    MMM-xiaomi - Temperature and Humidity from your smarthome
    142 Posts 28 Posters 242.4k Views 28 Watching
      cxlwill @mirko3000
      @mirko3000 Well, I have temp&hum sensor and it works well with Home Assistant and Homebridge. So I think the API itself is OK. I will check the log. Nice plugin anyway. Maybe we can extend it to more Xiaomi devices.
      • cowboysdudeC
        cowboysdude Module Developer @barnosch
        @barnosch said in MMM-xiaomi - Temperature and Humidity from your smarthome:
        @cowboysdude : As i read, the Gateway is mandatory.
        But as always Xiaomi is really cheap. GW is about 25$ i guess.
        I ordered some temp sensors. Can’t wait to test the stuff.
        I saw the gateway was inexpensive so if I can find a US plug adapter for this I will be ordering the gateway and about 9 of the temp sensors :)
        • A
          Albert2002
          How to figure out the id of the sensor?
            mirko3000
            Well the IDs show up in your magic mirror - the problem is to identify which ID belongs to which sensor. I guessed them by checking the temperature, still I agree that this is not very convenient so far. Looking out for a better solution…
            • A
              Albert2002
              Thank you for your replay!
              When I do so I get a “Connecting to XIAOMI gatway…”
              Connecting to XIAOMI gatway..
              As far as I understand "ENETUNREACH " means Network unreachable. I can successfully ping the Gatway at 192.168.2.107 via VNC & LX Terminal.
              Do I have to set up something on my Gateway first?
              Any idea what to do?
              This is what my error log says:
              ERROR! Could not find main module js file for RepositoryForRC
              ERROR! Could not find main module js file for async
              { Error: send ENETUNREACH 192.168.2.107:54321
                  at Object.exports._errnoException (util.js:1050:11)
                  at exports._exceptionWithHostPort (util.js:1073:20)
                  at SendWrap.afterSend [as oncomplete] (dgram.js:402:11)
                code: 'ENETUNREACH',
                errno: 'ENETUNREACH',
                syscall: 'send',
                address: '192.168.2.107',
                port: 54321 }
              My mm out:
              Starting MagicMirror: v2.1.3
              Loading config ...
              Loading module helpers ...
              Module helper loaded: MMM-Remote-Control
              Module helper loaded: MMM-xiaomi
              All module helpers loaded.
              Server started ...
              Connecting socket for: MMM-Remote-Control
              Starting node helper for: MMM-Remote-Control
              Connecting socket for: MMM-xiaomi
              Starting xiaomi helper
              Launching application.
              Triggering Xiaomi Gateway upate
              • A
                Albert2002
                I’ve made a completely new Raspian & MM installation. No other modules installed. the default modules disabled in the config.js.
                I Still get no connection. Im running the Home Gatewy V3 in Dev mode. Do I have to change any settings on my router or somewhere else?
                Right now I get different error messages. Maybe it helps. I would love to see this module running!
                mm-out:
                > magicmirror@2.1.3 start /home/pi/MagicMirror
                > sh run-start.sh
                Loading config ...
                You're using a full whitelist configuration to allow for all IPs
                Server started ...
                MagicMirror error log:
                Error: Token could not be auto-discovered
                    at Device._tokenResolve (/home/pi/MagicMirror/modules/MMM-xiaomi/node_modules/miio/lib/device.js:141:13)
                    at Device._onMessage (/home/pi/MagicMirror/modules/MMM-xiaomi/node_modules/miio/lib/device.js:80:9)
                    at emitTwo (events.js:106:13)
                    at Socket.emit (events.js:194:7)
                    at UDP.onMessage [as onmessage] (dgram.js:545:8)
                MagicMirror out:
                > sh run-start.sh
                Loading config ...
