added new module/not showing up
9 Posts 3 Posters 3.8k Views 3 Watching
  • N Offline
    navyvette87
    Added the module to the config file, it shows in the list below that is there, but says no helper, What is this and how do I fix it?
    Starting MagicMirror: v2.1.3
    Loading config …
    Loading module helpers …
    No helper found for module: MMM-JEOPARDY.
    All module helpers loaded.
    Starting server on port 8080 …
    Server started …
    Starting module: newsfeed
    Sockets connected & modules started …
    Ready to go! Please point your browser to: http://localhost:8080
    Create new calendar fetcher for url: http://www.calendarlabs.com/templates/ical/US-Holidays.ics - Interval: 300000
    Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
    ? 1 Reply Last reply Oct 27, 2017, 7:06 AM Reply Quote 0
      A Former User @navyvette87
      @navyvette87
      You don’t need to mind No helper found for module. It means just that module has no node_helper.js to execute. And usually, that is not a bug unless developer made some mistake. (some modules work enough without node_helper.js)
      N 1 Reply Last reply Oct 27, 2017, 7:23 AM Reply Quote 0
      • N Offline
        navyvette87 @Guest
        @Sean That module is not showing up on the screen though. I put the code in the config file with the { } on either end. so will have to look into it further when I have time.
        M 1 Reply Last reply Oct 27, 2017, 11:11 AM Reply Quote 0
          Mykle1 Project Sponsor Module Developer @navyvette87
          @navyvette87 said in added new module/not showing up:
          Are you talking about MMM-JEOPARDY? I just checked it and it’s working normally. I did a minor fix at the same time so git pull in the MagicMirror/modules/MMM-Jeopardy directory for that update. The entire config.js entry for MMM-JEOPARDY is as follows:
              module: 'MMM-JEOPARDY',
              position: 'top_left',                  // Works well anywhere
          	    useHeader: false,              // true if you want a header
                      header: "This is Jeopardy!",   // Any text you want
          	    maxWidth: "250px",             // Stretch or constrain according to region
          	    animationSpeed: 3000,          // New clue fades in and out
          Pay particular attention to the last } It has a comma after it
          N 1 Reply Last reply Oct 27, 2017, 11:32 AM Reply Quote 0
          • N Offline
            navyvette87 @Mykle1
            @Mykle1 no the weather module. used the link on the main page , I copied the code and inserted it in the config.js. and its not showing up. I can copy it and put it on here later tonight.
            But I think i dropped the jeopardy one in there to, so i will check and up date when I get back to that project tonight.
            M 1 Reply Last reply Oct 27, 2017, 11:34 AM Reply Quote 0
              @navyvette87
              Ok, weather won’t show without an API key, just so you know. The directions are in the readme for the module
              • N Offline
                navyvette87
                ok got that one to work, now trying to get stocks put in. the following is the config file,
                /* Magic Mirror Config Sample
                • MIT Licensed.
                • For more information how you can configurate this file
                • See https://github.com/MichMich/MagicMirror#configuration
                var config = {
                // - “”, “0.0.0.0”, “::” to listen on any interface
                // Default, when address config is left out, is “localhost”
                port: 8080,
                ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
                // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
                // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],
                language: "en",
                timeFormat: 24,
                units: "imperial",
                		module: "alert",
                		module: "updatenotification",
                		position: "top_bar"
                		module: "clock",
                		position: "top_left"
                module: “calendar”,
                header: “US Holidays”,
                position: “top_left”,
                symbol: "calendar-check-o ",
                url: “webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics”
                module: “currentweather”,
                position: “top_right”,
                locationID: “”, //ID from http://www.openweathermap.org/help/city_list.txt
                appid: “6ed9d867d3ba972c013edecdef1e685a”
                module: “weatherforecast”,
                header: “Weather Forecast”,
                module: ‘stocks’,
                position: ‘middle_center’,
                stocks: ‘.DJI,MSFT,AAPL,GOOG,INTC,CICS,TSLA,FB’, // stock symbols
                updateInterval: 37000 // update interval in milliseconds
                module: “newsfeed”,
                position: “bottom_bar”,
                feeds: [
                title: “New York Times”,
                url: “http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml”
                showSourceTitle: true,
                showPublishDate: true
                position: “top_right”, // This can be any of the regions.
                // Best results in left or right regions.
                // See ‘Configuration options’ for more information.
                locationID: “”, //Location ID from http://openweathermap.org/help/city_list.txt
                appid: “abcde12345abcde12345abcde12345ab” //openweathermap.org API key.
                if (typeof module !== “undefined”) {module.exports = config;}
                And the node start
                Loading config …
                Module helper loaded: stocks
                Server started …
                Connecting socket for: stocks
                stocks helper started …
                . it looks like it has started the stock helper and socket, but not showing on node screen, I changed the position to middle_center
                M 1 Reply Last reply Oct 28, 2017, 12:35 AM Reply Quote 0
                  @navyvette87
                  First, when you do post your code here, please post in a code block so that it is easier to read. My old eyes can’t look at that!
                  Second, I don’t use the stock module. However, I did read recently that there was some problem with it. A forum search found this
                  https://forum.magicmirror.builders/topic/4806/stock-module-problem
                  N 1 Reply Last reply Oct 28, 2017, 4:28 AM Reply Quote 0
                  • N Offline
                    navyvette87 @Mykle1
                    @Mykle1 Thanks everyone, got it all together, got the New York Times feed at the bottom, interesting quotes in the middle. Time, date, calendar on left top. Weather top right. Now on to find a screen.
