    MMM-xiaomi - Temperature and Humidity from your smarthome
    141 Posts 27 Posters 234.1k Views 27 Watching
      mirko3000
      Description
      Hi guys,
      just made a small module to display temperature and humidity from your Xiaomi smarthome sensors. Pretty basic so far, but hugely helpful to me to monitor heating and ventilation (humidity!).
      Screenshots
      Sensors look like this and cost around 8 €:
      alt text
      Here a sample from the module:
      alt text
      Download
      [card:mirko3000/MMM-xiaomi]
      • cowboysdudeC Offline
        Good call… that company is going to be making a ton of smart things! :) Great job.
        Do you have a link to the module?
          barnosch
          Great. Looking forward for the module…
          Meanwhile i order some of the Xiaomi stuff in China ;)
            cxlwill
            Great work. But mine keeps looking for gateway. I’m pretty sure that the ip of GW is correct.
              mirko3000
              Sorry, forgot about the link:
              https://github.com/mirko3000/MMM-xiaomi
              @barnosch, @cxlwill: Did you check the logs? Anything showing up there?
                mirko3000
                Also it only supports xiaomi temperature sensors, so if you don’t have any registered on your gateway it will not show anything (Keeping in “Connecting to gateway…” mode).
                  cowboysdude Module Developer @mirko3000
                  @mirko3000 Thank you for this!! Exactly what I have been looking for… this is truly awesome!
                  I would like about 9 of these sensors… do I also need the gateway as well?
                    barnosch @cowboysdude
                    @cowboysdude : As i read, the Gateway is mandatory.
                    But as always Xiaomi is really cheap. GW is about 25$ i guess.
                    I ordered some temp sensors. Can’t wait to test the stuff.
                      cxlwill @mirko3000
                      @mirko3000 Well, I have temp&hum sensor and it works well with Home Assistant and Homebridge. So I think the API itself is OK. I will check the log. Nice plugin anyway. Maybe we can extend it to more Xiaomi devices.
                        cowboysdude Module Developer @barnosch
                        @barnosch said in MMM-xiaomi - Temperature and Humidity from your smarthome:
                        I saw the gateway was inexpensive so if I can find a US plug adapter for this I will be ordering the gateway and about 9 of the temp sensors :)
                          Albert2002
                          How to figure out the id of the sensor?
                            mirko3000
                            Well the IDs show up in your magic mirror - the problem is to identify which ID belongs to which sensor. I guessed them by checking the temperature, still I agree that this is not very convenient so far. Looking out for a better solution…
                              Albert2002
                              Thank you for your replay!
                              When I do so I get a “Connecting to XIAOMI gatway…”
                              Connecting to XIAOMI gatway..
                              As far as I understand "ENETUNREACH " means Network unreachable. I can successfully ping the Gatway at 192.168.2.107 via VNC & LX Terminal.
                              Do I have to set up something on my Gateway first?
                              Any idea what to do?
                              This is what my error log says:
                              ERROR! Could not find main module js file for RepositoryForRC
                              ERROR! Could not find main module js file for async
                              { Error: send ENETUNREACH 192.168.2.107:54321
                                  at Object.exports._errnoException (util.js:1050:11)
                                  at exports._exceptionWithHostPort (util.js:1073:20)
                                  at SendWrap.afterSend [as oncomplete] (dgram.js:402:11)
                                code: 'ENETUNREACH',
                                errno: 'ENETUNREACH',
                                syscall: 'send',
                                address: '192.168.2.107',
                                port: 54321 }
                              My mm out:
                              Starting MagicMirror: v2.1.3
                              Loading config ...
                              Loading module helpers ...
                              Module helper loaded: MMM-Remote-Control
                              Module helper loaded: MMM-xiaomi
                              All module helpers loaded.
                              Server started ...
                              Connecting socket for: MMM-Remote-Control
                              Starting node helper for: MMM-Remote-Control
                              Connecting socket for: MMM-xiaomi
                              Starting xiaomi helper
                              Launching application.
                              Triggering Xiaomi Gateway upate
                                Albert2002
                                I’ve made a completely new Raspian & MM installation. No other modules installed. the default modules disabled in the config.js.
                                I Still get no connection. Im running the Home Gatewy V3 in Dev mode. Do I have to change any settings on my router or somewhere else?
                                Right now I get different error messages. Maybe it helps. I would love to see this module running!
                                mm-out:
                                > magicmirror@2.1.3 start /home/pi/MagicMirror
                                > sh run-start.sh
                                Loading config ...