                Server started ...
                mm error log:
                { Error: listen EADDRINUSE 127.0.0.1:8080
                    at Server.setupListenHandle [as _listen2] (net.js:1263:14)
                    at listenInCluster (net.js:1304:12)
                    at doListen (net.js:1428:7)
                    at GetAddrInfoReqWrap.asyncCallback [as callback] (dns.js:62:16)
                    at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:78:10)
                  code: 'EADDRINUSE',
                  errno: 'EADDRINUSE',
                  syscall: 'listen',
                  address: '127.0.0.1',
                  port: 8080 }
                  mirko3000
                  Hey Albert,
                  I think I have solved your issue: not all gateways seem to allow auto-discovery without authentification via a security token. I have added an additional configuration parameter now where you can provide your token:
                  https://github.com/mirko3000/MMM-xiaomi
                  Update the module and follow the description at the bottom:
                  https://github.com/mirko3000/MMM-xiaomi#authentification
                  Hope that works.
                  Best regards.
                  • A
                    Albert2002
                    Hi Mirko,
                    thank you for your work! I really appreciate this!
                    I’ve updated the module and installed the miio command line tools (with sudo)in the same directory. Or do I Have to install the miio command line tools in a different directory?
                    How ever, when am running miio command line tools i get
                    pi@raspberrypi:~/MagicMirror/modules/MMM-xiaomi $ miio --discover
                     INFO  Discovering devices. Press Ctrl+C to stop.
                    Device ID: 52238776
                    Model info: Unknown
                    Address: 192.168.2.107
                    Token: ???
                    Support: Unknown
                    My id I’ve discovered seams to be a different style then the one in your example.
                    After this I added the device id to my config:
                    devices: [{ id: '52238776', name: 'Wohnzimmer' }]
                    I still see the same as before.
                    mm error:
                    mm-out:
                    > sh run-start.sh
                    Loading config ...
                    Server started ...
                    MagicMirror error:
                      code: 'EADDRINUSE',
                      syscall: 'listen',
                      port: 8080 }
                    MagicMirror out:
                    > sh run-start.sh
                    Loading config ...
                    Server started ...
                      barnosch
                      God damnit.
                      Got a letter from the customs today, that my package from China arrived.
                      Sadly they are closing Fridays at 2.30pm. The letter arrived at 2.45pm.
                      So no chance to fetch it anymore.
                      The whole weekend is now useless!
                      Let`s see if i have also trouble …
                      • A
                        Albert2002
                        Maybe you can get it tomorrow? Would be great to figure out.
                        Something crossed my mind. When I set up the Developer mode in the Gateway there is a password too. I know that I need this one for OpenHAB. Maybe I need it for this module as well?
                        M 1 Reply Last reply
                          mirko3000 @Albert2002
                          So I just read through the documentation of miio and found this:
                          https://github.com/aholstenson/miio/blob/master/docs/management.md#getting-the-token-of-a-device
                          or:
                          https://github.com/aholstenson/miio/blob/master/docs/management.md#setting-the-token-of-a-device
                          My device seems to provide the token “via auto-token”, in your case it seems it does not. Maybe try either of the above.
                          IDs are same with me, maybe my documentation is wrong here.
                            mirko3000
                            When I run the discover tool I get the following:
                            Device ID: 56804143
                            Model info: Unknown
                            Address: 192.168.0.9 (xiaomi-gateway.fritz.box)
                            Token: cfbdb315c0825ccc971918e36923febe via auto-token
                            Support: Unknown
                            Device ID: 158d0001635bb3
                            Model info: lumi.sensor_ht (sensor)
                            Address: Owned by 56804143
                            Token: Automatic via parent device
                            Support: At least basic
                            • A
                              Albert2002
                              I am a step ahead!
                              I followed the instructions to get the token “Getting the token when using the Mi Home app”
                              This was working. I could see all the connected devices to the Gateway.
                              pi@raspberrypi:~/MagicMirror/modules/MMM-xiaomi $ miio --discover --sync
                              Device ID: 52238776
                              Model info: Unknown
                              Address: 192.168.13.1
                              Token: 6eea5ac1eb475bfedbfff98aab7c2bc7 via auto-token
                              Support: Unknown
                              Device ID: 158d000119fcb2
                              Model info: lumi.magnet (magnet)
                              Address: Owned by 52238776
                              Device ID: 158d00013e28ee
                              Model info: lumi.plug (power-plug)
                              Device ID: 158d00015aa973
                              Model info: lumi.switch (controller)
                              Device ID: 158d00015736a8
                              At this point I had to switch over to the Pi with the installed MagicMirror:
                              pi@MagicMirror:~ $ miio --discover
                              Device ID: 52238776
                              Model info: Unknown
                              Token: ???
