    Possible Error in My Code?
    18 Posts 4 Posters 6.8k Views 3 Watching
    • cowboysdudeC Offline
      @Wiltify said in Possible Error in My Code?:
      module: “clock”,
      position: “top_left”
      Yes after this line in your config you didn’t add the coma
                position: 'top_left',
      W 1 Reply Last reply Reply Quote 1
        Mykle1 Project Sponsor Module Developer @Wiltify
        Needs a comma position: "top_left",
        • W Offline
          Wiltify @Mykle1
          @Mykle1
          Thank you, humbling moment of the day.
            No worries, mate. We’ve all been there.
              You’re welcome…
              • W Offline
                Wiltify @cowboysdude
                @cowboysdude Jeez, I didn’t even see this, sorry… Thank you!!
                  Cowboysdude is a freakin Guru!
                  • W Offline
                    Wiltify
                    I don’t know if I downloaded the fitbit module correct, something maybe wrong in my code first?
                     * MIT Licensed.
                    var config = {
                            port: 8080,
                            language: "en",
                            timeFormat: 24,
                            units: "imperial",
                                            module: "alert",
                                            module: "updatenotification",
                                            position: "top_bar"
                                            module: "clock",
                                                    timeFormat: "12",
                                                    displaySeconds: "false",
                                                    showPeriod: "true",
                                                    timezone: "America/New_York"
                                            module: "currentweather",
                                                    locationID: "4839416",  //ID from http://www.openweathermap.org/help/city_list.txt
                                                    appid: "a8fcb80620f43f70c4e6141e5e0f09dc",
                                                    units: "imperial",
                                                    roundTemp: "true",
                                                    degreeLabel: "true",
                                                    showHumidity: "true"
                                            module: "weatherforecast",
                                                    appid:"a8fcb80620f43f70c4e6141e5e0f09dc",
                                                    units: "imperial",
                                                    roundTemp: "true",
                                                    showRainAmount: "true"
                                            module: 'MMM-fitbit',
                                            position: 'top_center',
                                            config: [
                                                    credentials: {
                                                            client_id: ,
                                                            client_secret: ,
                                                    resources: [
                                                            'steps',
                                                            'floors',
                                                            'caloriesOut',
                                                            'distance',
                                                            'activeMinutes',
                                                            'sleep',
                                                            'heart'
                                                    update_interval: 60
                      @Wiltify
                      Completely missing for the bottom
                      • W Offline
                        Wiltify @Mykle1
                        @Mykle1 I have that, must not have copied when I brought it into here, whoops…
