    Nothing showing but app is running
    16 Posts 6 Posters 11.3k Views 6 Watching
      mortenbirkelund @fiskaren
      @fiskaren Then i dont know what could be wrong. Perhaps someone else will see this post and can point you in the right direction.
      Your solution will start MM each time the computer is started, where pm2 will only start MM, if it was running when the reboot was initiated. But if it works for you.
        dikkedimi
        updated today and now I have a similar issue. App is running but the screen is black. Ran apt-get update & apt-get upgrade in the hopes it would fix itself, but nope :)
        pi@jarvis:~ $ pm2 log
        /home/pi/.pm2/pm2.log last 15 lines:
        PM2        | 2017-04-02 18:19:27: PM2 PID file         : /home/pi/.pm2/pm2.pid
        PM2        | 2017-04-02 18:19:27: RPC socket file      : /home/pi/.pm2/rpc.sock
        PM2        | 2017-04-02 18:19:27: BUS socket file      : /home/pi/.pm2/pub.sock
        PM2        | 2017-04-02 18:19:27: Application log path : /home/pi/.pm2/logs
        PM2        | 2017-04-02 18:19:27: Process dump file    : /home/pi/.pm2/dump.pm2
        PM2        | 2017-04-02 18:19:27: Concurrent actions   : 2
        PM2        | 2017-04-02 18:19:27: SIGTERM timeout      : 1600
        PM2        | 2017-04-02 18:19:27: ===============================================================================
        PM2        | 2017-04-02 18:19:27: Starting execution sequence in -fork mode- for app name:mm id:0
        PM2        | 2017-04-02 18:19:27: App name:mm id:0 online
        PM2        | 2017-04-02 18:21:20: Stopping app:mm id:0
        PM2        | 2017-04-02 18:21:20: App [mm] with id [0] and pid [1474], exited with code [0] via signal [SIGINT]
        PM2        | 2017-04-02 18:21:20: pid=1474 msg=process killed
        PM2        | 2017-04-02 18:26:49: Starting execution sequence in -fork mode- for app name:mm id:0
        PM2        | 2017-04-02 18:26:49: App name:mm id:0 online
        /home/pi/.pm2/logs/mm-error-0.log last 15 lines:
        0|mm       |
        0|mm       |
        0|mm       | error: cannot open .git/FETCH_HEAD: Permission denied
        0|mm       |
        0|mm       |
        0|mm       | [29012:0402/175739.310033:FATAL:bus.cc(1197)] D-Bus connection was disconnected. Aborting.
        0|mm       | #0 0x0000011cf88c
        0|mm       | #1 0x0000011bbc1a
        0|mm       | #2 0x000001e9a6b6
        0|mm       |
        0|mm       | [1665:0402/181857.627309:FATAL:bus.cc(1197)] D-Bus connection was disconnected. Aborting.
        0|mm       |
        /home/pi/.pm2/logs/mm-out-0.log last 15 lines:
        0|mm       | Initializing new module helper ...
        0|mm       | Module helper loaded: calendar
        0|mm       | No helper found for module: currentweather.
        0|mm       | No helper found for module: airquality.
        0|mm       | No helper found for module: weatherforecast.
        0|mm       | No helper found for module: MMM-Hue.
        0|mm       | All module helpers loaded.
        0|mm       | Starting server on port 8666 ...
        0|mm       | Starting server op port 8666 ...
        0|mm       | Server started ...
        0|mm       | Connecting socket for: updatenotification
        0|mm       | Connecting socket for: calendar
        0|mm       | Starting node helper for: calendar
        0|mm       | Sockets connected & modules started ...
        0|mm       | Launching application.
        [STREAMING] Now streaming realtime logs for [all] processes
        pi@jarvis:~ $ tail -f /home/pi/.pm2/logs/mm-error-0.log
        #0 0x0000011cf88c
        #1 0x0000011bbc1a
        #2 0x000001e9a6b6
        #0 0x0000011cf88c
        #1 0x0000011bbc1a
        #2 0x000001e9a6b6
          d3r @dikkedimi
          @dikkedimi said in Nothing showing but app is running:
          0|mm       |
          0|mm       |
          0|mm       |
          0|mm       |
          0|mm       |
          0|mm       |
          #0 0x0000011cf88c
          #1 0x0000011bbc1a
          #2 0x000001e9a6b6
          #0 0x0000011cf88c
          #1 0x0000011bbc1a
          #2 0x000001e9a6b6
          I have the same problem as you. I run the server on a pi zero and the the display is on a pi3 on the same network. It loads fine without any erros on the pi zero but when I go to the website I only get a black screen.
          • F Offline
            Fix Not Found @d3r
            @d3r @fiskaren having this issue for a school project right now. Did you two ever have any sucess fixing it?
            D Mykle1M F 3 Replies Last reply Reply Quote 0
              d3r @Fix Not Found
              @Fix-Not-Found I’ve got everything on a pi3 now not sure how I fixed this back then.
                Mykle1 Project Sponsor Module Developer @Fix Not Found
                @Fix-Not-Found said in Nothing showing but app is running:
                Are there any errors being reported in your terminal or dev console? If so, post them here
                • F Offline
                  fiskaren @Fix Not Found
                  @Fix-Not-Found I did not. But after formating and reinstalling it worked just fine. No idea what the problem was!
                  Mykle1M F 2 Replies Last reply Reply Quote 0
                    Mykle1 Project Sponsor Module Developer @fiskaren
                    @fiskaren
                    All’s well that ends well.
                    • F Offline
                      Fix Not Found @fiskaren
                      @fiskaren I’m going to attempt the above comment next class, but in the meantime, how would I go about that?
                        I don’t know that formatting is necessary. However, you could try this and know if you were successful in less than an hour.
                        https://forum.magicmirror.builders/topic/5274/how-to-manually-install-mm-on-your-pi-for-absolute-beginners