                              Support: Unknown
                              I’ve updated the Token as described:
                              pi@MagicMirror:~ $ miio --update 52238776 --token 6eea5ac1eb475bfedbfff98aab7c2bc7
                               INFO  Attempting to update 52238776
                               INFO  Device updated
                              I’ve searched for devices again. Now with success!
                              Device ID: 52238776
                              Model info: Unknown
                              Token: 6eea5ac1eb475bfedbfff98aab7c2bc7 via stored token
                              Support: Unknown
                              The problem so far is, that I still don’t get any informations visible in MM. I’ve tried ‘158d00015736a8’ and as well ‘52238776’ as id.
                              The second problem is, that I’ve lost the Gateway in my Mi Home app after updating the Token!
                              The question is, how to copy ( Store?) over the Token to a different Machine?
                              mm error:
                              error: Token could not be auto-discovered
                                mirko3000
                                Ok at least some progress. So first to enable your manual token just update the configuration:
                                	 interval: 30,
                                	 gatewayIP: '192.168.13.1',
                                	 gatewayToken: '6eea5ac1eb475bfedbfff98aab7c2bc7',
                                	 devices : [{
                                You only need the IDs from your sensors, not the gateway.
                                About the Mi Home App and your lost token, I would try once this works to reconfigure your gateway with the Mi Home app, and then try to fetch the auto-token again (in your first sample it seems to provide auto-token).
                                • A
                                  Albert2002
                                  I did the steps again to get the (new) Token. Now, I have a new Token and the Gateway again in my Mi Home app. I didn’t updated the Token on the different machine this time.
                                  I’ve tried out your new config. I still don’t see more than before on the MM, but I don’t have an error log as well, which make it a bit more harder.
                                  I have checked the IP address of the Gateway, its still the same. Dev is still enabled.
                                  My config with the new Token.
                                  		module: 'MMM-xiaomi',
                                  		position: 'bottom_left',
                                  		header: 'Temperatur / Feuchtigkeit',  // This is optional
                                  			interval: 30,
                                  			gatewayIP: '192.168.2.107',
                                  			gatewayToken: '050591e66a82f7adc92bfa6b03058cdb',
                                  			devices: [{ id: '158d00015736a8', name: 'Wohnzimmer' }]
                                  Edit:
                                  I get a error when I try to discover with miio:
                                  pi@MagicMirror:~/MagicMirror/modules/MMM-xiaomi/node_modules/miio $ miio --discover
                                  Device ID: 52238776
                                  Model info: Unknown
                                  Support: Unknown
                                  (node:3626) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 1): Error: Call to device timed out
                                  • A
                                    Albert2002
                                    Where did miio stored the Token?
                                    The Token Miio used “Token: 6eea5ac1eb475bfedbfff98aab7c2bc7 via stored token”
                                    is the old one! the new one is 050591e66a82f7adc92bfa6b03058cdb
                                      mirko3000
                                      Hmm not sure about miio details, I just know that you can sync the tokens via
                                      Else I would try manually setting to the correct (new) token.
                                      For the MM: try to uncomment line 51 in node_helper.js, this logs all found devices. You could also add some more logs here to see where the program fails.
                                      • A
                                        Albert2002
                                        Hi Mirko! Thanks for your reply!
                                        Before and after I uncommented the line 51 and restartet MM.
                                        Still with the old Token
                                        pi@MagicMirror:~ $ miio --discover --sync
                                        Device ID: 52238776
                                        Model info: Unknown
                                        Support: Unknown
                                        (node:25652) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 1): Error: Call to device timed out
                                        But right now after uncommenting the line the error log is different. In the log i can already see the Temperature and humidity (_properties: { temperature: 19.51, humidity: 62.44 },)!! The next step!
