    Setting up Magic Mirror remotely?
    Scheduled Pinned Locked Moved Solved General Discussion
    16 Posts 5 Posters 7.6k Views 5 Watching
    • N
      navyvette87
      Went back to the website and read, and found something about npm install, so ran that, it looked like it installed something, then ran npm start again and got:
      magicmirror@2.1.3 start /home/pi/MagicMirror
      sh run-start.sh
      /home/pi/MagicMirror/node_modules/electron/index.js:9
      throw new Error(‘Electron failed to install correctly, please delete node_modules/electron and try installing again’)
      Error: Electron failed to install correctly, please delete node_modules/electron and try installing again
      at Object. (/home/pi/MagicMirror/node_modules/electron/index.js:9:9)
      at Module._compile (module.js:570:32)
      at Object.Module._extensions…js (module.js:579:10)
      at Module.load (module.js:487:32)
      at tryModuleLoad (module.js:446:12)
      at Function.Module._load (module.js:438:3)
      at Module.require (module.js:497:17)
      at require (internal/module.js:20:19)
      at Object. (/home/pi/MagicMirror/node_modules/electron/cli.js:3:16)
      npm ERR! Linux 4.9.35-v7+
      npm ERR! argv “/usr/bin/node” “/usr/bin/npm” “start”
      npm ERR! node v6.11.5
      npm ERR! npm v3.10.10
      npm ERR! code ELIFECYCLE
      npm ERR! magicmirror@2.1.3 start: sh run-start.sh
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the magicmirror@2.1.3 start script ‘sh run-start.sh’.
      npm ERR! If you do, this is most likely a problem with the magicmirror package,
      npm ERR! not with npm itself.
      npm ERR! sh run-start.sh
      npm ERR! npm bugs magicmirror
      npm ERR! Or if that isn’t available, you can get their info via:
      npm ERR! npm owner ls magicmirror
      npm ERR! /home/pi/MagicMirror/npm-debug.log
      pi@raspberrypi:~/MagicMirror $
      npm-debug.log
      1 verbose cli [ ‘/usr/bin/node’, ‘/usr/bin/npm’, ‘start’, ‘dev’ ]
      2 info using npm@3.10.10
      3 info using node@v6.11.5
      4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
      5 info lifecycle magicmirror@2.1.3~prestart: magicmirror@2.1.3
      6 silly lifecycle magicmirror@2.1.3~prestart: no script for prestart, continuing
      7 info lifecycle magicmirror@2.1.3~start: magicmirror@2.1.3
      8 verbose lifecycle magicmirror@2.1.3~start: unsafe-perm in lifecycle true
      9 verbose lifecycle magicmirror@2.1.3~start: PATH: /usr/lib/node_modules/npm/bi$
      10 verbose lifecycle magicmirror@2.1.3~start: CWD: /home/pi/MagicMirror
      11 silly lifecycle magicmirror@2.1.3~start: Args: [ ‘-c’, 'sh run-start.sh "dev$
      12 silly lifecycle magicmirror@2.1.3~start: Returned: code: 1 signal: null
      13 info lifecycle magicmirror@2.1.3~start: Failed to exec start script
      14 verbose stack Error: magicmirror@2.1.3 start: sh run-start.sh "dev"
      14 verbose stack Exit status 1
      14 verbose stack at EventEmitter. (/usr/lib/node_modules/npm/lib$
      14 verbose stack at emitTwo (events.js:106:13)
      14 verbose stack at EventEmitter.emit (events.js:191:7)
      [ Read 45 lines ]
      Mykle1M 1 Reply Last reply
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @navyvette87
        @navyvette87 said in Setting up Magic Mirror remotely?:
        Terminal is telling what happened and you what to do here.
        Go into your MagicMirror folder, then into the node_modules folder, then DELETE the electron folder.
        Then run npm install again in the MagicMirror directory
        • N
          navyvette87
          ok read some on the repository, was able to run the serveronly and got this
          Magic Mirror2
          Please create a config file.
          See README for more information.
          If you get this message while your config file is already
          created, your config file probably contains an error.
          Use a JavaScript linter to validate your file.
          what next?
          • Mykle1M
            @navyvette87
            Look at the bottom left of my post. Click on Create a working config
            • N
              navyvette87
              I got it to work, but then I went through the pi setup stuff to turn on the screensaver and wifi sleep, now when i tried to reboot, it says
              [FAILED] Failed to start Light Display Manager
              SSH is enabled and the default password for the ‘pi’ user has not been changed. This is a security risk - please login as the ‘pi’ user and type passwd to set a new password.
              pi@raspberrypi: $
              How do i get it to continue to the desktop screen?
              • Mykle1M
                @navyvette87
                I’ve never encountered that before. Maybe, revert the changes you just made, get your mirror running, then try them again, 1 at a time
                • N
                  navyvette87
                  fixed the light display thing by rebooting with hdmi unplugged, then repluging it in, then rebooting, but the ssh message still there
                  ? 1 Reply Last reply
                    A Former User @navyvette87
                    @navyvette87
                    It means as written. Change your password with command passwd.
                    just try passwd in your terminal.
                    N 1 Reply Last reply
                    • N
                      navyvette87 @Guest
                      @Sean It ended up being one of the changes I made to set up the pi for the screensaver edit. I did try passwd though. thanks eveyone. I got it up and running. I have another post for a module problem, once I get that figured out, I will start on the hardware.
                      • MikgaboM
                        Mikgabo
                        Hey guys,
                        Noob question…
                        So, I’m running MM2 on my Pi Zero W and can’t figure out home to get to my config.js through terminal. Can someone help me out???
                        Cheers,
                        Mike
                        MikgaboM 1 Reply Last reply
                        • MikgaboM
                          Mikgabo @Mikgabo
                          NEVER MIND…FIGURED IT OUT :)
