    Setting up Magic Mirror remotely?
    Scheduled Pinned Locked Moved Solved General Discussion
    16 Posts 5 Posters 7.6k Views 5 Watching
    • Y
      yawns Moderator
      Did you access your PI via ssh (putty for example)? Or did you use vnc to actually see the screen?
      Both ways should be fine for installation, only running the MagicMirror via ssh is a bit tricky as you have to tell MagicMirror which display to use.
      N 1 Reply Last reply
      • N
        navyvette87 @yawns
        @yawns Via VNC, It froze when it did the two warnings. the pi prompt never returned. I just shut it down. Had to leave. Will try again when I have time, next time via the hdmi screen.
        • N
          navyvette87
          tried again today with the hdmi screen, it got to where it said something about it was loading a file that had 715 at the end and froze. so restarted removed the folder, and restarted installing remotely. it got to loading depandencies and gave me this :
          Installing dependencies …
          npm WARN prefer global coffee-script@1.10.0 should be installed with -g
          npm WARN prefer global jsonlint@1.6.2 should be installed with -g
          uws@0.14.5 install /home/pi/MagicMirror/node_modules/uws
          node-gyp rebuild > build_log.txt 2>&1 || exit 0
          Unable to install dependencies!
          tried starting npm remotely got this:
          pi@raspberrypi:~ $ npm start
          npm ERR! Linux 4.9.35-v7+
          npm ERR! argv “/usr/bin/node” “/usr/bin/npm” “start”
          npm ERR! node v6.11.5
          npm ERR! npm v3.10.10
          npm ERR! code ENOENT
          npm ERR! errno -2
          npm ERR! syscall open
          npm ERR! enoent ENOENT: no such file or directory, open ‘/home/pi/package.json’
          npm ERR! enoent This is most likely not a problem with npm itself
          npm ERR! enoent and is related to npm not being able to find a file.
          npm ERR! enoent
          npm ERR! /home/pi/npm-debug.log
          tried starting from the hdmi screen same thing.
          tried starting from with the magicmirror folder, got this:
          magicmirror@2.1.3 start /home/pi/MagicMirror
          sh run-start.sh
          /home/pi/MagicMirror/node_modules/electron/index.js:9
          throw new Error(‘Electron failed to install correctly, please delete node_modules/electron and try installing again’)
          Error: Electron failed to install correctly, please delete node_modules/electron and try installing again
          at Object. (/home/pi/MagicMirror/node_modules/electron/index.js:9:9)
          at Module._compile (module.js:570:32)
          at Object.Module._extensions…js (module.js:579:10)
          at Module.load (module.js:487:32)
          at tryModuleLoad (module.js:446:12)
          at Function.Module._load (module.js:438:3)
          at Module.require (module.js:497:17)
          at require (internal/module.js:20:19)
          at Object. (/home/pi/MagicMirror/node_modules/electron/cli.js:3:16)
          npm ERR! code ELIFECYCLE
          npm ERR! magicmirror@2.1.3 start: sh run-start.sh
          npm ERR! Exit status 1
          npm ERR!
          npm ERR! Failed at the magicmirror@2.1.3 start script ‘sh run-start.sh’.
          npm ERR! If you do, this is most likely a problem with the magicmirror package,
          npm ERR! not with npm itself.
          npm ERR! sh run-start.sh
          npm ERR! npm bugs magicmirror
          npm ERR! Or if that isn’t available, you can get their info via:
          npm ERR! npm owner ls magicmirror
          npm ERR! /home/pi/MagicMirror/npm-debug.log
          Can anyone point me in the direction to correct? I have already upgraded Node.js so i know it cant be that.