                                        > sh run-start.sh
                                        Loading config ...
                                        Module helper loaded: MMM-DWD-WarnWeather
                                        Module helper loaded: MMM-PNews
                                        No helper found for module: MMM-Remote-Control-Repository.
                                        Module helper loaded: internet-monitor
                                        Module helper loaded: MMM-MovieListings
                                        Module helper loaded: MMM-Fuel
                                        Module helper loaded: MMM-NetworkScanner
                                        Module helper loaded: MMM-nasaastropic
                                        Module helper loaded: MMM-SystemStats
                                        Module helper loaded: MMM-Departures
                                        No helper found for module: MMM-Carousel.
                                        Module helper loaded: MMM-Events
                                        Server started ...
                                        Connecting socket for: MMM-DWD-WarnWeather
                                        MMM-DWD-WarnWeather helper started...
                                        Connecting socket for: MMM-PNews
                                        Starting module: MMM-PNews
                                        Starting module: newsfeed
                                        Connecting socket for: internet-monitor
                                        internet-monitor helper started ...
                                        Connecting socket for: MMM-MovieListings
                                        MMM-MovieListing helper started...
                                        Connecting socket for: MMM-Fuel
                                        Starting module helper: MMM-Fuel
                                        Connecting socket for: MMM-NetworkScanner
                                        Starting module: MMM-NetworkScanner
                                        Connecting socket for: MMM-nasaastropic
                                        Starting node helper: MMM-nasaastropic
                                        Connecting socket for: MMM-SystemStats
                                        Connecting socket for: MMM-Departures
                                        Connecting socket for: MMM-Events
                                        Starting node_helper for: MMM-Events
                                        Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/htc.one.m2304%40gmail.com/private-;-)/basic.ics - Interval: 300000
                                        Create new news fetcher for url: http://www.haz.de/rss/feed/haz_schlagzeilen - Interval: 300000
                                        Create new news fetcher for url: http://www.spiegel.de/schlagzeilen/index.rss - Interval: 300000
                                        starting internet monitor node helper
                                        MMM-NetworkScanner received CONFIG
                                        astro helper: config received
                                        retrieveAndUpdate()
                                        MMM-Departures error: Error: getaddrinfo ENOTFOUND transportrest-sbiermann.rhcloud.com transportrest-sbiermann.rhcloud.com:80
                                        NASA Astro Pic of the Day URL: https://apod.nasa.gov/apod/image/1711/m5_hubblesmessier1024c.jpg
                                        Magnet {
                                          domain: null,
                                          _events: {},
                                          _eventsCount: 0,
                                          _maxListeners: undefined,
                                          model: 'lumi.magnet',
                                          type: 'magnet',
                                          capabilities: [],
                                          _properties: {},
                                          _propertiesToMonitor: [],
                                          _propertyDefinitions: {},
                                          _parent:
                                           Gateway {
                                             domain: null,
                                             _events: {},
                                             _eventsCount: 0,
                                             type: 'gateway',
                                             model: 'lumi.gateway.v3',
                                             capabilities: [ 'color:rgb', 'brightness', 'sensor', 'illuminance' ],
                                             port: 54321,
                                             writeOnly: false,
                                             packet:
                                              Packet {
                                                header: ,
                                                _serverStampTime: 1509842296639,
                                                _token: ,
                                                _tokenKey: ,
                                                _tokenIV: ,
                                                data: ,
                                                _serverStamp: 48587 },
                                             socket:
                                              Socket {
                                                domain: null,
                                                _events: [Object],
                                                _eventsCount: 1,
                                                _handle: [Object],
                                                _receiving: true,
                                                _bindState: 2,
                                                type: 'udp4',
                                                fd: -42,
                                                _reuseAddr: undefined,
                                                _queue: undefined },
                                             _id: 4,
                                             _promises: {},
                                             _hasFailedToken: false,
                                             _properties: { illuminance: 307, rgb: [Object], brightness: 0 },
                                             _propertiesToMonitor: [ 'illumination', 'rgb' ],
                                             _propertyDefinitions: { illumination: [Object], rgb: [Object] },
                                             _reversePropertyDefinitions: { illuminance: 'illumination' },
                                             _loadProperties: [Function: bound _loadProperties],
                                             management: DeviceManagement { device: [Circular] },
                                             debug:
                                              { [Function: debug]
                                                namespace: 'miio.device.[192.168.2.107]',
                                                enabled: false,
