Solved Setting up Magic Mirror remotely?
tried again today with the hdmi screen, it got to where it said something about it was loading a file that had 715 at the end and froze. so restarted removed the folder, and restarted installing remotely. it got to loading depandencies and gave me this :
Installing dependencies …
npm WARN prefer global coffee-script@1.10.0 should be installed with -g
npm WARN prefer global jsonlint@1.6.2 should be installed with -guws@0.14.5 install /home/pi/MagicMirror/node_modules/uws
node-gyp rebuild > build_log.txt 2>&1 || exit 0
Unable to install dependencies!tried starting npm remotely got this:
pi@raspberrypi:~ $ npm start
npm ERR! Linux 4.9.35-v7+
npm ERR! argv “/usr/bin/node” “/usr/bin/npm” “start”
npm ERR! node v6.11.5
npm ERR! npm v3.10.10
npm ERR! code ENOENT
npm ERR! errno -2
npm ERR! syscall open
npm ERR! enoent ENOENT: no such file or directory, open ‘/home/pi/package.json’
npm ERR! enoent This is most likely not a problem with npm itself
npm ERR! enoent and is related to npm not being able to find a file.
npm ERR! enoent
npm ERR! /home/pi/npm-debug.logtried starting from the hdmi screen same thing.
tried starting from with the magicmirror folder, got this:
magicmirror@2.1.3 start /home/pi/MagicMirror
sh run-start.sh
/home/pi/MagicMirror/node_modules/electron/index.js:9
throw new Error(‘Electron failed to install correctly, please delete node_modules/electron and try installing again’)
Error: Electron failed to install correctly, please delete node_modules/electron and try installing again
at Object. (/home/pi/MagicMirror/node_modules/electron/index.js:9:9)
at Module._compile (module.js:570:32)
at Object.Module._extensions…js (module.js:579:10)
at Module.load (module.js:487:32)
at tryModuleLoad (module.js:446:12)
at Function.Module._load (module.js:438:3)
at Module.require (module.js:497:17)
at require (internal/module.js:20:19)
at Object. (/home/pi/MagicMirror/node_modules/electron/cli.js:3:16)
npm ERR! code ELIFECYCLE
npm ERR! magicmirror@2.1.3 start:sh run-start.sh
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the magicmirror@2.1.3 start script ‘sh run-start.sh’.
npm ERR! If you do, this is most likely a problem with the magicmirror package,
npm ERR! not with npm itself.
npm ERR! sh run-start.sh
npm ERR! npm bugs magicmirror
npm ERR! Or if that isn’t available, you can get their info via:
npm ERR! npm owner ls magicmirror
npm ERR! /home/pi/MagicMirror/npm-debug.log
Can anyone point me in the direction to correct? I have already upgraded Node.js so i know it cant be that.npm-bug.log:
1 verbose cli [ ‘/usr/bin/node’, ‘/usr/bin/npm’, ‘start’ ]
2 info using npm@3.10.10
3 info using node@v6.11.5
4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
5 info lifecycle magicmirror@2.1.3~prestart: magicmirror@2.1.3
6 silly lifecycle magicmirror@2.1.3~prestart: no script for prestart, continuing
7 info lifecycle magicmirror@2.1.3~start: magicmirror@2.1.3
8 verbose lifecycle magicmirror@2.1.3~start: unsafe-perm in lifecycle true
9 verbose lifecycle magicmirror@2.1.3~start: PATH: /usr/lib/node_modules/npm/bi$
10 verbose lifecycle magicmirror@2.1.3~start: CWD: /home/pi/MagicMirror
11 silly lifecycle magicmirror@2.1.3~start: Args: [ ‘-c’, ‘sh run-start.sh’ ]
12 silly lifecycle magicmirror@2.1.3~start: Returned: code: 1 signal: null
13 info lifecycle magicmirror@2.1.3~start: Failed to exec start script
14 verbose stack Error: magicmirror@2.1.3 start:sh run-start.sh
14 verbose stack Exit status 1
14 verbose stack at EventEmitter. (/usr/lib/node_modules/npm/lib$
14 verbose stack at emitTwo (events.js:106:13)
14 verbose stack at EventEmitter.emit (events.js:191:7)
[ Read 45 lines ] -
@navyvette87 said in Setting up Magic Mirror remotely?:
pi@raspberrypi:~ $ npm startYou would need to
cd MagicMirror
to change into your MagicMirror directory first, then runnpm start
Went back to the website and read, and found something about npm install, so ran that, it looked like it installed something, then ran npm start again and got:
sh run-start.sh
npm ERR!
pi@raspberrypi:~/MagicMirror $npm-debug.log
1 verbose cli [ ‘/usr/bin/node’, ‘/usr/bin/npm’, ‘start’, ‘dev’ ]
11 silly lifecycle magicmirror@2.1.3~start: Args: [ ‘-c’, 'sh run-start.sh "dev$
14 verbose stack Error: magicmirror@2.1.3 start:sh run-start.sh "dev"
[ Read 45 lines ] -
Terminal is telling what happened and you what to do here.
Go into your MagicMirror folder, then into the node_modules folder, then DELETE the electron folder.
Then run
npm install
again in the MagicMirror directory -
ok read some on the repository, was able to run the serveronly and got this
Magic Mirror2
Please create a config file.
See README for more information.
If you get this message while your config file is already
created, your config file probably contains an error.
Use a JavaScript linter to validate your file.what next?
Look at the bottom left of my post. Click on Create a working config
I got it to work, but then I went through the pi setup stuff to turn on the screensaver and wifi sleep, now when i tried to reboot, it says
[FAILED] Failed to start Light Display Manager
SSH is enabled and the default password for the ‘pi’ user has not been changed. This is a security risk - please login as the ‘pi’ user and type passwd to set a new password.
pi@raspberrypi: $How do i get it to continue to the desktop screen?
I’ve never encountered that before. Maybe, revert the changes you just made, get your mirror running, then try them again, 1 at a time
fixed the light display thing by rebooting with hdmi unplugged, then repluging it in, then rebooting, but the ssh message still there
@navyvette87
It means as written. Change your password with commandpasswd
just trypasswd
in your terminal.
