    MMM-MyCalendar
    109 Posts 40 Posters 163.6k Views 38 Watching
      j.e.f.f Project Sponsor Module Developer @Guest
      @PCPAYN3 Can you confirm you installed the module by following these steps:
      1. Navigate to the MagicMirror/modules directory
      2. Execute git clone https://github.com/jclarke0000/MMM-MyCalendar.git
      3. Add the relevant configuration to config.js
      4. Restart Magic Mirror
      And yes, your post shows as deleted.
      ? 3 Replies Last reply Reply Quote 0
        A Former User @j.e.f.f
        @j.e.f.f Thanks @j-e-f-f no I didn’t do that, I have done it now. And trying it out. Sorry im new to this, and really appreciate your help.
          @j.e.f.f After reboot it is now showing the second calendar i entered for UK holidays but not the top one which was my google calendar :( any ideas?
            @j.e.f.f Sorry to keep bothering you, i have everything on the screen now apart from the google calender. Can i embed in as an iframe on the html page? As i am familiar with html.
              @PCPAYN3 google calendar should work – I’m using two separate google calendars with mine.
              You can confirm that you got your ics link by following these instructions?
              (full instructions here: https://www.smsclientreminders.com/how_to_share_your_calendar_with_other_applications#google)
                @j.e.f.f Hi jeff yes thats what ive done and got that link and still not showing. Do i edit the module to show this link? Or in the config file? As i tried to also edit the .js file in the MMM-Calendar module but it said permission denied when saving.
                  A Former User
                  As I know, private calendar sharing works only in Google Calendar. If you want to use calendar in other application, you should use public calendar. (I might be wrong.)
                    I worked with @PCPAYN3 over chat to figure out this issue. For anyone else this might help, the problem was as follows:
                    The following error came up in the log:
                    Error: dates lower than Thu Jan 01 1970 00:00:00 GMT-0500 (EST) are not supported
                    A bit of Googling pointed me to this thread:
                    https://forum.magicmirror.builders/topic/2208/calendar-shows-no-entries-after-mm-update/29?page=3
                    Apparently the problem is that there is an entry in the calendar that has a date prior to Jan 1, 1970. The solution was to edit the following file:
                    /home/pi/MagicMirror/node_modules/rrule-alt/lib/rrule.js
                    and change the ORDINAL_BASE property on line 56 to an earlier date.
                    example, I changed:
                    ORDINAL_BASE: new Date(1970, 0, 1),
                    to
                    ORDINAL_BASE: new Date(1900, 0, 1),
                    and then the calendar worked.
                    Z B 2 Replies Last reply Reply Quote 3
                    • Z Offline
                      zzaidi148 @j.e.f.f
                      @j.e.f.f Hi Jeff! I love your module and its been easily booting up nicely. However, I tried adding two of my google calendars on it, and as I booted the module it up, it loaded and said no upcoming events. While today I dont have any events, tomorrow I do. I set the max number of days in the future to a huge number but stilll nothing. Any ideas?
                      J C 2 Replies Last reply Reply Quote 1
                        j.e.f.f Project Sponsor Module Developer @zzaidi148
                        @zzaidi148 Can you confirm that you got your Gmail ICS link by following the instructions here?
                        If so, send me a private message and I’ll troubleshoot your config.
                          bmarofsky @j.e.f.f
                          @j.e.f.f Thank You! Spent 3 days trying to figure this out after my SD card corrupted and I had to rebuild my MM.
                          (making sure I remember where I store my backup .img)
                            Buggy
                            Hi all. Has someone seen this? Today ist the 4th. The second term is wrong “heute” (today) and the third term is correct “morgen” (tomorrow)
                              A Former User @Buggy
                              @Buggy
                              I don’t know why creater leave this issue until now, but there is a hot-fix about that.
                              https://github.com/jclarke0000/MMM-MyCalendar/issues/3
                              B J 2 Replies Last reply Reply Quote 1
                                Buggy @Guest
                                @Sean Thank you. I will apply this hot-fix.
                                  @Sean I’m currently moving to the UK, so I haven’t had time to fix this. If the hot fix worked for you, then great! I probably won’t get around to addressing this until sometime in the new year.
                                  • N Offline
                                    nitram @j.e.f.f
                                    @j.e.f.f Hi all, firstly thanks for this module - it’s fab. I’m having the exact same issue as above with today/tomorrow not working properly. I tried applying the hotfix, but it didn’t seem to work for me (though that was quite a way beyond my skill level so I could have done that wrong!). Has anyone else got this sorted?
                                      rrrene
                                      first of all thanks for the great looking module.
                                      Unfortunately I don‘t get it up on my side…
                                      It doesnt‘t show anything no matter if I load your example ics or my iCloud calendar Url (is this supposed to work?)
                                      Below you can see my module config, maybe someone can help me out :)
                                      		module: "MMM-MyCalendar",
                                      			maximumEntries: 6,
                                      					url: "http://calendarlabs.com/templates/ical/US-Holidays.ics"
                                      Thanks in advance.
                                      Best regards,
                                      René
                                      • H Offline
                                        Hotstepper @rrrene
                                        • H Offline
                                          Hotstepper
                                          @rrrene said in MMM-MyCalendar:
                                          I have had the same issue and have searched the error for a while…
                                          My fault was, that the entry in the “MMM-Carousel”-Module in the slides-Section was missing.
                                          So the Module wasn’t showing.
                                          		module: 'MMM-Carousel',
                                                          		slides: [
        ['MMM-MyCalendar',.....],
                                          Best regards
                                          Lutz
                                          • F Offline
                                            fabbr
                                            alt text
                                            I can’t find out why the left panel is stretched so much. when I turn this module off it goes back to normal. Any ideas?
                                            Here’s my code:
                                            		position: "top_left",	// This can be any of the regions. Best results in left or right regions.
                                            				colored: true,
                                            				maxTitleLength: 10,
                                            				maximumEntries: 5,
                                            				fade: true,
                                            						url: 'webcal://mycalendar',
                                            						symbol: 'calendar',
                                            						color: "#6666ff"
                                            						url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics",
                                            						color: "#ffffcc"
                                            • 3 / 6