                                                useColors: false,
                                                color: 1,
                                                inspectOpts: {} },
                                             _devices:
                                              { '158d000119fcb2': [Object],
                                                '158d00013e28ee': [Object],
                                                '158d00015aa973': [Object],
                                                '158d00015736a8': [Object] },
                                             _monitorInterval: 60000,
                                             _propertyMonitor:
                                              Timeout {
                                                _called: false,
                                                _idleTimeout: 60000,
                                                _idlePrev: [Object],
                                                _idleNext: [Object],
                                                _idleStart: 69767,
                                                _onTimeout: [Function: bound _loadProperties],
                                                _timerArgs: undefined,
                                                _repeat: 60000 },
                                             _lastToken: 1509842294044,
                                             _developerKey: 'xqbs1fvtsq6x4oby',
                                             devApi:
                                              DeveloperApi {
                                                domain: null,
                                                _events: [Object],
                                                _eventsCount: 2,
                                                debug: [Object],
                                                socket: [Object],
                                                devices: [],
                                                ready: false },
                                             setRGB: [Function],
                                             setBrightness: [Function],
                                             _deviceListTimer:
                                              Timeout {
                                                _called: false,
                                                _idleTimeout: 1800000,
                                                _idleStart: 72417,
                                                _onTimeout: [Function: bound _updateDeviceList],
                                                _repeat: 1800000 } },
                                          management: SubDeviceManagement { _device: [Circular] },
                                          debug:
                                           { [Function: debug]
                                             namespace: 'miio.device.[192.168.2.107].158d000119fcb2',
                                             enabled: false,
                                             useColors: false,
                                             color: 1,
                                             inspectOpts: {} } }
                                        Switch {
                                          domain: null,
                                          _events: {},
                                          _eventsCount: 0,
                                          model: 'lumi.switch',
                                          type: 'controller',
                                          capabilities: [],
                                          _properties: {},
                                          _parent:
                                           Gateway {
                                             domain: null,
                                             _events: {},
                                             _eventsCount: 0,
                                             type: 'gateway',
                                             port: 54321,
                                             writeOnly: false,
                                             packet:
                                              Packet {
                                                header: ,
                                                _token: ,
                                                _tokenKey: ,
                                                _tokenIV: ,
                                                data: ,
                                             socket:
                                              Socket {
                                                domain: null,
                                                _events: [Object],
                                                _eventsCount: 1,
                                                _handle: [Object],
                                                _receiving: true,
                                                _bindState: 2,
                                                type: 'udp4',
                                                fd: -42,
                                             _id: 4,
                                             _promises: {},
                                             debug:
                                              { [Function: debug]
                                                enabled: false,
                                                useColors: false,
                                                color: 1,
                                                inspectOpts: {} },
                                             _devices:
                                             _propertyMonitor:
                                              Timeout {
                                                _called: false,
                                                _idleStart: 69767,
                                                _repeat: 60000 },
                                             devApi:
                                              DeveloperApi {
                                                domain: null,
                                                _events: [Object],
                                                _eventsCount: 2,
                                                debug: [Object],
                                                socket: [Object],
                                                devices: [],
                                                ready: false },
                                             setRGB: [Function],
                                             _deviceListTimer:
                                              Timeout {
                                                _called: false,
                                                _idleStart: 72417,
                                          debug:
                                           { [Function: debug]
                                             namespace: 'miio.device.[192.168.2.107].158d00015aa973',
                                             enabled: false,
                                             useColors: false,
                                             color: 3,
                                             inspectOpts: {} } }
