    Possible Error in My Code?
    18 Posts 4 Posters 6.7k Views 3 Watching
    • cowboysdudeC Offline
      You’re welcome…
      • W Offline
        Wiltify @cowboysdude
        @cowboysdude Jeez, I didn’t even see this, sorry… Thank you!!
          Mykle1 Project Sponsor Module Developer @Wiltify
          @Wiltify said in Possible Error in My Code?:
          Cowboysdude is a freakin Guru!
          • W Offline
            Wiltify
            I don’t know if I downloaded the fitbit module correct, something maybe wrong in my code first?
             * MIT Licensed.
            var config = {
                    port: 8080,
                    language: "en",
                    timeFormat: 24,
                    units: "imperial",
                                    module: "alert",
                                    module: "updatenotification",
                                    position: "top_bar"
                                    module: "clock",
                                            timeFormat: "12",
                                            displaySeconds: "false",
                                            showPeriod: "true",
                                            timezone: "America/New_York"
                                    module: "currentweather",
                                            locationID: "4839416",  //ID from http://www.openweathermap.org/help/city_list.txt
                                            appid: "a8fcb80620f43f70c4e6141e5e0f09dc",
                                            units: "imperial",
                                            roundTemp: "true",
                                            degreeLabel: "true",
                                            showHumidity: "true"
                                    module: "weatherforecast",
                                            appid:"a8fcb80620f43f70c4e6141e5e0f09dc",
                                            units: "imperial",
                                            roundTemp: "true",
                                            showRainAmount: "true"
                                    module: 'MMM-fitbit',
                                    position: 'top_center',
                                    config: [
                                            credentials: {
                                                    client_id: ,
                                                    client_secret: ,
                                            resources: [
                                                    'steps',
                                                    'floors',
                                                    'caloriesOut',
                                                    'distance',
                                                    'activeMinutes',
                                                    'sleep',
                                                    'heart'
                                            update_interval: 60
              @Wiltify
              Completely missing for the bottom
              • W Offline
                Wiltify @Mykle1
                @Mykle1 I have that, must not have copied when I brought it into here, whoops…
                  @Wiltify
                  I assume you removed the client id and client secret for this post?
                  • W Offline
                    Wiltify @Mykle1
                    @Mykle1 Yes, but the module site has them inside of brackets instead of quatations, does that vary between developers formatting?
                      @Wiltify
                      I’m not familiar with this module. Try it as shown in the README. Try it without the brackets shown. Try it with quotes and without.
                      There are also some differences between your entry and this entry from the module site, as you call it. Can you see them? Correct them and try again. :-)
                      	config: [
                      		credentials: {
                      			client_id: ,
                      			client_secret: ,
                      		resources: [
                      			'steps',
                      			'floors',
                      			'caloriesOut',
                      			'distance',
                      			'activeMinutes',
                      			'sleep',
                      			'heart'
                      		update_interval: 60
                        A Former User
                        config: [] ???
                        Usually config field is not array. So I think {} is right.