                                You're using a full whitelist configuration to allow for all IPs
                                Server started ...
                                MagicMirror error log:
                                Error: Token could not be auto-discovered
                                    at Device._tokenResolve (/home/pi/MagicMirror/modules/MMM-xiaomi/node_modules/miio/lib/device.js:141:13)
                                    at Device._onMessage (/home/pi/MagicMirror/modules/MMM-xiaomi/node_modules/miio/lib/device.js:80:9)
                                    at emitTwo (events.js:106:13)
                                    at Socket.emit (events.js:194:7)
                                    at UDP.onMessage [as onmessage] (dgram.js:545:8)
                                MagicMirror out:
                                > sh run-start.sh
                                Loading config ...
                                Server started ...
                                mm error log:
                                { Error: listen EADDRINUSE 127.0.0.1:8080
                                    at Server.setupListenHandle [as _listen2] (net.js:1263:14)
                                    at listenInCluster (net.js:1304:12)
                                    at doListen (net.js:1428:7)
                                    at GetAddrInfoReqWrap.asyncCallback [as callback] (dns.js:62:16)
                                    at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:78:10)
                                  code: 'EADDRINUSE',
                                  errno: 'EADDRINUSE',
                                  syscall: 'listen',
                                  address: '127.0.0.1',
                                  port: 8080 }
                                  mirko3000
                                  Hey Albert,
                                  I think I have solved your issue: not all gateways seem to allow auto-discovery without authentification via a security token. I have added an additional configuration parameter now where you can provide your token:
                                  Update the module and follow the description at the bottom:
                                  https://github.com/mirko3000/MMM-xiaomi#authentification
                                  Hope that works.
                                  Best regards.
                                    Albert2002
                                    Hi Mirko,
                                    thank you for your work! I really appreciate this!
                                    I’ve updated the module and installed the miio command line tools (with sudo)in the same directory. Or do I Have to install the miio command line tools in a different directory?
                                    How ever, when am running miio command line tools i get
                                    pi@raspberrypi:~/MagicMirror/modules/MMM-xiaomi $ miio --discover
                                     INFO  Discovering devices. Press Ctrl+C to stop.
                                    Device ID: 52238776
                                    Model info: Unknown
                                    Address: 192.168.2.107
                                    Token: ???
                                    Support: Unknown
                                    My id I’ve discovered seams to be a different style then the one in your example.
                                    After this I added the device id to my config:
                                    devices: [{ id: '52238776', name: 'Wohnzimmer' }]
                                    I still see the same as before.
                                    mm error:
                                    mm-out:
                                    > sh run-start.sh
                                    Loading config ...
                                    Server started ...
                                    MagicMirror error:
                                      code: 'EADDRINUSE',
                                      syscall: 'listen',
                                      port: 8080 }
                                    MagicMirror out:
                                    > sh run-start.sh
                                    Loading config ...
                                    Server started ...
                                      barnosch
                                      God damnit.
                                      Got a letter from the customs today, that my package from China arrived.
                                      Sadly they are closing Fridays at 2.30pm. The letter arrived at 2.45pm.
                                      So no chance to fetch it anymore.
                                      The whole weekend is now useless!
                                      Let`s see if i have also trouble …
                                        Albert2002
                                        Maybe you can get it tomorrow? Would be great to figure out.
                                        Something crossed my mind. When I set up the Developer mode in the Gateway there is a password too. I know that I need this one for OpenHAB. Maybe I need it for this module as well?
                                          mirko3000 @Albert2002
                                          So I just read through the documentation of miio and found this:
                                          https://github.com/aholstenson/miio/blob/master/docs/management.md#getting-the-token-of-a-device
                                          or:
                                          https://github.com/aholstenson/miio/blob/master/docs/management.md#setting-the-token-of-a-device
                                          My device seems to provide the token “via auto-token”, in your case it seems it does not. Maybe try either of the above.
                                          IDs are same with me, maybe my documentation is wrong here.
                                            mirko3000
                                            When I run the discover tool I get the following:
                                            Device ID: 56804143
                                            Model info: Unknown
                                            Address: 192.168.0.9 (xiaomi-gateway.fritz.box)
                                            Token: cfbdb315c0825ccc971918e36923febe via auto-token
                                            Support: Unknown
                                            Device ID: 158d0001635bb3
                                            Model info: lumi.sensor_ht (sensor)
                                            Address: Owned by 56804143
                                            Token: Automatic via parent device
                                            Support: At least basic
                                            • 1 / 8