                                        SensorHT {
                                          domain: null,
                                          _events: {},
                                          _eventsCount: 0,
                                          model: 'lumi.sensor_ht',
                                          type: 'sensor',
                                          capabilities: [ 'sensor', 'temperature', 'humidity' ],
                                          _propertiesToMonitor: [ 'temperature', 'humidity' ],
                                           { temperature: { mapper: [Function] },
                                             humidity: { mapper: [Function] } },
                                          _parent:
                                           Gateway {
                                             domain: null,
                                             _events: {},
                                             _eventsCount: 0,
                                             type: 'gateway',
                                             port: 54321,
                                             writeOnly: false,
                                             packet:
                                              Packet {
                                                header: ,
                                                _token: ,
                                                _tokenKey: ,
                                                _tokenIV: ,
                                                data: ,
                                             socket:
                                              Socket {
                                                domain: null,
                                                _events: [Object],
                                                _eventsCount: 1,
                                                _handle: [Object],
                                                _receiving: true,
                                                _bindState: 2,
                                                type: 'udp4',
                                                fd: -42,
                                             _id: 4,
                                             _promises: {},
                                             debug:
                                              { [Function: debug]
                                                enabled: false,
                                                useColors: false,
                                                color: 1,
                                                inspectOpts: {} },
                                             _devices:
                                             _propertyMonitor:
                                              Timeout {
                                                _called: false,
                                                _idleStart: 69767,
                                                _repeat: 60000 },
                                             devApi:
                                              DeveloperApi {
                                                domain: null,
                                                _events: [Object],
                                                _eventsCount: 2,
                                                debug: [Object],
                                                socket: [Object],
                                                devices: [],
                                                ready: false },
                                             setRGB: [Function],
                                             _deviceListTimer:
                                              Timeout {
                                                _called: false,
                                                _idleStart: 72417,
                                          debug:
                                           { [Function: debug]
                                             namespace: 'miio.device.[192.168.2.107].158d00015736a8',
                                             enabled: false,
                                             useColors: false,
                                             color: 6,
                                             inspectOpts: {} } }
                                        • A
                                          Albert2002
                                          One more. When I run the MM as standalone server (node serveronly) I get this in the Browser console:
                                          MMM-xiaomi.js:28 received XIAOMI_DATA
                                          MMM-xiaomi.js:212 Uncaught TypeError: Cannot read property 'id' of null
                                              at Class. (MMM-xiaomi.js:212)
                                              at Function.each (jquery-2.2.3.min.js:2)
                                              at Class.renderText (MMM-xiaomi.js:210)
                                              at Class.render (MMM-xiaomi.js:100)
                                              at Class.socketNotificationReceived (MMM-xiaomi.js:29)
                                              at module.js:183
                                              at r. (socketclient.js:25)
                                              at r.emit (index.js:133)
                                              at r.onevent (socket.js:270)
                                              at r.MMSocket.self.socket.onevent (socketclient.js:19)
                                          (anonymous) @ MMM-xiaomi.js:212
                                          each @ jquery-2.2.3.min.js:2
                                          renderText @ MMM-xiaomi.js:210
                                          render @ MMM-xiaomi.js:100
                                          socketNotificationReceived @ MMM-xiaomi.js:29
                                          (anonymous) @ module.js:183
                                          (anonymous) @ socketclient.js:25
                                          r.emit @ index.js:133
                                          r.onevent @ socket.js:270
                                          MMSocket.self.socket.onevent @ socketclient.js:19
                                          r.onpacket @ socket.js:228
                                          (anonymous) @ index.js:21
                                          r.ondecoded @ manager.js:345
                                          s.add @ index.js:241
                                          r.ondata @ manager.js:335
                                          r.onPacket @ socket.js:457
                                          (anonymous) @ socket.js:274
                                          r.onPacket @ transport.js:145
                                          r.onData @ transport.js:137
                                          ws.onmessage @ websocket.js:147
                                            mirko3000
                                            Try the latest update (git pull), I just checked for null items - even i that should not happen.
                                            • 1 / 8
