions. Best results in left or right regions.
                              				colored: true,
                              				maxTitleLength: 10,
                              				maximumEntries: 5,
                              				fade: true,
                              						url: 'webcal://mycalendar',
                              						symbol: 'calendar',
                              						color: "#6666ff"
                              						url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics",
                              						color: "#ffffcc"
                              • N Offline
                                ninjabreadman @fabbr
                                @fabbr There is nothing (iirc) that really constrains the MM regions … they expand to fit their content. Moreover, I think some modules aren’t written with a landscape orientation in mind. I suggest you try the following in your custom.css:
                                .module.MMM-MyCalendar {
                                min-width: 200px; /* adjust number as necessary */
                                Alternatively, you can try instead using:
                                .region.top.left {
                                max-width: 30%;
                                • F Offline
                                  fabbr @ninjabreadman
                                  @ninjabreadman Thank, that didn’t work however, I found the file MMM-MyCalendar.css and there I changed this and got my problem solved, thank you !!!
                                  .MMM-MyCalendar {
                                    max-width: 250px;  //original was 500
                                    j.e.f.f Project Sponsor Module Developer @fabbr
                                    @fabbr you’re better off putting this change in custom.css. If you update the module down the road, the change you made will be overwritten.
                                    A better solution here is to revert your change and set a width for the container, like as follows:
                                    region.left,
                                    region.left .module-content {
                                      width: 250px;
                                      max-width: 250px;
                                      min-width: 250px;
                                    This will size the entire left column to 250px, including anything you put in top_left, bottom_left, etc. If you want to limit it to just top_left replace region.left with region.top.left.
                                    F 1 Reply Last reply Reply Quote 2
                                    • F Offline
                                      fabbr @j.e.f.f
                                      @j.e.f.f I agree with you, however for some reason I can’t make that work. Did those changes worked on your custom.css? if yes, would you mind sharing your code with me? I might be doing something wrong.
                                        @fabbr Try also setting a maximum width for MMM-MyCalendar in your custom.css file as well. Here is exactly what I have in my custom.css file:
                                        .region.left,
                                        .region.left .module-content {
                                          width: 555px;
                                          max-width: 555px;
                                          min-width: 555px;
                                        .MMM-MyCalendar {
                                          max-width: 555px;
                                        Adjust 555px to whatever you like.
                                        • F Offline
                                          fabbr @j.e.f.f
                                          @j.e.f.f Very strange mine is completely ignoring the CSS. No change is made on the screen. Here’s my CSS:
                                           body {
                                            		 .region.left,
                                           			  width: 555px;
                                          			  max-width: 555px;
                                          			  min-width: 555px;
                                          		.MMM-MyCalendar {
                                          			  max-width: 555px;
                                          N F 2 Replies Last reply Reply Quote 0
                                          • N Offline
                                            @fabbr You can’t nest the braces in CSS. Just take out the body { and last } entirely.
                                            • 3 / 6