          npm-bug.log:
          1 verbose cli [ ‘/usr/bin/node’, ‘/usr/bin/npm’, ‘start’ ]
          2 info using npm@3.10.10
          3 info using node@v6.11.5
          4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
          5 info lifecycle magicmirror@2.1.3~prestart: magicmirror@2.1.3
          6 silly lifecycle magicmirror@2.1.3~prestart: no script for prestart, continuing
          7 info lifecycle magicmirror@2.1.3~start: magicmirror@2.1.3
          8 verbose lifecycle magicmirror@2.1.3~start: unsafe-perm in lifecycle true
          9 verbose lifecycle magicmirror@2.1.3~start: PATH: /usr/lib/node_modules/npm/bi$
          10 verbose lifecycle magicmirror@2.1.3~start: CWD: /home/pi/MagicMirror
          11 silly lifecycle magicmirror@2.1.3~start: Args: [ ‘-c’, ‘sh run-start.sh’ ]
          12 silly lifecycle magicmirror@2.1.3~start: Returned: code: 1 signal: null
          13 info lifecycle magicmirror@2.1.3~start: Failed to exec start script
          14 verbose stack Error: magicmirror@2.1.3 start: sh run-start.sh
          14 verbose stack Exit status 1
          14 verbose stack at EventEmitter. (/usr/lib/node_modules/npm/lib$
          14 verbose stack at emitTwo (events.js:106:13)
          14 verbose stack at EventEmitter.emit (events.js:191:7)
          [ Read 45 lines ]
          Mykle1M 1 Reply Last reply
          • Mykle1M
            Mykle1 Project Sponsor Module Developer @navyvette87
            @navyvette87 said in Setting up Magic Mirror remotely?:
            You would need to cd MagicMirror to change into your MagicMirror directory first, then run npm start
            • N
              navyvette87
              Went back to the website and read, and found something about npm install, so ran that, it looked like it installed something, then ran npm start again and got:
              sh run-start.sh
              npm ERR!
              npm-debug.log
              1 verbose cli [ ‘/usr/bin/node’, ‘/usr/bin/npm’, ‘start’, ‘dev’ ]
              11 silly lifecycle magicmirror@2.1.3~start: Args: [ ‘-c’, 'sh run-start.sh "dev$
              14 verbose stack Error: magicmirror@2.1.3 start: sh run-start.sh "dev"
              [ Read 45 lines ]
              • Mykle1M
                Terminal is telling what happened and you what to do here.
                Go into your MagicMirror folder, then into the node_modules folder, then DELETE the electron folder.
                Then run npm install again in the MagicMirror directory
                • N
                  navyvette87
                  ok read some on the repository, was able to run the serveronly and got this
                  Magic Mirror2
                  Please create a config file.
                  See README for more information.
                  If you get this message while your config file is already
                  created, your config file probably contains an error.
                  Use a JavaScript linter to validate your file.
                  what next?
                  • Mykle1M
                    @navyvette87
                    Look at the bottom left of my post. Click on Create a working config
                    • N
                      navyvette87
                      I got it to work, but then I went through the pi setup stuff to turn on the screensaver and wifi sleep, now when i tried to reboot, it says
                      [FAILED] Failed to start Light Display Manager
                      SSH is enabled and the default password for the ‘pi’ user has not been changed. This is a security risk - please login as the ‘pi’ user and type passwd to set a new password.
                      pi@raspberrypi: $
                      How do i get it to continue to the desktop screen?
                      • Mykle1M
                        @navyvette87
                        I’ve never encountered that before. Maybe, revert the changes you just made, get your mirror running, then try them again, 1 at a time
                        • N
                          navyvette87
                          fixed the light display thing by rebooting with hdmi unplugged, then repluging it in, then rebooting, but the ssh message still there
                          ? 1 Reply Last reply
                            A Former User @navyvette87
                            @navyvette87
                            It means as written. Change your password with command passwd.
                            just try passwd in your terminal.
                            • N
                              navyvette87 @Guest
                              @Sean It ended up being one of the changes I made to set up the pi for the screensaver edit. I did try passwd though. thanks eveyone. I got it up and running. I have another post for a module problem, once I get that figured out, I will start on the hardware.
                              • MikgaboM
                                Mikgabo
                                Hey guys,
                                Noob question…
                                So, I’m running MM2 on my Pi Zero W and can’t figure out home to get to my config.js through terminal. Can someone help me out???
                                Cheers,
                                Mike
                                MikgaboM 1 Reply Last reply
                                • MikgaboM
                                  Mikgabo @Mikgabo
                                  NEVER MIND…FIGURED IT OUT :)
