    MMM-MyCalendar
    109 Posts 40 Posters 167.3k Views 38 Watching
    • Z
      zzaidi148 @j.e.f.f
      @j.e.f.f Hi Jeff! I love your module and its been easily booting up nicely. However, I tried adding two of my google calendars on it, and as I booted the module it up, it loaded and said no upcoming events. While today I dont have any events, tomorrow I do. I set the max number of days in the future to a huge number but stilll nothing. Any ideas?
      J C 2 Replies Last reply
        j.e.f.f Project Sponsor Module Developer @zzaidi148
        @zzaidi148 Can you confirm that you got your Gmail ICS link by following the instructions here?
        https://www.smsclientreminders.com/how_to_share_your_calendar_with_other_applications#google
        If so, send me a private message and I’ll troubleshoot your config.
          bmarofsky @j.e.f.f
          @j.e.f.f Thank You! Spent 3 days trying to figure this out after my SD card corrupted and I had to rebuild my MM.
          (making sure I remember where I store my backup .img)
            Buggy
            Hi all. Has someone seen this? Today ist the 4th. The second term is wrong “heute” (today) and the third term is correct “morgen” (tomorrow)
            ? 1 Reply Last reply
              A Former User @Buggy
              @Buggy
              I don’t know why creater leave this issue until now, but there is a hot-fix about that.
              https://github.com/jclarke0000/MMM-MyCalendar/issues/3
              B J 2 Replies Last reply
                Buggy @Guest
                @Sean Thank you. I will apply this hot-fix.
                  j.e.f.f Project Sponsor Module Developer @Guest
                  @Sean I’m currently moving to the UK, so I haven’t had time to fix this. If the hot fix worked for you, then great! I probably won’t get around to addressing this until sometime in the new year.
                  N 1 Reply Last reply
                  • N
                    nitram @j.e.f.f
                    @j.e.f.f Hi all, firstly thanks for this module - it’s fab. I’m having the exact same issue as above with today/tomorrow not working properly. I tried applying the hotfix, but it didn’t seem to work for me (though that was quite a way beyond my skill level so I could have done that wrong!). Has anyone else got this sorted?
                      rrrene
                      first of all thanks for the great looking module.
                      Unfortunately I don‘t get it up on my side…
                      It doesnt‘t show anything no matter if I load your example ics or my iCloud calendar Url (is this supposed to work?)
                      Below you can see my module config, maybe someone can help me out :)
                      		module: "MMM-MyCalendar",
                      			maximumEntries: 6,
                      					url: "http://calendarlabs.com/templates/ical/US-Holidays.ics"
                      Thanks in advance.
                      Best regards,
                      René
                      H 1 Reply Last reply
                      • H
                        Hotstepper @rrrene
                        • H
                          Hotstepper
                          @rrrene said in MMM-MyCalendar:
                          I have had the same issue and have searched the error for a while…
                          My fault was, that the entry in the “MMM-Carousel”-Module in the slides-Section was missing.
                          So the Module wasn’t showing.
                          		module: 'MMM-Carousel',
                                          		slides: [
                                              				['MMM-MyCalendar',.....],
                          Best regards
                          Lutz
                          • F
                            fabbr
                            alt text
                            I can’t find out why the left panel is stretched so much. when I turn this module off it goes back to normal. Any ideas?
                            Here’s my code:
                            		position: "top_left",	// This can be any of the regions. Best results in left or right regions.
                            				colored: true,
                            				maxTitleLength: 10,
                            				maximumEntries: 5,
                            				fade: true,
                            						url: 'webcal://mycalendar',
                            						symbol: 'calendar',
                            						color: "#6666ff"
                            						url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics",
                            						color: "#ffffcc"
                            • N
                              ninjabreadman @fabbr
                              @fabbr There is nothing (iirc) that really constrains the MM regions … they expand to fit their content. Moreover, I think some modules aren’t written with a landscape orientation in mind. I suggest you try the following in your custom.css:
                              .module.MMM-MyCalendar {
                              min-width: 200px; /* adjust number as necessary */
                              Alternatively, you can try instead using:
                              .region.top.left {
                              max-width: 30%;
                              F 1 Reply Last reply
                              • F
                                fabbr @ninjabreadman
                                @ninjabreadman Thank, that didn’t work however, I found the file MMM-MyCalendar.css and there I changed this and got my problem solved, thank you !!!
                                .MMM-MyCalendar {
                                  max-width: 250px;  //original was 500
                                J 1 Reply Last reply
                                  j.e.f.f Project Sponsor Module Developer @fabbr
                                  @fabbr you’re better off putting this change in custom.css. If you update the module down the road, the change you made will be overwritten.
                                  A better solution here is to revert your change and set a width for the container, like as follows:
                                  region.left,
                                  region.left .module-content {
                                    width: 250px;
                                    max-width: 250px;
                                    min-width: 250px;
                                  This will size the entire left column to 250px, including anything you put in top_left, bottom_left, etc. If you want to limit it to just top_left replace region.left with region.top.left.
                                  Reply Quote 2
                                  • F
                                    fabbr @j.e.f.f
                                    @j.e.f.f I agree with you, however for some reason I can’t make that work. Did those changes worked on your custom.css? if yes, would you mind sharing your code with me? I might be doing something wrong.
                                      @fabbr Try also setting a maximum width for MMM-MyCalendar in your custom.css file as well. Here is exactly what I have in my custom.css file:
                                      .region.left,
                                      .region.left .module-content {
                                        width: 555px;
                                        max-width: 555px;
                                        min-width: 555px;
                                      .MMM-MyCalendar {
                                        max-width: 555px;
                                      Adjust 555px to whatever you like.
                                      • F
                                        fabbr @j.e.f.f
                                        @j.e.f.f Very strange mine is completely ignoring the CSS. No change is made on the screen. Here’s my CSS:
                                         body {
                                          		 .region.left,
                                         			  width: 555px;
                                        			  max-width: 555px;
                                        			  min-width: 555px;
                                        		.MMM-MyCalendar {
                                        			  max-width: 555px;
                                        N F 2 Replies Last reply
                                        • N
                                          @fabbr You can’t nest the braces in CSS. Just take out the body { and last } entirely.
                                          • F
                                            fabbr @fabbr
                                            @fabbr LoL
                                            Body {
                                            Was there, no I was under the impression all the changed were going to be inside the brackets. Sorry it was always my fault. Thank you so much for the help. It now works perfectly!
                                            • 3 / 6
